Старый 02.11.2010, 20:05   #1
workflowax: No .NET Business connector session found.
Источник: http://workflowax.wordpress.com/2010...session-found/
My quick fix for the day. If you are getting an error message “No .NET Business connector session found.”  in your system event log, there may be a number of things to look at, however the first thing to check is whether the default business connector on your IIS machine is set up and pointing to the correct AOS. This may occur on development servers with multiple AOS instances. You can take a look at this post how to setup multiple workflow websites on the same machine in order to avoid this issue.
Happy Daxing
Dynamics Ax: Workflow Error “No .NET Business Connector Session could be found” in Dynamics AX2009 Blog bot DAX Blogs 0 18.09.2010 21:06
Arijit Basu: DAX 4.01 .NET Business Connector: Microsoft.Dynamics.BusinessConnectorNet Blog bot DAX Blogs 3 30.09.2008 01:17
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Inside Dynamics AX 4.0: Inside the Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
ALEG: Проект "Фишка недели" и первый пост - Microsoft Dynamics™ AX .NET Business Connector Blog bot DAX Blogs 1 22.11.2006 09:43
Часовой пояс GMT +3, время: 11:55.
