22.11.2010, 14:11 | #1 |
xplusplus: How to: prompt a dialog box or a modal window
Источник: http://xplusplus.info/index.php/how-...-modal-window/
============== In this post I will review the different types of dialog boxes that can be used within the AX system. There are many scenarios where you want to prompt a message or dialog box to the user. That could be achieved within the box class in the AOT. Here are some example of the common ones - 1. Inofrmation Box::info(str _text,str _title);2. Warning Box::warning(str _text,str _title);3. Critical stop Box::stop(str _text,str _title);4. "Do not tell me again" check box Box::infoOnce(str _heading,str _information,str owner);5. OK / Cancel dialog box DialogButton diagBut;;diagBut = Box::yesNo(str _text,DialogButton _defaultButton,str _title);6. Yes to all dialog box DialogButton diagBut;;diagBut = Box::yesAllNoAllCancel(str _text,DialogButton _defaultButton,str _title); Summery In the last two examples, the box method will return the name of the selected option button. Then, you can use the variable diagBut to proceed with your operations: if (diagBut == dialogbutton::Ok) { //do something } Источник: http://xplusplus.info/index.php/how-...-modal-window/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
Опции просмотра | |
