22.02.2012, 17:41 | #1 |
Different labels depends on company
Hello Guys,
Is there any way AX dimension labels to be dependent on company? For example in one company Dimension[1] to be "Department", but in another company to be "Purpose". I thing It's not possible, but hwo knows... There is workaround to use different languages, but I donn't like this idea! Regards, 10x |
23.02.2012, 10:39 | #2 |
You can try to change the label of controls in the RunTime.
SysSetupFormRun + Итератор с поддержкой методов обратного вызова для обработки контролов на форме |
23.02.2012, 15:46 | #3 |
Thanks for your idea, but this is the case only for forms. And reports...?
I'm searching for solution in general. Regards, |
24.02.2012, 00:31 | #4 |
Британский учённый
Сообщение от ist
Hello Guys,
Is there any way AX dimension labels to be dependent on company? For example in one company Dimension[1] to be "Department", but in another company to be "Purpose". I thing It's not possible, but hwo knows... There is workaround to use different languages, but I donn't like this idea! Regards, 10x I can't see a simple way. The languages that you have mentioned also required additional license.
Людям физического труда для восстановления своих сил нужен 7-8 часовой ночной сон. Людям умственного труда нужно спать часов 9-10. Ну а программистов будить нельзя вообще. |
24.02.2012, 15:03 | #5 |
It's not necessary to use a two (or more) physical copies of application files in that scenario. You can have two different application folders but application files in one of them can be just hardlinks to the same files in the other folder and only label files can differ. In that case AOSes that use both of the application folders will actually work with the same «physical» application files so that you wouldn't have to sync the applications (which is vital if two or more applications are used with the same database). But anyway such an approach requires very careful application maintenance.
За это сообщение автора поблагодарили: Link (2). |
Опции просмотра | |
