#1 |
ax-erp: Get underlying SQL query using getSQLStatement [Dynamics AX 2012]
Источник: http://microsoft-dynamics-ax-erp.blo...ery-using.html
============== Friends, To get the underlying SQL query or statement from the X++ query, use getSQLStatement method. getSQLStatement is a new method that has been introduced in tables in AX 2012. The X++ select has been extended with the generateonly command that instructs the underlying data access framework to generate the SQL query without actually executing it. staticvoid SR_getSQLStatement(Args _args) { CustTable custTable; CustTrans custTrans; ; selectgenerateonlyfirstOnly AccountNum, CustGroup from custTable join custTrans where custTrans.AccountNum == custTable.AccountNum; info(custTable.getSQLStatement()); } Below is the SQL query. ![]() Simple but very useful for developers for trouble shooting or to use it on reports. Источник: http://microsoft-dynamics-ax-erp.blo...ery-using.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
Теги |
ax2012, sql |
Опции просмотра | |
