16.07.2018, 14:12 | #1 |
crmtipoftheday: Tip #1134: Moving Users Between Business Units
Источник: https://crmtipoftheday.com/1134/movi...usiness-units/
============== As discussed in 917, moving Users between Business Units can be difficult and, as Joel suggested in 935, a good option when setting up a new system is to add a child Business Unit from the outset and add all the Users there. In a recent implementation I did not do this (in my defence, I did start the project before Joel wrote the tip.) So what do you do when you have ignored the Tips of the Day and are experiencing Spießrutenlaufen? In my scenario I had 300 users to move to child Business Units. Also, as the change was driven by a security requirement, all Security Roles were changing. This was my approach. First of all I needed to know who had what Security Roles. This can be done with the SSRS User Summary report which comes with Dynamics. You also will need to check whether any of your Teams have Security Roles assigned and whether these need moving and the consequences. In our case this was not a problem but, if it is, I would try Mitch Milan’s SnapShot! tool which is excellent for such things. Exporting the User Summary report to Excel allows you to work out the ‘clusters’ of Users with the same security configuration. This means you can deal with groups of Users at once, which will save time. In my case this meant I was dealing with 90 clusters instead of 300 Users. Once I knew the clusters, this is what I did:
This was the process:
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
