22.11.2006, 20:25 | #1 |
New behaviour on forms after KR2 release
Hello,
If you have KR2 deployed, go to any form and set filter on any field and then try to create new record ( CTRL+N). Your filter will disappear. Before KR2 deployment the filter would stay. The other new thing can be demostrated in LedgerJournalSplitPosting. You can't set a focus on a lower grid just by clicking on it ( it used to work always). Now you need to do a left click then right click ( this is a work around ) to get a focus. The solution to this one was to change property on the datasource: InsertIfempty to 'Yes'. Then you can just highlight the empty buffer and continue with entering data. I didn't see any mentioning in the release docs from Microsoft. I am wondering what other things are out there. I appreciate any comments. Thanks, gb |
За это сообщение автора поблагодарили: glibs (1). |
22.11.2006, 20:48 | #2 |
Сообщение от gb
If you have KR2 deployed, go to any form and set filter on any field and then try to create new record ( CTRL+N). Your filter will disappear. Before KR2 deployment the filter would stay. ... Thanks for info.
С уважением, glibs® |
22.11.2006, 23:33 | #3 |
I am hoping that there is an easy way to keep that filter on the data source.
May be somebody already found a solution and can share. Thanks, gb |
