#1 |
RetrieveMultiple
Хочу вытащить записи по значению атрибута. Пробовал 2 разных кода:
ConditionExpression condition = new ConditionExpression(); condition.AttributeName = "new_ExtID"; condition.Operator = ConditionOperator.Equal; condition.Values = new string[] { ExtID }; FilterExpression filter = new FilterExpression(); filter.FilterOperator = LogicalOperator.And; filter.Conditions = new ConditionExpression[] { condition }; QueryExpression query = new QueryExpression(); query.EntityName = EntityName.account.ToString(); query.ColumnSet = new AllColumns(); query.Criteria = filter; BusinessEntityCollection Customer = service.RetrieveMultiple(query); и QueryByAttribute query = new QueryByAttribute(); query.ColumnSet = new AllColumns(); query.EntityName = EntityName.account.ToString(); query.Attributes = new string[] { "new_ExtID" }; query.Values = new string[] { ExtID }; BusinessEntityCollection Customer = service.RetrieveMultiple(query); где "new_ExtID" искомый атрибут, ExtID - входящее значение. Запускаю через расширенную SQL процедуру, работает 7-8 минут, затем выдает ошибку: The request was aborted: The request was canceled. |
#2 |
Чайный пьяница
Сообщение от vital.mih
![]() Хочу вытащить записи по значению атрибута. Пробовал 2 разных кода:
ConditionExpression condition = new ConditionExpression(); condition.AttributeName = "new_ExtID"; condition.Operator = ConditionOperator.Equal; condition.Values = new string[] { ExtID }; FilterExpression filter = new FilterExpression(); filter.FilterOperator = LogicalOperator.And; filter.Conditions = new ConditionExpression[] { condition }; QueryExpression query = new QueryExpression(); query.EntityName = EntityName.account.ToString(); query.ColumnSet = new AllColumns(); query.Criteria = filter; BusinessEntityCollection Customer = service.RetrieveMultiple(query); и QueryByAttribute query = new QueryByAttribute(); query.ColumnSet = new AllColumns(); query.EntityName = EntityName.account.ToString(); query.Attributes = new string[] { "new_ExtID" }; query.Values = new string[] { ExtID }; BusinessEntityCollection Customer = service.RetrieveMultiple(query); где "new_ExtID" искомый атрибут, ExtID - входящее значение. Запускаю через расширенную SQL процедуру, работает 7-8 минут, затем выдает ошибку: The request was aborted: The request was canceled. При формировании RetrieveMultipleRequest укажите RetrieveDynamicEntity - true. Кроме того напишите, пожалуйста, какого типа аттрибут new_ExtID. Если это лукап - тогда в качестве параметров для фильтрации надо использовать GUID, а не строку. Кроме того попытайтесь таким образом объявить фильтр: query.Values = new object[] { ExtID };
Эмо разработчик, сначала пишу код, потом плачу над его несовершенством. Подписывайтесь на мой блог, twitter и YouTube канал. Пользуйтесь моим Ultimate Workflow Toolkit |
#3 |
new_ExtID nvarchar, хорошо попробую как вы описали.
#4 |
а еще такой вопрос, что возвратит retrieve если не найдет записей, удовлетворяющих условию?
#5 |
Чайный пьяница
BusinessEntityCollection с количеством записей в коллекции равным 0.
#6 |
RetrieveMultipleRequest request = new RetrieveMultipleRequest();
ColumnSet cols = new ColumnSet(); cols.Attributes = new string[] { "new_ExtID","accountid" }; ConditionExpression condition = new ConditionExpression(); condition.AttributeName = "new_ExtID"; condition.Operator = ConditionOperator.Like; condition.Values = new string[] { ExtID }; FilterExpression filter = new FilterExpression(); filter.FilterOperator = LogicalOperator.And; filter.Conditions = new ConditionExpression[] { condition }; QueryExpression query = new QueryExpression(); query.EntityName = "account"; query.ColumnSet = cols; query.Criteria = filter; request.Query = query; request.ReturnDynamicEntities = true; // Execute the request. RetrieveMultipleResponse response = (RetrieveMultipleResponse)service.Execute(request); //Выводим коллекцию значений BusinessEntityCollection Customer = response.BusinessEntityCollection; Test = Customer.ToString(); Я знаю, что в базе значений с таким условием нет, правильно ли я ожидаю увидеть test=0, или же здесь необходимо написать функцию типа if exists? |
#7 |
Чайный пьяница
Если так, то используйте такой код:
Test = Customer.BusinessEntities.Count.ToString();
#8 |
Error 1 'System.Array' does not contain a definition for 'Count' and no extension method 'Count' accepting a first argument of type 'System.Array' could be found (are you missing a using directive or an assembly reference?)
#9 |
Чайный пьяница
В таком случае Count поменяйте на Length.
#10 |
все так же, процедура висит
#11 |
Чайный пьяница
Вы можете привести полный код для исследования?
#12 |
using System;
using System.Collections.Generic; using System.Text; using System.Data.Sql; using Microsoft.SqlServer.Server; using DiasToCrm.CrmWebService; namespace DiasToCrm { public static class Proxy { [SqlProcedure()] public static void AddCustomerToCrm(string ExtID, string Name, string INN, int RelationshipType, string Phone1, string Phone2, string Phone3, string email, out string Test, out string ErrorMessage, out string Ret_Error) { Test = String.Empty; ErrorMessage = String.Empty; // по дефолту ошибок нет Ret_Error=String.Empty; try { // Set up the CRM Service. CrmAuthenticationToken token = new CrmAuthenticationToken(); token.AuthenticationType = 0; token.OrganizationName = "ServiceDesk"; CrmService service = new CrmService(); service.Url = "http://crm:5555/ServiceDesk/mscrmservices/2007/crmservice.asmx"; service.CrmAuthenticationTokenValue = token; service.Credentials = System.Net.CredentialCache.DefaultCredentials; QueryByAttribute query = new QueryByAttribute(); query.ColumnSet = new AllColumns(); ; query.EntityName = EntityName.account.ToString(); query.Attributes = new string[] { "new_ExtID" }; query.Values = new string[] { "111" }; RetrieveMultipleRequest request = new RetrieveMultipleRequest(); request.Query = query; request.ReturnDynamicEntities = true; //Выводим коллекцию значений try { RetrieveMultipleResponse response = (RetrieveMultipleResponse)service.Execute(request); BusinessEntityCollection Customer = response.BusinessEntityCollection; Test = Customer.BusinessEntities.Length.ToString(); } catch (Exception Ret_ex) { Ret_Error = Ret_ex.Message; } } catch (Exception ex) { ErrorMessage = ex.Message; } } } } Я максимально упростил процедуру и создал аккаунт с атрибутом new_ExtID=111. Последний раз редактировалось vital.mih; 30.07.2009 в 15:07. |
#13 |
Чайный пьяница
![]() using System;
using System.Collections.Generic; using System.Text; using System.Data.Sql; using Microsoft.SqlServer.Server; using DiasToCrm.CrmWebService; namespace DiasToCrm { public static class Proxy { [SqlProcedure()] public static void AddCustomerToCrm(string ExtID, string Name, string INN, int RelationshipType, string Phone1, string Phone2, string Phone3, string email, out string Test, out string ErrorMessage, out string Ret_Error) { Test = String.Empty; ErrorMessage = String.Empty; // по дефолту ошибок нет Ret_Error=String.Empty; try { // Set up the CRM Service. CrmAuthenticationToken token = new CrmAuthenticationToken(); token.AuthenticationType = 0; token.OrganizationName = "ServiceDesk"; CrmService service = new CrmService(); service.Url = "http://crm:5555/ServiceDesk/mscrmservices/2007/crmservice.asmx"; service.CrmAuthenticationTokenValue = token; service.Credentials = System.Net.CredentialCache.DefaultCredentials; QueryByAttribute query = new QueryByAttribute(); query.ColumnSet = new AllColumns(); ; query.EntityName = EntityName.account.ToString(); query.Attributes = new string[] { "new_ExtID" }; query.Values = new string[] { "111" }; RetrieveMultipleRequest request = new RetrieveMultipleRequest(); request.Query = query; request.ReturnDynamicEntities = true; //Выводим коллекцию значений try { RetrieveMultipleResponse response = (RetrieveMultipleResponse)service.Execute(request); BusinessEntityCollection Customer = response.BusinessEntityCollection; Test = Customer.BusinessEntities.Length.ToString(); } catch (Exception Ret_ex) { Ret_Error = Ret_ex.Message; } } catch (Exception ex) { ErrorMessage = ex.Message; } } } } Я максимально упростил процедуру и создал аккаунт с атрибутом new_ExtID=111. service.Url = "http://crm:5555/ServiceDesk/mscrmservices/2007/crmservice.asmx"; на service.Url = "http://crm:5555/mscrmservices/2007/crmservice.asmx";
#14 |
пробовал, причем всегда так было, я только что для проверки вставил ServiceDesk
#15 |
Чайный пьяница
Судя по всему - вы пытаетесь создать сборку с классом, который будет использоваться непосредственно в SQL Server. Пробовали написать простую консоль, которая выполняет этот код?
#16 |
а есть возможность другим способом проверить существуют ли записи с заданным значением new_extid? Вот, например, ретрив одного значения по гуиду работает прекрасно. Но моя задача заключается в проверке наличия ранее созданных аккаунтов. Соответсвенно, если аккаунт был создан ранее - апдейтим, если ретрив возвращает ноль - создаем.
Есть конечно вариант создавать внешнюю таблицу, где связывать ExtID аккаунта с гуидом в СРМ и проверять наличие связи, но это менее желательный вариант. Последний раз редактировалось vital.mih; 30.07.2009 в 15:30. |
#17 |
нет не пробовал, пусть даже заработает, то что? мне в любом случае данные из SQL отправлять.
#18 |
Чайный пьяница
А можете объяснить зачем? Это так - в целях самообразования.
#19 |
Скорее всего я чего-нить не догоняю... Необходимо из базы данных отправить данные в СРМ, как подключиться к веб сервисам СРМ иначе кроме как с помощью расширенной процедуры я не знаю.
#20 |
Чайный пьяница
Ээээ. А не проще ли написать 100% работающую консоль, которая из базы при помощи .Net средств (SqlConnection и т.п.) - вытянет данные в DataSet, а дальше будет их выгружать в Microsoft CRM?
Теги |
c#, webservice |
Тема | Ответов | |||
RetrieveMultiple и сущности НЕдефаултной организации | 16 | |||
Быстродействие CrmService | 16 |
