#1 |
axinthefield: Currency Round-off and Maximum Penny Difference
Источник: http://blogs.msdn.com/b/axinthefield...ifference.aspx
============== Knowledge Base article 923022 explains when the penny difference account is used in Dynamics AX. I was recently asked how this works in connection with the maximum penny difference setting in GL Parameters. In this post, I have used the example provided in the mentioned article to illustrate how the two settings work together. When a foreign currency is used, each line in a given voucher is translated to the functional currency, and is rounded separately, according to the setup on the functional currency. ![]() Vouchers may have multiple debit and credit entries. With rounding in play, the voucher may become unbalanced. Here is an example: Functional currency = USD Transaction currency = CAD Exchange rate = 117.5 USD = 100 CAD ![]() Journal lines entered as follows: Transaction Amount CAD Amount USD Rounded amount (USD) Debit 55.00 64.625 64.63 Debit 45.00 52.875 52.88 Debit 55.00 64.625 64.63 Debit 45.00 52.875 52.88 Credit 200.00 235.00 235.00 TOTAL debits after rounding: 235.02 TOTAL credits after rounding: 235.00 DIFFERENCE: 0.02 Before AX will actually post this 2 cents to the ‘Penny Difference’ account, we do a check against the GL Parameter setting for ‘maximum penny difference’. For my first test on this journal, I set the maximum penny difference to 0.01. When I attempt to post the journal, I will receive an error: 'The transactions on voucher 00044_DAY do not balance as per 4/4/2011. (Company currency: -0.02 - secondary currency : 0.00)' If I change the maximum penny difference to 0.02, the journal posts since it is now within the maximum allowable penny difference: References: https://mbs.microsoft.com/knowledgeb...b;EN-US;923022 Источник: http://blogs.msdn.com/b/axinthefield...ifference.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
