#1 |
sumitsaxfactor: Replacing Financial Dimension in Ledger Dimension
Источник: http://sumitsaxfactor.wordpress.com/...ger-dimension/
============== Replacing a financial dimension in a Ledger dimension is not straight forward as the replacing of a dimension in Default dimensions. For default dimensions, we had a method serviceReplaceAttributeValue to replace one particular dimension. But for a ledger dimension, we need to do the following: X++: static void replaceLedgerDimensions(Args _args) { #LedgerSHA1Hash DimensionSHA1Hash hash; //To store the calculated hash for DimensionAttributeValueSet HashKey valueKeyHashArray[]; //To store the has key of dimension in question Map dimAttrIdx, dimAttrRecId; //to store the dimension index and backing entity type DimensionAttributeSetItem dimAttrSetItem; // Contains the number of dimensions active for a account structure ledger DimensionAttribute dimAttr; // Contains the financial dimensions records DimensionAttributeValue dimAttrValue; // Contains used financial dimension values DimensionAttributeValueSet dimAttrValueSet; //Contains default dimension records DimensionAttributeValueSetItem dimAttrValueSetItem; //Contains individual records for default dimensions DimAttributeHcmWorker dimAttrWorker; //Backing entity view for Employee type dimension DimensionEnumeration dimensionSetId; //Record id for table that contains active dimensions for current ledger LedgerDimensionAccount targetDimension = 5637145829; //Record Id DimensionAttributeValueCombination table in which attribute value is to be replaced LedgerDimensionAccount ledgerDimension; // To hold the resultant DimensionAttributeValueCombination record id LedgerDimensionAccount mainAccDimension; // Record id for LedgerDimension(DimensionAttributeValueCombination) containing default account for main account RecId DimensionStorage dimensionStorage; // Class Dimension storage is used to store and manipulate the values of combination DimensionStorageSegment segment; // Class DimensionStorageSegment will get specfic segments based on hierarchies int segmentCount, segmentIndex; int hierarchyCount, hierarchyIndex; SysDim segmentValue, mainAccountValue; int dimAttrCount, i; int emplBackEntityType; //Stores the backing entity type for Employee type dimension str valueStrArray[]; //To store the dimension attribute values int64 valueKeyArray[]; //To store the record ids of DimensionAtrributeValue table int backingEntityInstance; ; //The employee backing entity will be the view DimAttributeHcmWorker emplBackEntityType = tableNum(DimAttributeHcmWorker); //Initialize the map to store the backing entity types dimAttrIdx = new Map(Types::Integer, Types::Integer); dimAttrRecId = new Map(Types::Integer, Types::Int64); //Get the record Id (dimension set id) for current ledger to find active dimensions dimensionSetId = DimensionCache::getDimensionAttributeSetForLedger(); //Find all the active dimensions for current ledger except main account and store there //backing entity type in the map while select * from dimAttr order by Name where dimAttr.Type != DimensionAttributeType::MainAccount join RecId from dimAttrSetItem where dimAttrSetItem.DimensionAttribute == dimAttr.RecId && dimAttrSetItem.DimensionAttributeSet == dimensionSetId { dimAttrCount++; dimAttrIdx.insert(dimAttr.BackingEntityType, dimAttrCount); dimAttrRecId.insert(dimAttr.BackingEntityType, dimAttr.RecId); } //initialize hash key array to null for (i = 1; i<= dimAttrCount; i++) { valueKeyHashArray[i] = emptyGuid(); valueStrArray[i] = ; valueKeyArray[i] = 0; } // Default hash key array with required dimension value // Get dimension storage dimensionStorage = DimensionStorage::findById(targetDimension); if (dimensionStorage == null) { throw error("@SYS83964"); } // Get hierarchy count hierarchyCount = dimensionStorage.hierarchyCount(); //Loop through hierarchies to get individual segments for(hierarchyIndex = 1; hierarchyIndex <= hierarchyCount; hierarchyIndex++) { //Get segment count for hierarchy segmentCount = dimensionStorage.segmentCountForHierarchy(hierarchyIndex); //Loop through segments and display required values for (segmentIndex = 1; segmentIndex <= segmentCount; segmentIndex++) { // Get segment segment = dimensionStorage.getSegmentForHierarchy(hierarchyIndex, segmentIndex); // Get the segment information if (segment.parmDimensionAttributeValueId() != 0) { //Get the backing entity type; backingEntityInstance = DimensionAttribute::find(DimensionAttributeValue::find(segment.parmDimensionAttributeValueId()).DimensionAttribute).BackingEntityType; if (backingEntityInstance == tableNum(DimAttributeMainAccount)) mainAccountValue = segment.parmDisplayValue(); //Default the required arrays if (dimAttrIdx.exists(backingEntityInstance)) { i = dimAttrIdx.lookup(backingEntityInstance); valueKeyHashArray[i] = segment.parmHashKey(); valueKeyArray[i] = segment.parmDimensionAttributeValueId(); valueStrArray[i] = segment.parmDisplayValue(); } } } } //Find the Dimension attribute record for the dimension to work on, in our case it is HcmWorker dimAttr.clear(); dimAttr = DimensionAttribute::find(dimAttrRecId.lookup(emplBackEntityType)); //Get the backing entity type for the dimension value to process select firstOnly dimAttrWorker where dimAttrWorker.Value == "51011"; //Find the required Dimension Attribute Value record //Create if necessary dimAttrValue = DimensionAttributeValue::findByDimensionAttributeAndEntityInst(dimAttr.RecId, dimAttrWorker.RecId, false, true); //Replace the required combination hash keys and other value arrays i = dimAttrIdx.lookup(emplBackEntityType); valueKeyHashArray[i] = dimAttrValue.HashKey; valueStrArray[i] = dimAttrWorker.Value; valueKeyArray[i] = dimAttrValue.RecId; //Calculate the hash for the current values hash = DimensionAttributeValueSetStorage::getHashFromArray(valueKeyHashArray, dimAttrCount); //Null hash indicates no values exist, which may occur if the user entered an invalid value for one dimension attribute if (hash == conNull()) { throw error("Wrong value for Employee Dimension"); } // Search for existing value set dimAttrValueSet = DimensionAttributeValueSet::findByHash(hash); // This value set does not exist, so it must be persisted if (!dimAttrValueSet) { ttsbegin; // Insert the value set with appropriate hash dimAttrValueSet.Hash = hash; dimAttrValueSet.insert(); // Insert only specified set items use this for (i = 1; i <= dimAttrCount; i++) { if (valueKeyArray[i] != 0) { dimAttrValueSetItem.clear(); dimAttrValueSetItem.DimensionAttributeValueSet = dimAttrValueSet.RecId; dimAttrValueSetItem.DimensionAttributeValue = valueKeyArray[i]; dimAttrValueSetItem.DisplayValue = valueStrArray[i]; dimAttrValueSetItem.insert(); } } ttscommit; } // Get the default account for main account mainAccDimension = DimensionStorage::getDefaultAccountForMainAccountNum(mainAccountValue); //Find or create the LedgerDimension record for required combination ledgerDimension = DimensionDefaultingService::serviceCreateLedgerDimension( mainAccDimension, dimAttrValueSet.RecId); info(strFmt("Original %1: %2", targetDimension, DimensionAttributeValueCombination::find(targetDimension).DisplayValue)); info(strFmt("Replaced %1: %2", ledgerDimension, DimensionAttributeValueCombination::find(ledgerDimension).DisplayValue)); } ![]()
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось Poleax; 19.01.2012 в 13:32. |
