Старый 14.11.2012, 01:12   #1
ax_gfm_framework_team: The Microsoft Dynamics AX 2012 extension framework – Part 1
Источник: http://blogs.msdn.com/b/ax_gfm_frame...rk-part-1.aspx
Arthur Greef and Michael Gall.
Microsoft Dynamics AX 2012 includes a new extension framework that can be used to reduce coupling between application foundation frameworks and their extensions.
This is the first part in a series of blogs that describes the design of the extension framework and gives examples of where this framework is used in Microsoft Dynamics AX 2012.
A typical design pattern used to extend Microsoft Dynamics AX capability is found in the bill of material (BOM) consumption calculation design. There are four parts to the extension design. The first part of the design specifies a base enumeration for each of the calculation formulas.
Base enum
BOMFormula
Formula0
Formula1
The second part of the design specifies a base class and base class extensions.
AOT/Classes
class BOMCalcConsumption{}
class BOMCalcConsumption_Formula0 extends BOMCalcConsumption {}
class BOMCalcConsumption_Formula1 extends BOMCalcConsumption {}
The third part of the design specifies a static factory method on the base class that uses the value of a base enumeration parameter to instantiate a derived class.
client
server static BOMCalcConsumption construct(
BOMFormula formula, BOMCalcData calcData)
switch (formula)
case BOMFormula::Formula0:
return new BOMCalcConsump_Formula0(calcData);
case BOMFormula::Formula1:
return new BOMCalcConsump_Formula1(calcData);
In the preceding design example, the base class is tightly coupled to derived classes and needs to be modified each time that a new derived class is added to the application. In addition, a new enumeration must be added to the base enumeration. A less tightly coupled extension design that uses a class attribute and a class factory is now possible and has been used for product configuration adaptor extensions.
The extension framework uses the class attribute framework and class factory framework that is also new to Microsoft Dynamics AX 2012. These two frameworks are used to decouple base and derived classes in two steps.
1. Create a class attribute method by extending the SysAttribute class.
The following example is taken from the product configuration code in the Product information management module.
class PcAdaptorExtensionAttribute extends SysAttribute
PCName modelName;
public
void new(PCName _modelName)
super();
if (_modelName == '')
throw error(Error::missingParameter(this));
modelName = _modelName;
public PCName parmModelName(PCName _modelName = modelName)
return modelName;
2. Use the preceding class attribute to add metadata to a derived class.
For example, add the following code to extend the PCAdaptor class so that a MyPCAdaptor object is created instead of a PCAdaptor object when processing a product configuration that is created from a product configuration model named “Computers”.
[PCAdaptorExtensionAttribute('Computers')]
class MyPCAdaptor extends PCAdaptor
protected void new()
super();
You can test that this extension works by performing the following steps.
1. Open the Microsoft Dynamics AX development environment.
2. Add the MyPCAdaptor class to the Application Object Tree (AOT), and then compile the class.
3. Add a breakpoint in the PCAdaptorFactory.getAdaptorFromModelName method.
4. Open the Microsoft Dynamics AX client.
5. Click Product information management >Common >Product configuration models.
6. On the action pane, in the New group, click Product configuration model.
The New product configuration model dialog opens.
7. Enter “Computers” in the Name field.
8. Enter a name in the Root component section Name field, and then click OK.
The Constraint-based product configuration model details form opens.
9. Add an attribute to the root component in the Attributes section.
10. On the action pane, in the Run group, click Test.
11. Select a value for the attribute.
12. Click OK.
The Microsoft Dynamics AX debugger should launch at the breakpoint added in step 3 in the preceding step list.
As you step though the code you will see how the SysExtensionAppClassFactory is used to create an instance of the MyPCAdaptor class.
adaptor = SysExtensionAppClassFactory::getClassFromSysAttribute(classStr(PCAdaptor), extensionAttribute);
The getClassFromSysAttribute method works by searching through the classes that are derived from the PCAdaptor class until it finds a class that has a PCAdaptorExtensionAttribute that returns a product model name that matches the name of the product configuration model being tested. In this case, the name “Computers”.
The benefits of using this new extension model are that the base and derived classes are decoupled, and it takes less code to extend the capability of the Microsoft Dynamics AX application.
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 8 Blog bot Dynamics CRM: Blogs 1 30.04.2016 10:26
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Development Cookbook' Blog bot DAX Blogs 1 12.05.2012 16:55
dynamics-ax: Microsoft Highlights New ERP Public Sector Capabilities for AX 2012 Blog bot DAX Blogs 0 23.05.2011 19:11
Часовой пояс GMT +3, время: 14:50.
