Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 03.12.2012, 22:31   #1
pawan is offline
pawan
Need to get previous but one record from PO in ax 2009
Hi Everyone,
Firstly,There are two types of PO in PurchOrder.
1. P and 2.D
When you create a PO of type "D" you should create "P" PO after "D" PO(Alternatively)
Ex: 1. D1(First D) PO 2. D2(Second D) PO 3. P1(First P) PO
But My req. is i should filter all the "P" into my cutomized Table(say X_Test) and in the below fields i have to get below values as per example...
Fields:
1.P_PurchId(PO of type P from Purchtable)[ P1]
2.D_purchid(the value of this should be [D1] for P1 record )
Note: P & D PO have to be same InventsiteId...
Plz Help me out ...
Старый 04.12.2012, 01:09   #2
macklakov is offline
macklakov
Аватар для macklakov
2,298 / 977 (37) +++++++
Dear pawan,
It would be very nice of you to bother giving description of business needs you want to solve or at least asking a question. It would show some respect to you colleagues.
Sincerely yours,
macklakov
Старый 04.12.2012, 14:26   #3
pawan is offline
pawan
Сообщение от macklakov Посмотреть сообщение
Dear pawan,
Sincerely yours,
macklakov
Hi macklakov ,
Thanks for your advise macklakov...I will follow it from next time...I didnt get where i not show respect to ppl here...Anywaz noted your point...
_________________________________
We came here to solve technical issues,Not Arguing ...
Старый 06.12.2012, 03:13   #4
macklakov
Сообщение от pawan Посмотреть сообщение
Hi macklakov ,
I just humbly expressed my wish. If I was giving you advises it would be to read "Microsoft Dynamics AX 2009 Programming: Getting Started". And I would highly recommend the person who wrote the spec to attend "Trade and Logistics" training.
I can hardly believe there are any technical issues in your Accounts Payable module.
Старый 04.12.2012, 14:34   #5
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2156 (80) +++++++++
The point is that your intial message is not very "friendly". For thoses who are not in the middle of your solution of the issue, it's absolutely unclear what and for what you are doing.
Ivanhoe as is..
Старый 04.12.2012, 16:05   #6
I would suggest that you add a larger sample data set, so that we can better understand your problem statement.
Or at least confirm that my understanding of what you wrote is correct:
1. For any PO of type "P", there's exactly one corresponding PO of type "D", that is linked to it through the InventSiteId field on the PO table
2. There can be multiple POs of type "P" for the same "D" PO, so for example P1 linked to D1 and P2 linked to D1.
3. You want to create a query that would select all POs of type "P" and their respective "D" POs.
4. You want to do it with just 1 query.
My suggestion would be:
PO poP;
PO poD;
while select PurchId from poP
where poP.PurchaseType == "P"
join PurchID from poD
where poD.PurchaseType == "D"
&& poD.InventSiteId == poP.InventSiteId
info(strfmt("'P' PO: %1, 'D' PO: %2", poP.PurchId, poD.PurchId));
Старый 04.12.2012, 23:21   #7
pawan is offline
pawan
Dear kashperuk,
thanks for responding for my issue.
I will explain you the requirenment clearly below...
If we create "D1" PO with a +ve amount with a inventsiteid"123"
we should create "P1" with a -ve amount with same inventsiteid"123"
purchtable
Purchid enum(Drop/pick) timing for example inventsiteid
drop1 D day before yesterday 123
drop2 D yesterday 123
Pick1 P todays date n time 123
In my Cutomized Table:
N_Pick N_Drop inventsiteid
P1 D1 123
my req is to get D1 PO in the field of N_drop against P1 PO in the field N_pick
Please ask me if u need more info regarding this req...Hope you understand the issue..
Thanku
Старый 05.12.2012, 01:33   #8
lol, what an explanation.
in any case, try my query from above - it should work for you.
Старый 05.12.2012, 13:36   #9
pawan is offline
pawan
Sorry kashperuk,I just copied from excel to here to show you the exact req.
Please find Attachement of my task...
As per the Excel i need to get the PO0001 value against the PI0001 purchid...(last but one record value)...Plz help me out...
Thankyou...
Тип файла: xlsx TASK.xlsx (8.8 Кб, 62 просмотров)
Последний раз редактировалось pawan; 05.12.2012 в 14:07.
axforum blogs: Квест: Подружим Dynamics Ax 2009 Sp1 RU7 c SharePoint Foundation 2010 Blog bot DAX Blogs 4 16.10.2017 17:50
Sample Design Patterns: Upgrade to Microsoft Dynamics AX 2009 and issues with the global address book Blog bot DAX Blogs 0 21.12.2010 11:11
Часовой пояс GMT +3, время: 01:30.
