Старый 20.06.2009, 19:05   #1
Arijit Basu: Intelligent Data Management Framework for Microsoft Dynamics AX
Источник: http://daxguy.blogspot.com/2009/06/i...framework.html
The Intelligent Data Management Framework for Microsoft Dynamics® AX helps administrators optimize Dynamics AX database layout by intelligently monitoring index usage, index layout, fragmentation and query patterns thru indices. The framework allows reduction of the database size by purging transaction records from a set of related entities, while maintaining the consistency and integrity of production data. The Intelligent Data Management Framework provides customers and partners the ability to identify and discover related entities based on Microsoft Dynamics AX metadata and to determine the purging criteria for entities and transactions. The Intelligent Data Management Framework also analyzes the production database to determine current usage patterns and assesses the health of the Microsoft Dynamics AX application.
At RTM, this Framework will include “Archive to Offline” Instance Support.
Click here to download [ Requires Partnersource Access]
Старый 24.06.2009, 18:07   #2
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2156 (80) +++++++++
Кто-нибудь уже посмотрел? Судя по скриншотам и документации полезный и удобный инструмент.
Вот только требования к ОС не дают посмотреть
Operating system requirements
The Intelligent Data Management Framework is currently tested on the 32-bit version of the following operating systems.
Operating system
Microsoft Windows Server 2003 R2, Standard Edition
Windows Server 2003 R2, Enterprise Edition
Windows Server 2003 R2, Datacenter Edition
Windows Server 2003 with Service Pack 1, Standard Edition
Windows Server 2003 with Service Pack 1, Enterprise Edition
Windows Server 2003 with Service Pack 1, Datacenter Edition
Microsoft Windows Small Business Server 2003, Standard Edition
Windows Small Business Server 2003, Premium Edition
Windows Server 2008
Windows Vista SP1 or above
Ivanhoe as is..
Старый 25.06.2009, 00:31   #3
gl00mie is offline
gl00mie
3,684 / 5798 (201) ++++++++++
Это еще почему? Если идет на w2k3, то должно пойти и на wxp. Опять же, приведенный список - это то, на чем инструмент был протестирован, а не его требования к ОС.
Старый 25.06.2009, 10:25   #4
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Как раз таки требования. Запускаю установку на WinXP Pro - сразу выдает сообщение, что требуется WServer 2003 и программа закрывается!
Ivanhoe as is..
Старый 08.07.2009, 11:29   #5
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Подыму тему. Кто-нибудь уже попробовал инструмент?
Ivanhoe as is..
Старый 08.07.2009, 13:34   #6
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Установил, настроил, заработало По крайней мере, сама программка просмотра.
В документации не нашел описания выполнения task'ов: используется отдельный сервис. Если сервер после установки не перезапускался - нужно запустить вручную.
Неудобно, что нельзя удалить настроенный task
Наткнулся на ошибку: запуск task'а по созданию Analysis snapshot завершается с ошибкой:
Тип события: Ошибка
Источник события: SQLISPackage
Категория события: Отсутствует
Код события: 12550
Дата: 08.07.2009
Время: 13:17:17
Пользователь: хххххх
Компьютер: ууууууу
Описание:
Event Name: OnError
Message: Executing the query "Declare @count int
select @count = count(1) from dbo.STATS_COLLECTION_SUMMARY WHERE STATS_TIME < ?
if ( @count > 0)
Begin
SELECT TOP 1
STATS_TIME
FROM STATS_COLLECTION_SUMMARY WITH (NOLOCK)
ORDER BY STATS_TIME DESC
End
else
Begin
select cast(convert(varchar(25),'1900-01-01',21) as datetime)
End" failed with the following error: "Syntax error, permission violation, or other nonspecific error". Possible failure reasons: Problems with the query, "ResultSet" property not set correctly, parameters not set correctly, or connection not established correctly.
Operator: хххххххх
Source Name: InsIndexCaptureStats
Source ID: {67735AD4-197C-43A5-89FA-6462A225F8F6}
Execution ID: {FD2E5DAD-9DB3-4ABC-A2D6-5A17E89A6A98}
Start Time: 08.07.2009 13:17:17
End Time: 08.07.2009 13:17:17
Data Code: -1073548784
Дополнительные сведения можно найти в центре справки и поддержки, в "http://go.microsoft.com/fwlink/events.asp".
Будем копать дальше без выполнения этого task'а не посмотреть "красивые картинки" со скриншотов в первом сообщении .
Ivanhoe as is..
Старый 11.11.2009, 11:02   #7
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Пытаюсь поставить на Windows Server 2008 - пишет, что не найдена служба Micosoft Distributed Transaction Co-Ordinator (MSDTC).
Я так понимаю, это стандартная служба, она видна в Server Manager и запущена, но инсталлятор ее не видит. В чем может быть проблема?
Ivanhoe as is..
Старый 11.11.2009, 12:11   #8
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
В инструкции по установке, оказывается, все написано .
Ivanhoe as is..
Старый 11.11.2009, 12:41   #9
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,326 / 3556 (125) ++++++++++
А то, что написано там в Installation Guide - не то?
Microsoft Distributed Transaction Coordinator (DTC)
Version depends upon the operating system
For installation instructions for Windows Vista or Windows Server 2008, see the Enable Network DTC Access topic on TechNet.
For installation instructions for Windows Server 2003, see the How to enable network DTC access in Windows Server 2003 topic on TechNet.
PS... опоздал
За это сообщение автора поблагодарили: Ivanhoe (1).
Старый 11.11.2009, 13:11   #10
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
А вы только гайд читали, или пользуетесь программкой (может, можете рассказать про ее полезность / бесполезность?)
Ivanhoe as is..
Старый 11.11.2009, 13:31   #11
egorych is offline
egorych
Oracle
761 / 154 (7) ++++++
Зачем такое пихать в Аксапту? У нормального админа есть кучка (ну или набор) СПЕЦпрограмулек, которые делают то-же, только лучше и глыбже!
ИМХО - ненадо превращать ERP в систему алминистрирования серверов!
Старый 11.11.2009, 15:16   #12
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
Мне казалось, что всё немного не так, и это не превращение Аксапты в очередного монста, а наоборот - удобный инструмент для опытного админа, знающего в первую очередь Аксапту и ее БД, во вторую - всякие SQL-ые штуки. Вольный перевод первого поста:
Intelligent Data Management Framework for Microsoft Dynamics® AX помогает администраторам оптимизировать БД путем интеллектуального мониторинга использования индексов, "index layout", фрагментации и планов запросов с учетом индексов (?).
Система позволяет сократить размер БД "очищая" транзакционные записи от набора связанных сущностей, при этом сохраняя согласованность и целостность данных.
Система позволяет клиентам и партнерам выделить и проанализировать связанные сущности, основываясь на метаданных Приложения,
и определить критерии "очистки" сущностей и транзакций.
Система также анализирует рабочую БД для определения текущих "паттернов использования" и оценивает состояние ("здоровье") Dynamics AX.
От себя добавлю, судя по описанию:
- Можно анализировать используемые индексы;
- Можно смотреть "заполненность" таблиц (самое большое количество записей);
- Можно анализировать "захламленность" БД не очень нужными данными;
- Можно настроить "удаление в корзину" ненужных данных с возможностью восстановления / окончательного удаления.
Пока у меня не получилось ничего проанализировать - см. ошибки в предыдущих постах, сейчас делаю новую попытку установки на новом сервер. Посмотрим...
Миниатюры
Ivanhoe as is..
Старый 11.11.2009, 15:42   #13
sukhanchik
К сожалению не пользовался - я думал она только для 2009 и забыл про нее, а увидев Ваше сообщение и перечитав еще раз гайд - понял - что она подойдет и для 4.0. Испробую - отпишусь
Старый 18.11.2009, 01:20   #14
sukhanchik
Дошел до того же состояния - не выполнился Analysis snapshot. Правда так и не понял где можно найти расширенное состояние ошибки, однако жутко напряг интерфейс софтинки. Также у меня не выполнилось задание (task) Ledger period.
В общем - с ходу не получилось взять приступом диаграммки.
Поигрался с инструментом зависимых таблиц - типа от каких таблиц зависит InventTrans. Сложилось ощущение - что автор программульки - человек - который делал упор на красоте в ущерб функциональности и информативности возникающих ошибок. Так красиво выезжают диаграмки
Тулза конечно прикольная - но мне кажется, что SQL Management Studio от SQL Server 2008 c его монитором активности (кстати совершенно бесплатный софт) гораздо проще в плане первоначальной настройки. Если конечно смотреть только в плане индексов.
В общем - это как установка Reporting Services для SQL Server 2005 - тут не дыши, тут в реестре подправь, тут налево смотрим и т.д. Задумка конечно неплохая, но.. подождем - может у кого получится ее оживить - кто расскажет...
ax2009, ax3.0, ax4.0, idmf, intelligent data management, администрирование, архивирование, база данных, инструменты
Arijit Basu: Demo Data for Microsoft Dynamics AX 2009 Blog bot DAX Blogs 0 09.07.2008 02:10
Arijit Basu: Credit Card Import Transformation Sample for Expense Management in Microsoft Dynamics AX 5.0 Blog bot DAX Blogs 0 12.02.2008 15:10
Arijit Basu: PerformancePoint Server 2007 Tool: Data Import Wizard for Microsoft Dynamics AX Blog bot DAX Blogs 0 22.01.2008 21:33
Arijit Basu: Optimizing Data Upgrade for Microsoft Dynamics AX 4.0 and 4.0 Service Pack on Microsoft SQL Server Blog bot DAX Blogs 1 10.01.2008 12:06
Часовой пояс GMT +3, время: 16:58.
