Старый 22.11.2010, 14:11   #1
xplusplus: How to: prompt a dialog box or a modal window
Источник: http://xplusplus.info/index.php/how-...-modal-window/
In this post I will review the different types of dialog boxes that can be used within the AX system.
There are many scenarios where you want to prompt a message or dialog box to the user. That could be achieved within the box class in the AOT.
Here are some example of the common ones -
1. Inofrmation
Box::info(str _text,str _title);2. Warning
Box::warning(str _text,str _title);3. Critical stop
Box::stop(str _text,str _title);4. "Do not tell me again" check box
Box::infoOnce(str _heading,str _information,str owner);5. OK / Cancel dialog box
DialogButton diagBut;;diagBut = Box::yesNo(str _text,DialogButton _defaultButton,str _title);6. Yes to all dialog box
DialogButton diagBut;;diagBut = Box::yesAllNoAllCancel(str _text,DialogButton _defaultButton,str _title);
Summery
In the last two examples, the box method will return the name of the selected option button.
Then, you can use the variable diagBut to proceed with your operations:
if (diagBut == dialogbutton::Ok) { //do something }
xplusplus: How to read data from text (.txt) file with AsciiIo Blog bot DAX Blogs 0 22.11.2010 01:11
emeadaxsupport: How to run a form modal Blog bot DAX Blogs 0 14.12.2009 14:05
Dynamics AX FAQ: How to override the event methods on dialog controls? Blog bot DAX Blogs 0 23.04.2008 04:16
DynamicsTech: How to modify the behavior of dialog boxes to enable forms to appear in full-screen mode in Microsoft Dynamics AX Blog bot DAX Blogs 0 13.04.2007 12:10
window: число -> картинку, how? somebody DAX: Программирование 9 24.03.2004 12:34
Часовой пояс GMT +3, время: 18:59.
