Старый 14.05.2007, 18:00   #1
25,643 / 848 (80) +++++++
axcoder: Tabax v 0.3
Источник: http://axcoder.blogspot.com/2007/05/tabax-v-03.html
download (87k)
After the long period of beta stage, the new release of Tabax is out.
This release introduces several new features which will be very useful for developers and end-users
First of all, it works under version 4 of Dynamics Ax.
Second, it introduces the Tabax Plugin API which allows developers to increase functionality of Tabax sufficiently.
There is a plugin for Tabax (in the tabax archive) to integrate AxPath with your system: so, if you install this plugin, you can click on AxPath links in browsers and email clients and go to specific location in code or specific record in the database (thank to AndyD for this functionality).
Ivan Kashperuk has developed a great plugin named RecentWindows which I use heavily. If you close some window, it allows to reopen it quickly.
Also, Ivan added a very useful feature to Tabax: if You press the 'Edit current field' toolbar button, while holding Ctrl and Shift down, Tabax will open a table field or data method related to the currently selected form field.
I have added similar fuctionality to the 'cross referebces' buton - now You can press it while working with form, and you will see cross refereces for the fireld related to the active control.
There are also some minor bugfixes and enhancements in this release
axcoder: Tabax is one year old Blog bot DAX Blogs 0 03.10.2007 17:10
axcoder: Tabax 0.3.2 Blog bot DAX Blogs 0 07.08.2007 21:10
axcoder: Tabax 0.3 beta 3 Blog bot DAX Blogs 0 26.03.2007 18:20
axcoder: Tabax 0.2.15 -- fit mazimized windows Blog bot DAX Blogs 0 10.03.2007 01:36
axcoder: Tabax 0.2.14: View query of the active datasource Blog bot DAX Blogs 2 02.02.2007 12:10
Часовой пояс GMT +3, время: 19:58.
