Старый 17.01.2008, 15:40   #1
axcoder: Trace Parser small bug
Источник: http://axcoder.blogspot.com/2008/01/...small-bug.html
Trace Parser is a new tool for profiling Dynamics Ax code. Unlike profiler, which makes execution of the code about 30 times slower, TraceParser takes extremely low resources - 4% according to Alexey Eremenko blog)
But since it is in the "beta" stage, there are some problems with usability and stability.
For example, when I run the "trace summary" menu item on my trace I've got an exception. It seems (thanks to reflector) the cause is in SqlTimeBreakDown function in SQL server Trace Parser database.
When I add condition to exclude division by zero, it results in empty
grid instead of exception.
This is the fix:
if @SQLTime>0 <SPAN class="comment">--
axperf: Trace Parser Release Candidate 2 Blog bot DAX Blogs 0 25.11.2008 23:05
aEremenko: Trace Parser для Microsoft Dynamics AX Blog bot DAX Blogs 1 16.01.2008 19:26
Arijit Basu: Trace Parser (beta) tool for Microsoft Dynamics™ AX 4.0 Blog bot DAX Blogs 0 02.08.2007 22:00
Dynamics AX: Trace Parser (beta) tool for Microsoft Dynamics™ AX 4.0 Blog bot DAX Blogs 1 14.04.2007 04:32
Dynamics AX: Trace Parser (beta) tool for Microsoft Dynamics™ AX 4.0 Blog bot DAX Blogs 0 20.03.2007 14:40
Часовой пояс GMT +3, время: 01:46.
