Старый 05.07.2008, 06:33   #1
axperf: Debugging X++ Object Leaks
Источник: http://blogs.msdn.com/axperf/archive...ect-leaks.aspx
One of the most important aspects of writing managed code that interacts with AX through the Business Connector is cleaning up objects. Each AxaptaObject and AxaptaTable must have dispose called on it before going out of scope, or we’ll leak the object...(read more)
Старый 06.07.2008, 15:09   #2
axstart is offline
axstart
MVP
16 / 10 (1) +
I'm lost in this story. So general, there is no garbage collection for the .net client?
What happens to the basic software design rule that tells use: The object that creates an object should also delete it. In C++ ad c# it is possible with methods like finalize. Who can help me with my confusion in my head..........
MVP
Старый 07.07.2008, 12:35   #3
Maxim Gorbunov is offline
Maxim Gorbunov
2,483 / 646 (26) +++++++
The thing is that the garbage collector cleans up objects only when they go out of scope. Sometimes an object can stay in scope for quite a while holding its memory (especially if .net client stays logged in, logging out forces all object handles to be released). There's a good advice on how to avoid objects staying in scope for too long - always use the using statement.
Vincent: Debugging business logic in AX 2009 SSRS reports Blog bot DAX Blogs 0 29.11.2008 09:05
Dynamics AX: Map Object Sorting - a real issue Blog bot DAX Blogs 7 15.10.2008 12:02
axStart: A structure way off dealing with garbage collection & memory leaks with the Dynamics AX .net connector. Blog bot DAX Blogs 0 31.07.2008 22:05
SysDictCoder: 10 tips for debugging in Dynamics Ax Blog bot DAX Blogs 0 01.07.2007 22:05
Dynamics AX: .Net BC, C# - Working with AxaptaRecord Object Blog bot DAX Blogs 0 20.06.2007 23:13
Часовой пояс GMT +3, время: 15:25.
