Старый 17.12.2008, 12:05   #1
axaptapedia: Validate field values on form
Источник: http://www.axaptapedia.com/Validate_...values_on_form
Summary: Validating a field on a form
A nifty trick for comparing the "old" value against the "new" value using "obj.orig()" when validating a field on a form.
Example:
Change the behavior of the "Customer Group" on "CustTable" form.
Overwrite the method "validate" on the field "CustGroup" on the data source on "CustTable" form.
Original method:
public boolean validate()
    boolean ret;
    ret = super();
    return ret;
Change method:
    boolean ret;
    if(custTable.orig().CustGroup == '30') // Non changeable group.
        info('You cannot change this Customer group');
        ret = false;
    } else {
        ret = super();
    return ret;
Note: I've explained the general principle for validating a field against it's old value, however there are some issues with the data source not refreshing data set when changing the value back and forth.
axaptapedia: Tutorial Form MultiSelectCheckBox Blog bot DAX: База знаний и проекты 21 23.09.2010 14:16
DeniZone: Invoking a method on a field in a form's datasource Blog bot DAX Blogs 0 13.02.2009 14:05
axaptapedia: Packing date range values in queries Blog bot DAX Blogs 1 09.11.2007 13:10
axaptapedia: Tutorial Form Dynalink Blog bot DAX Blogs 0 22.08.2007 23:00
Часовой пояс GMT +3, время: 05:39.
