Старый 09.01.2009, 06:03   #1
Solutions Monkey: Getting Around Thread was being aborted error when creating EP site.
Источник: http://blogs.msdn.com/solutions/arch...g-ep-site.aspx
Wishing you all a Very Happy New Year!!!
When you are trying to create EP Site on a machine low in memory or processing power, some times you may get “Thread was being aborted.” Error. To avoid this error, you should increase the executiontimeout.
Change connection time-out properties in the web.config file
1. In a basic text editor such as Notepad, open the web.config file for example %SYSTEMDRIVE%\Inetpub\wwwroot
-or-
%SYSTEMDRIVE%\\Inetpub\wwwroot\wss\VirtualDirectories\80 folder
1. Press CTRL + F to open the Find dialog box.
2. Find the following tag:
3. Replace it with this tag:
4. Find the following tag (you might have to search from the beginning of the file):
5. Add the following tags on new lines after the tag:
6. Find the following tag:
7. Add the following tags on new lines after the tag:
8. Save your changes, and close the web.config file.
9. At the command prompt, type iisreset, and then press ENTER.
10. Try to create the top-level Web site in SharePoint Portal Administration.
Solutions Monkey: Integrating EP Web Parts to non-EP SharePoint sites Blog bot DAX Blogs 0 04.04.2009 03:19
Solutions Monkey: w3wp crash while installing EP or creating EP site Blog bot DAX Blogs 0 07.02.2009 08:13
Solutions Monkey: Deploying Ax 2009 SP1 EP Blog bot DAX Blogs 0 05.02.2009 07:08
Solutions Monkey: EP SSL ( https) Setup Blog bot DAX Blogs 0 23.10.2008 12:05
Solutions Monkey: EP Site Templates not appearing under "Custom Tab" in WSS 3.0/MOSS 2007 Blog bot DAX Blogs 0 14.06.2007 03:52
Часовой пояс GMT +3, время: 05:24.
