Старый 16.01.2009, 18:05   #1
msdynamicsax: How to get the current call stack in X++
Источник: http://msdynamicsax.wordpress.com/20...ll-stack-in-x/
A neat feature in X++ is the ability to get the current call stack.
You do this by writing the following anywhere in the code:
xSession:: xppCallStack(); // without the space between : and x It’s there just because when I type them together in WordPress, this is what I get
The method returns a container, but you can offcourse convert it to a string by using the con2str() method and search for a specific method or class by using the strscan() method.
This way, you can separate the code depending on how it has been initiated.
AIFFault class AX2009 get all errors back in webservice call axstart DAX in English 0 28.01.2009 19:02
Malaysia: How to get the PC Name and IP Blog bot DAX Blogs 5 22.01.2008 16:26
Ruslan Goncharov: How to get the screenshots of all open windows in AX Blog bot DAX Blogs 0 12.01.2008 12:31
Ruslan Goncharov: How to get list of all open windows and their names in AX Blog bot DAX Blogs 0 29.12.2007 19:50
dynamicsusers: How to get a good picture on someone else's developments Blog bot DAX Blogs 1 04.05.2007 09:15
Часовой пояс GMT +3, время: 09:44.
