Старый 17.12.2009, 20:05   #1
hariprasadp: Import Excel file data in to dynamics AX through Dynamics AX
Источник: http://hariprasadp.spaces.live.com/B...B91F!208.entry
//--HariPattela--Dynamics AX import table data form Excel to AX table
static void ExcelFile_Import(Args _args)
    int i;
    //Excel related declarations
    #excel
    SysExcelApplication SysExcelApplication;
    SysExcelWorksheet SysExcelWorksheet;
    SysExcelWorksheets SysExcelWorksheets;
    SysExcelWorkbooks SysExcelWorkbooks;
    SysExcelWorkbook SysExcelWorkbook;
    SysExcelRange SysExcelRange;
    SysExcelCell SysExcelCell;
    SysExcelCells SysExcelCells;
    SysExcelRange range;
    COMVariant file;
    //progress bar
    #avifiles
    SysOperationProgress simpleProgress;
    //variables used while importing data
    int j, imported,  noofrows, firstrow;
    real ratio;
    str strExample;
    int intExample;
    //check if file has been selected
    //open the selected excel
    try{
        sysExcelApplication = SysExcelApplication::construct();
        sysExcelApplication.visible(false);
        sysExcelWorkbooks = sysExcelApplication.workbooks();
        file = new COMVariant();
        file.bStr('C:/fg.xls');
        sysExcelWorkbook = sysExcelWorkbooks.add(file);
        SysExcelWorksheets = sysExcelWorkbook.worksheets();
        SysExcelWorksheet = SysExcelWorksheets.itemFromNum(1);
    catch(Exception::Error)
         throw error("cannot open the excel file");
    try
        SysExcelRange = SysExcelWorksheet.cells().range(#ExcelDataRange);
        //Get the number of rows in excel file
        range = SysExcelRange.find("*", null, #xlFormulas, #xlWhole,
                                    #xlByRows, #xlPrevious);
        if(range)
            noofrows = range.row();
        else
            sysExcelApplication.workbooks().close();
            sysExcelApplication.quit();
            throw error('fg.xls');
        //Get the number of columns in excel file
                                    #xlByColumns, #xlPrevious);
        if(range)
            throw error('C:/fg.xls');
       throw error("Hata!");
    sysExcelCells = sysExcelWorksheet.cells();
    //initialize the progress bar
    ratio = noofrows / 100;
    simpleProgress = SysOperationProgress::newGeneral(#aviUpdate, 'file is importing', 100);
    //importing part
    //Chck currency
    ttsbegin;
    //read rows of excel
    for(j=3; j<=noofrows; j++)
            imported++;
        print(imported);
        strExample           = sysExcelCells.item(j, 1).value().bStr();
        intExample           = sysExcelCells.item(j, 4).value().double();
    pause;
    ttscommit;
    //display info
    info(int2str(imported) + " records imported.");
    //close the excel file
За это сообщение автора поблагодарили: Gustav (0).
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Часовой пояс GMT +3, время: 10:21.
