Старый 05.02.2010, 15:05   #1
25,643 / 848 (80) +++++++
palleagermark: Datasource names on Data Sets used for custom lookups on Enterprise Portal
Источник: http://palleagermark.blogspot.com/20...-used-for.html
When creating lookups based on a User Control in the AOT, it seems required that you, in the query of the dataset, make sure the datesource name and table name is exactly the same for each datasource.
Normally you would be able to name the datasource differently from the table it represents, but the EP frameworks can't figure this out when you apply custom filters from the webpage.
It fails when applying the filter, being unable to update the query on the dataset.
palleagermark: Important limitation in Enterprise Portal deployment Blog bot DAX Blogs 0 28.01.2010 15:05
palleagermark: AX 2009 Enterprise Portal Development Cookbook Blog bot DAX Blogs 0 06.01.2010 22:05
palleagermark: Data Set lookups on Enterprise Portal (EP) Blog bot DAX Blogs 0 20.12.2009 11:06
Solutions Monkey: Enterprise Portal Screencasts at Channel9.msdn.com Blog bot DAX Blogs 6 01.07.2008 19:38
jinx: Microsoft Dynamics AX 2009 Enterprise Portal Entwicklung Samples Blog bot DAX auf Deutsch 0 27.06.2008 04:06
Часовой пояс GMT +3, время: 06:47.
