Старый 28.07.2010, 18:05   #1
kamalblogs: Finding if a node is existing in lower layers Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2010...s-dynamics-ax/
Sometime when we were automating our form documentation methodology I had one particular requirement. I had to find if a component exists in the lower layer(Below BUS layer in our case). I tried searching for a way in the standard Ax to figure out. But i was unsuccessful, so at the end I wrote myself a small piece of code that will indicate if a component exists in the lower layer.
Here it goes
UtilEntryLevel getHighestBelowCurLayer(TreeNode _treeNode){ UtilEntryLevel layer, highestLayer; ; for (layer=UtilEntryLevel::sys; layer < UtilEntryLevel::bus; layer++) { if (SysTreeNode::isNodeInLayer(_treeNode, layer)) { highestLayer = layer; break; } } return highestLayer;}
kamalblogs: Storing and retrieving an XML in Resource node in Dynamics Ax Blog bot DAX Blogs 0 23.05.2010 02:12
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 04:35.
