Старый 07.07.2011, 22:12   #1
emeadaxsupport: AxUpdatePortal does not update Enterprise Portal
Источник: http://blogs.msdn.com/b/emeadaxsuppo...se-portal.aspx
Lately I have seen the issue when we run AxUpdatePortal (AxUpdatePortal.exe -updatewebsites -verbose -iisreset) , the process is reading following registry keys:
SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\14.0
SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0
Then AXUpdatePortal is doing IISReset and report Success. You are unable to see that web parts, proxies are deployed or page being upgraded. After successful running on AxUpdatePortal the page is simply not updated.
The reason behind is that user running AxUpdatePortal does not have correct rights for SharePoint, this is why nothing is happening.
To verify your rights please follow: http://blogs.msdn.com/b/axsupport/archive/2011/05/31/permissions-needed-to-run-axupdateportal-exe.aspx
--author:Czesława Langowska--editor:Czesława Langowska--date:7/July/2011
emeadaxsupport: Kerberos authentication does not work when Enterprise Portal uses a non-standard port Blog bot DAX Blogs 0 14.02.2011 21:11
emeadaxsupport: Unable to deploy AX 2009 Enterprise Portal on SharePoint 2010 even after patching setup files with hotfix 2278963 Blog bot DAX Blogs 0 08.12.2010 03:14
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
emeadaxsupport: How to manually deploy ODC Files to Microsoft Dynamics AX 2009 Enterprise Portal Blog bot DAX Blogs 0 17.02.2010 21:07
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 23:13.
