Старый 19.03.2012, 18:11   #1
workflowax: Adding code templates/shortcuts in AX 2012
Источник: http://workflowax.wordpress.com/2012/03/19/527/
If you’ve got any blocks of code that you use frequently, e.g. specific comment blocks, you can very easily add code short cuts in AX 2012 to auto-insert the them in to your X++ code.
For example you can setup AX to automatically create surrounding comment such as
whenever you type “mycom” and press the tab key.
How do you accomplish this. Very easily!
Step1: Locate the class EditorScripts in the AOT.
Step2: Create a new method with the format public void template_flow_[shortcut](Editor editor)
Step3: User the editor parameter to add code the code that you would like inserted. e.g. editor.insertLines(“\\test comment”);
Step4: Add your method to the case statement in the isApplicableMethod method in the section relating to template “editor scripts that does not apply to Macros”
Thats it, now if you type your shortcut into any editor in AX and press tab, the “\\test comment” code will be inserted.
Here’s a full example method
The above creates the following output:
workflowax: Code upgrade whitepapers for AX 2012 Blog bot DAX Blogs 0 24.02.2012 01:11
workflowax: Workflow Session at Dynamics AX 2012 Technical Conference Blog bot DAX Blogs 0 08.02.2011 18:11
Часовой пояс GMT +3, время: 09:40.
