#1 |
axforum blogs: Копировать права доступа на БД из вкладки Securables (SQL Server)
Источник: http://axforum.info/forums/blog.php?b=359
============== После восстановления БД Ax , AOS не подключается к БД. У БД другой логин, не такой под которым стартует AOS. Ошибка: Цитата: The Microsoft Dynamics AX Object Server 6.2$01-MicrosoftDynamicsAX2012R2 service terminated unexpectedly. It has done this 2 time(s). Windows detected your registry file is still in use by other applications or services. The file will be unloaded now. The applications or services that hold your registry file may not function properly afterwards. DETAIL - 2 user registry handles leaked from \Registry\User\S-1-5-21-3493872076-3631449775-1555872641-12685: Process 5144 (\Device\HarddiskVolume2\Windows\System32\WerFault.exe) has opened key \REGISTRY\USER\S-1-5-21-3493872076-3631449775-1555872641-12685 Process 5144 (\Device\HarddiskVolume2\Windows\System32\WerFault.exe) has opened key \REGISTRY\USER\S-1-5-21-3493872076-3631449775-1555872641-12685\Control Panel\International Faulting application name: Ax32Serv.exe, version: 6.2.158.0, time stamp: 0x50a65c76 Faulting module name: Ax32Serv.exe, version: 6.2.158.0, time stamp: 0x50a65c76 Exception code: 0xc0000005 Fault offset: 0x0000000000667fbc Faulting process id: 0x804 Faulting application start time: 0x01cdd43caa5d6aab Faulting application path: C:\Program Files\Microsoft Dynamics AX\60\Server\MicrosoftDynamicsAX2012R2\Bin\Ax32Serv.exe Faulting module path: C:\Program Files\Microsoft Dynamics AX\60\Server\MicrosoftDynamicsAX2012R2\Bin\Ax32Serv.exe Report Id: e88ab5b8-402f-11e2-bd5e-0050568c0067 Object Server 01: The database reported (session 1 (-AOS-)): [Microsoft][SQL Server Native Client 10.0][SQL Server]The EXECUTE permission was denied on the object 'XU_GetSchemaVersion', database 'MicrosoftDynamicsAX_model', schema 'dbo'.. The SQL statement was: "{ ? = CALL [MicrosoftDynamicsAX_model].[dbo].[XU_GetSchemaVersion](?, ?) }" Надо перенести настройки от OldUser --> NewUser http://social.msdn.microsoft.com/For...9-530a73a0814d http://vyaskn.tripod.com/scripting_p...erver_2005.htm PHP код: SET NOCOUNT ON DECLARE @OldUser sysname, @NewUser sysname SET @OldUser = 'HRUser' SET @NewUser = 'PersonnelAdmin' SELECT 'USE' + SPACE(1) + QUOTENAME(DB_NAME()) AS '--Database Context' SELECT '--Cloning permissions from' + SPACE(1) + QUOTENAME(@OldUser) + SPACE(1) + 'to' + SPACE(1) + QUOTENAME(@NewUser) AS '--Comment' SELECT 'EXEC sp_addrolemember @rolename =' + SPACE(1) + QUOTENAME(USER_NAME(rm.role_principal_id), '''') + ', @membername =' + SPACE(1) + QUOTENAME(@NewUser, '''') AS '--Role Memberships' FROM sys.database_role_members AS rm WHERE USER_NAME(rm.member_principal_id) = @OldUser ORDER BY rm.role_principal_id ASC SELECT CASE WHEN perm.state 'W' THEN perm.state_desc ELSE 'GRANT' END + SPACE(1) + perm.permission_name + SPACE(1) + 'ON ' + QUOTENAME(USER_NAME(obj.schema_id)) + '.' + QUOTENAME(obj.name) + CASE WHEN cl.column_id IS NULL THEN SPACE(0) ELSE '(' + QUOTENAME(cl.name) + ')' END + SPACE(1) + 'TO' + SPACE(1) + QUOTENAME(@NewUser) COLLATE database_default + CASE WHEN perm.state 'W' THEN SPACE(0) ELSE SPACE(1) + 'WITH GRANT OPTION' END AS '--Object Level Permissions' FROM sys.database_permissions AS perm INNER JOIN sys.objects AS obj ON perm.major_id = obj.[object_id] INNER JOIN sys.database_principals AS usr ON perm.grantee_principal_id = usr.principal_id LEFT JOIN sys.columns AS cl ON cl.column_id = perm.minor_id AND cl.[object_id] = perm.major_id WHERE usr.name = @OldUser ORDER BY perm.permission_name ASC, perm.state_desc ASC SELECT CASE WHEN perm.state 'W' THEN perm.state_desc ELSE 'GRANT' END + SPACE(1) + perm.permission_name + SPACE(1) + SPACE(1) + 'TO' + SPACE(1) + QUOTENAME(@NewUser) COLLATE database_default + CASE WHEN perm.state 'W' THEN SPACE(0) ELSE SPACE(1) + 'WITH GRANT OPTION' END AS '--Database Level Permissions' FROM sys.database_permissions AS perm INNER JOIN sys.database_principals AS usr ON perm.grantee_principal_id = usr.principal_id WHERE usr.name = @OldUser AND perm.major_id = 0 ORDER BY perm.permission_name ASC, perm.state_desc ASC Источник: http://axforum.info/forums/blog.php?b=359
