Старый 07.02.2011, 22:06   #1
25,531 / 847 (80) +++++++
pFinally I#39;m finished with this new update of the list of quot;Platform Updatesquot;. I#39;m starting to be convinced that I#39;m doing a necessary job here .. OH - MY - GOD! It#39;s not only A LOT, but it#39;s only getting more and more complicated. Lately, because Microsoft is trying to consolidate the R2 release with th SP1 release of NAV 2009 (and you remember my a href="http://dynamicsuser.net/blogs/waldo/archive/2011/01/14/dynamics-nav-2009-r2-is-not-a-quot-normal-quot-release-beware.aspx"quot;not normalquot; post/a, right?). /ppLet me try to explain: /ppa href="http://dynamicsuser.net/blogs/waldo/archive/2011/01/14/dynamics-nav-2009-r2-is-not-a-quot-normal-quot-release-beware.aspx"As mentioned/a, NAV 2009 R2 isn#39;t really a release like an SP1. In fact, it#39;s less then that. Functionally, it#39;s the same as SP1, just with a few world-wide additions. It#39;s only these additions they built into the SP1 environment like we knew it (and which lacks e.g. the VAT 2010 updates and other hotfixes .. ). You are intended to take these two databases, and built your own quot;newquot; R2 environment, with the necessary updates. /ppBut anyway, that#39;s old news, you all shouldn#39;t be quot;surprisedquot; about that (inside joke.. ;deg ). /ppstrongSo, more complicated, you said?/strong /ppAlso for the platform updates, they try to do as much as possible with as less effort as possible (can i BE more positive? :-) ). So they consolidate their platform updates, with this understanding: /pp style="margin-left:27pt;"strongemIn order to install hotfixes with build 32074 and higher, customers who have Microsoft Dynamics NAV 2009 SP1 with a build below 32074 installed, must first perform one of the following steps:/em/strong /pul style="margin-left:54pt;"listrongemInstall hotfix 2496107 ndash; Platform hotfix resource files for Microsoft Dynamics NAV 2009 SP1./em/strongspan style="font-family:Times New Roman;font-size:12pt;" /span/lilistrongemPerform a solution upgrade to Microsoft Dynamics NAV 2009 R2/em/strong /li/ulpNotice anything in particular? Indeed: the platform update for SP1 as well as the release of R2 are build 32012, while they state that anything higher then 32074 would need the above steps. There wouldn#39;t be a problem when there wasn#39;t an update between 32012 and 32074, would there? /ppSorry folks, there are KB-articles a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2483349"2483349/a and a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2483340"2483340/a, which are build 32029. What to do with them? I asked this question to Microsoft and here is the answer: Any hotfixes in between these two builds can be implemented as before, and after build 32074, you have to do one of the steps above. Luckily, they indicate this in the quot;prerequisitesquot;-part of the hotfix, although they don#39;t indicate it in the title of the hotfix (notice the referral to SP1 there...). /ppSo, to make it understandable to you, I will include in my list below the stuff you need. I indicated the platform update as quot;update 1quot; (being the first real quot;updatequot, which indicates that this step is for update 1.1 and 1.2... . I copied the hotfix to the R2-table, so you have it there as well, and you don#39;t have to look at the prerequisites.. . So in a way, my job got more complex, and yours is just the same (if you trust my list at least ;deg ). /ppHere#39;s the list: /ppnbsp; nbsp;/pdivtable border="0" style="border-collapse:collapse;"colgroupcol style="width:103px;"/colcol style="width:93px;"/colcol style="width:73px;"/colcol style="width:90px;"/colcol style="width:278px;"/col/colgrouptbody valign="top"trtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongVersion/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongUpdate/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongBuild No./strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongKB number/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongInfo/strong/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/partnersource/support/selfsupport/productreleases/microsoftdynamicsnav2009r2.htm"span style="background-color:yellow;"emNAV2009 R2/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emnbsp;/em/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em32012/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emnbsp;/em/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 0.1/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em32074/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb$en-us$2481169amp;wa=wsignin1.0"span style="background-color:yellow;"em2481169/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;background-color:yellow;"emquot;ComplexType is neither recognized as a GUID nor as the name of an Automation serverquot; error message when you try to import an object that has an Automation type variable into Microsoft Dynamics NAV 2009 Service Pack 1/em/span/p/td/tr/tbody/table/divpstrongSome interesting version-specific links:/strong /pullidiva href="https://mbs.microsoft.com/Cms/Templates/site/UtilityPlus.aspx?NRMODE=Publishedamp;NRNODEGUID=%7bF160D35A-A76A-4B68-8E47-1F017C652985%7damp;NRORIGINALURL=/partnersource/marketing/campaigns/prospect/launchmdnavamp;NRCACHEHINT=Guestamp;wa=wsignin1.0"span style="background-color:yellow;"strongemPartner Launch Portal/em/strong/span/aspan style="background-color:yellow;"strongem: you can find all information about the product there:/em/strong/spanspan style="font-family:Times New Roman;font-size:12pt;" /span/divullispan style="background-color:yellow;"strongemNews/em/strong/span /lilispan style="background-color:yellow;"strongemReadiness and Training/em/strong/span /lilispan style="background-color:yellow;"strongemMarketing Material/em/strong/span /li/ul/lilidiva href="https://mbs.microsoft.com/partnersource/support/selfsupport/taxupdates/MSDNAVIsabel6SEPA_Belgium"span style="background-color:yellow;"emNAV 2009 SP1 Support for strongISABEL6/strong and strongSEPA Credit Transfer/strong - strongBelgium/strong/em/span/a /divpnbsp; nbsp;/p/li/uldivtable border="0" style="border-collapse:collapse;"colgroupcol style="width:638px;"/col/colgrouptbody valign="top"trtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"strongemNotes:/em/strong/span /pullidivspan style="background-color:yellow;"strongemVAT 2010 and other hotfixes or updates that were released for NAV 2009 SP1 are NOT part of NAV 2009 R2. R2 is in fact a SP1 database, with the extra functionality for R2 built in. So SP1 objects were only changed for:/em/strong/spanspan style="font-family:Times New Roman;font-size:12pt;" /span/divullispan style="background-color:yellow;"strongemOnline Services for Microsoft Dynamics ERP (US)/em/strong/span /lilispan style="background-color:yellow;"strongemCRM Integration/em/strong/span /lilispan style="background-color:yellow;"strongemSystem Indicator/em/strong/span /li/ul/lilispan style="background-color:yellow;"strongemAdvice: read the a href="http://msdn.microsoft.com/en-us/library/gg502497.aspx"upgrade instructions/a carefully./em/strong/span /li/ulpspan style="font-size:8pt;background-color:yellow;"emMore info a href="http://dynamicsuser.net/blogs/waldo/archive/2011/01/14/dynamics-nav-2009-r2-is-not-a-quot-normal-quot-release-beware.aspx"here/a./em/span/p/td/tr/tbody/table/divp style="margin-left:27pt;"nbsp; nbsp;/pdivtable border="0" style="border-collapse:collapse;"colgroupcol style="width:90px;"/colcol style="width:79px;"/colcol style="width:75px;"/colcol style="width:68px;"/colcol style="width:325px;"/col/colgrouptbody valign="top"trtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/Cms/Templates/document/General.aspx?NRMODE=Publishedamp;NRNODEGUID=%7b5EA33D79-4292-48CA-935A-CB582FEACDB8%7damp;NRORIGINALURL=/partnersource/downloads/servicepack/MicrosoftDynamicsNAV2009SP1.htmlamp;NRCACHEHINT=Guestamp;wa=wsignin1.0"NAV 2009 SP1/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29626/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"nbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/customersource/downloads/servicepacks/microsoftdynamicsnav2009SP1.htm"This link for Customers./a/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.1/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29958/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;974980"974980/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The import of the translations fails when you export and translate report objects in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.2/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29958/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;975339"975339/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You cannot synchronize meetings and tasks as expected between Microsoft Dynamics NAV 2009 Service Pack 1 and Microsoft Office Outlook/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.3/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29958/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;975655"975655/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The quot;ISTEMPORARYquot; property of a RecordRef variable becomes incorrect in certain cases in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.4/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29958/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;976028"976028/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 Service Pack 1 development environment becomes unstable when the object cache is set to zero/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.5/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29958/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;976076"976076/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 Service Pack 1 classic client crashes when you receive a Microsoft SQL Server error message in a synchronization process/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.6/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29958/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;976273"976273/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The result set is incorrect when you apply a filter on a form in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.7/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29958/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977219"977219/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The subform part of a dialog box is always noneditable if you use the Editable property for the subform of the dialog box in Microsoft Dynamics NAV 2009 with Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.8/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29987/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977063"977063/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Microsoft Dynamics NAV 2009 Service Pack 1 crashes when you run a codeunit to call the quot;RecRef.GETTABLEquot; method and the quot;RecRef.FIELDquot; method/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.9/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29994/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;976611"976611/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You experience slow performance in pages after you run a report in the Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.10/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30037/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;976994"976994/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The spaces in a fixed-length file are unexpectedly truncated when you run the XMLPort import in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.11/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30037/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;976646"976646/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"A report is always printed in portrait orientation even though you set the Orientation property of the report to Landscape in Microsoft Dynamics NAV 2009 with Service Pack 1 installed/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.12/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30045/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;976543"976543/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The GET function disallows you to handle an error when you run the function on an uninitialized RecordID value in Microsoft Dynamics NAV 2009 with Service Pack 1 installed/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.13/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30045/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;976810"976810/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You cannot access the files that are located on a share from the Microsoft Dynamics NAV 2009 Service Pack 1 server/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.14/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30045/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;976914"976914/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you convert a database to Microsoft Dynamics NAV 2009 Service Pack 1: quot;CREATE USER [] FOR LOGIN []quot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.15/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30065/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;975298"975298/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You cannot see any processing indication when you save the data in the Gantt component in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.16/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30069/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977294"977294/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you close the Microsoft Dynamics NAV 2009 Classic Client with SP1 installed: quot;Date is not validquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.17/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30101/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;976254"976254/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The records in a table are displayed as quot;#Name?quot; when you create a linked table in Microsoft Access by using the Microsoft Dynamics NAVnbsp;N/ODBC-connection data source/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.18/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30212/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977447"977447/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 server crashes sporadically/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.19/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30212/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977121"977121/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You experience various issues when you upgrade Microsoft Dynamics NAV to Microsoft Dynamics NAV 2009 or Microsoft Dynamics NAV 2009 SP1 after you specify a value for the CaptionClass property of a field in a system table/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.20/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30212/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977393"977393/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Two errors are logged in the Application log when you restart the Microsoft Dynamics NAV Server service in Microsoft Dynamics NAV 2009 with Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.21/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30212/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977455"977455/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The user sessions remain active on a Microsoft SQL Server server when the Microsoft Dynamics NAV 2009 Role Tailored Client (RTC) crashes/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.22/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30212/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977575"977575/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The GETRECORD function returns different results on the Classic Client of Microsoft Dynamics NAV 2009 SP1 and on the Role Tailored Client in Microsoft Dynamics NAV 2009 SP1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.23/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30212/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977604"977604/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You experience slow performance when you perform any actions after you print a report in the Role Tailored Client in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.24/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30212/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977602"977602/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Only the company that you previously log on to is displayed when you use company-specific roles in the Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.25/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30212/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;976930"976930/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You experience slow performance when you open or resize pages after you print or preview a report in the Role Tailored Client in Microsoft Dynamics NAV 2009 with Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.26/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30212/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977218"977218/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 Service Pack 1 client crashes when you run the FORM.RUNMODAL statement together with the COMMIT statement/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.27/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30212/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977597"977597/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you import an XML file by using an XML port in Microsoft Dynamics NAV 2009 Service Pack 1: quot;DTD is prohibitedquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.28/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30232/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977533"977533/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Role Tailored Client (RTC) crashes when you run an Automation object in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.29/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30232/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;948302"948302/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The NAS stops responding to events when a lock time-out occurs in Microsoft Dynamics NAV/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.30/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30326/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978426"978426/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Some records in a table are displayed as quot;#Deletedquot; when you create the linked table in Microsoft Access by using the Microsoft Dynamics NAV 2009 N/ODBC-connection data sourcenbsp;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.31/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30357/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978484"978484/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The cursor jumps incorrectly between fields on pages in the Role Tailored Client in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.32/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30473/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;979422"979422/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"quot;This message is for C/AL programmers: The call to member Send failed: The system cannot find the file specifiedquot; error message when you send a document to a server that is running Microsoft BizTalk Server from the Microsoft Dynamics NAV 2009 RTC client/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.33/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30480/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978422"978422/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Microsoft Dynamics NAV 2009 does not export the Page-type object when you run the Cfront code that invokes the ExportFob method/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.34/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30502/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;979428"979428/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"A hotfix is available to develop and deploy an unsupported language for Microsoft Dynamics NAV 2009 SP1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.35/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30522/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;979700"979700/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 Service Pack 1 server service does not release memory after you run the SaveAsPDF function when you run a report or a codeunit/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.36/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30548/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;979795"979795/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 RoleTailored client (RTC) crashes when the terminal server uses temporary profiles/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.37/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30553/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977064"977064/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"A RecordID field cannot be used on a page in Microsoft Dynamics NAV 2009 SP1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.38/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30596/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;980491"980491/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 RoleTailored client (RTC) crashes when you try to filter on a field whose CaptionClass property is set to a formula/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.39/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30596/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;980640https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;980640"980640/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The filter does not work as expected when you press TAB to leave a filter field in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.40/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978100"978100/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you add a field to a table in Microsoft Dynamics NAV 2009 SP1: quot;You can only specify the READPAST lock in the READ COMMITTED or REPEATABLE READ isolation levelsquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.41/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978492"978492/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you print a classic report in the RoleTailored client (RTC) in Microsoft Dynamics NAV 2009 Service Pack 1: quot;The date is not validquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.42/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978033"978033/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Microsoft Dynamics NAV 2009 Service Pack 1 unexpectedly shows 0 in flow field column in pages even though the amounts in the flow field column are not 0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.43/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978488"978488/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You experience an increase of memory consumption when you run an application that calls a function in the Web Service codeunit in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.44/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977606"977606/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you perform a data conversion in Microsoft Dynamics NAV 2009 SP1: quot;The call to member [Method_member] failedquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.45/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978942"978942/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The data type of a field in a page becomes incorrect when you publish the page to a Web service in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.46/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978537"978537/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You experience slow performance after you print a report in the Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.47/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978290"978290/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you try to compile an object in Microsoft Dynamics NAV 2009 Service Pack 1: quot;The Type ndash;[Number] was not defined for the functionquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.48/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978298"978298/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 classic client crashes when you try to compile an object directly from the Object Designer window/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.49/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978343"978343/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009 does not use the primary language when a caption is not translated to the current language/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.50/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978457"978457/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you start the RoleTailored client from a terminal server or from a Citrix server in Microsoft Dynamics NAV 2009 SP1: quot;The time zone with the ID #39;Mitteleuropauml;ische Zeit#39; was not recognized on the serverquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.51/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977217"977217/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The records in the table in an active company are unexpectedly deleted when you run the Table.CHANGECOMPANY code and then run the Table.DELETEALL(TRUE) code from a page in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.52/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30609/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978939"978939/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The decimals are imported incorrectly when you use the Webservice service to import decimals in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.53/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30623/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;980448"980448/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The FINDSET function may return an incomplete record set, depending on the size of the caching Record Set configuration setting in the Microsoft Dynamics NAV client that uses the Microsoft SQL Server database/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.54/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30632/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;980572"980572/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The RoleTailored client (RTC) does not show the ampersand character (amp as expected in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.55/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30638/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;980680"980680/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 Service Pack 1 client stops responding if a runmodal form is closed not in the opening order/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.56/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30647/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;980564"980564/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The cursor unexpectedly jumps to the first line when you add a line to a document in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.57/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30677/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;980343"980343/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"quot;You cannot use the zup file because it is already in usequot; error message when you print classic reports from the RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.58/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30711/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;979959"979959/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Local RecordRef variables can cause performance issues when the local RecordRef variables are used through Web services and the RoleTailored client in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.59/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30711/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;980899"980899/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You experience slow performance when you print a document in the RoleTailored client of Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.60/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30711/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;981150"981150/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Microsoft Dynamics NAV crashes when you run the quot;Suggest Vendor Paymentquot; report in the RoleTailored client of Microsoft Dynamics NAV 2009 in Spanish language/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.61/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30746/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;981708"981708/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The analysis view entries do not reflect the dimensions filter when you drill down from the quot;Acc. Schedule Overviewquot; page in Microsoft Dynamics NAV 2009 RoleTailored client/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.62/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30806/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;981195"981195/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"A report is printed incorrectly if the page height is less than the width in the RoleTailored client of Microsoft Dynamics NAV 2009 SP1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.63/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30806/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;982066"982066/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Customer Card dialog box closes unexpectedly when you click OK to select a number series in the No. Series dialog box in the RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.64/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30806/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;982148"982148/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The RoleTailored client of Microsoft Dynamics NAV 2009 crashes when you run the XMLPort import if the XML port data has an xml tag that includes quot;:quot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.65/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30828/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;981923"981923/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV native database server may stop when a batch process is deadlocked in Microsoft Dynamics NAV/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.66/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30828/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;982361"982361/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The shortcut keys for pages in the background are unexpectedly captured by the page on which you work in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.67/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30863/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;982464"982464/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Values and column header names are invisible in the Sales Budget Overview form (7139) in Microsoft Dynamics NAV 2009 SP1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.68/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30894/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;982031"982031/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 RoleTailored client (RTC) crashes when you try to customize a Card page that has two parts of the FastTab type/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.69/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30929/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;982509"982509/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The result is different when you send data to a report in the Classic client and in the RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.70/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31051/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2028783"2028783/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2059737"2059737/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2072312"span style="background-color:yellow;"em2072312/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2062103"span style="background-color:yellow;"em2062103/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The character quot;Cquot; is incorrectly added in front of the field when you enter a time of quot;23:59quot; in a Time type field in the RoleTailored client (RTC) in Microsoft Dynamics NAV 2009 SP1 /span/ppspan style="font-size:8pt;"Each session has a blank space added at the beginning of the User ID value in Microsoft Dynamics NAV 2009 Service Pack 1 against the native database /span/ppspan style="font-size:8pt;"span style="background-color:yellow;"emThe OnlyMaxLimit property of a flowfield does not work when you drill down into the flowfield in the RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;background-color:yellow;"emThe corresponding flowfields in a header page are not updated when you update the lines in a subpage in the RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.71/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31085/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2126644"2126644/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2028800"2028800/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2130496"2130496/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You cannot create a sales invoice from a job planning line in the RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"The exposed data is formatted as quot;floatquot; incorrectly when you expose the data of the quot;decimalquot; type by using the web service in Microsoft Dynamics NAV 2009 SP1 /span/ppspan style="font-size:8pt;"The filter that you created for a responsibility center is ignored in the RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.72/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31112/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2161039"2161039/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You cannot add a Windows login that contains an apostrophe character to Microsoft Dynamics NAV 2009 SP1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.73/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31143/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2179493"2179493/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2188923"2188923/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/kbdisplay.aspx?wtntzsmnwukntmmyqolmyuqtyzkmlnlzmxmuqkxmtvwmxwrz"2160818/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The quot;Savevaluequot; page property does not work if a page has a variable whose name contains the special characters in the RoleTailored Client (RTC) in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"The RoleTailored client crashes when you run a page and then execute an action that uses the COMMIT statement and then the PAGE.RUNMODAL statement in Microsoft Dynamics NAV 2009 SP1 /span/ppspan style="font-size:8pt;"quot;This message is for C/AL programmers: The call to member Value failedquot; error message when you run the quot;Export to Excelquot; function in the RoleTailored client (RTC) in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.74/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31177/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2084058"2084058/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2228548"2228548/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Web services do not handle the decimals consistently if the EVALUATE function is called after the GLOBALLANGUAGE statement in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"Microsoft Dynamics NAV 2009 SP1 does not write full text for the DBCS code page when you use the WRITETEXT function or the WRITE function to execute writing text/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.75/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31213/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2256756"2256756/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"quot;The variable [Variable_Name] is defined more than oncequot; error message when you try to compile the Microsoft Dynamics NAV objects that use Microsoft Excel Automation /span/ppspan style="font-size:8pt;"Error message when you run multiple classic reports in the Microsoft Dynamics NAV 2009 Service Pack 1 Role Tailored Client (RTC)/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.76/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31246/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2264896"2264896/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2266791"2266791/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Duplicated files/folders are shown in the quot;Filequot; virtual table unexpectedly when you use the table in the RoleTailored client (RTC) in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"Decreased performance when you run a list form or page that displays the table that contains a BLOB field in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.77/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31320/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2254777"2254777/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2251466"2251466/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You cannot resize columns in role center list parts in the RoleTailored client (RTC) in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"You can unexpectedly enter excess characters in a field if you use the double-byte character set in the RoleTailored client (RTC) in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 0.78/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em31340/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2161209"span style="background-color:yellow;"em2161209/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;background-color:yellow;"emquot;The Service Header already exists. Identification fields and valueshellip;quot; error message when you change the Ship-to Code value on a service order in RoleTailored Client (RTC) in Microsoft Dynamics NAV 2009 /em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.79/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31361/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2281977"2281977/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2286287"2286287/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2281980"2281980/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2281769"2281769/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The classic report does not consider the work date when you start the classic report from the RoleTailored client (RTC) in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"The C# files cannot be used after you compile the double-byte character set (DBCS) text constants into the C# files in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"You cannot edit records in a sub page when you open a page that contains the sub page in the lookup mode in Microsoft Dynamics NAV 2009 SP1 /span/ppspan style="font-size:8pt;"You receive C++ runtime error messages when you run classic reports from the RoleTailored client (RTC) of Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.80/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31397/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2313001"2313001/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The RoleTailored client (RTC) of Microsoft Dynamics NAV 2009 crashes when you create records that include quotation marks/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.81/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31414/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb$en-us$2301052amp;wa=wsignin1.0"2301052/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2312984"2312984/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2297047"2297047/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2291060"2291060/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Incorrect C# code is generated for the ISSERVICETIER statement when you use the nested quot;IF-THEN-ELSEquot; statement that includes a reference to a Dataport variable in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"You cannot start the RoleTailored client (RTC) in maximized mode or without the Navigation Pane in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"The Classic client of Microsoft Dynamics NAV 2009 SP1 crashes after you receive an expected error message /span/ppspan style="font-size:8pt;"quot;The maximum length for a string value is [Length]quot; error message when you run code that uses the MAXSTRLEN function in the RoleTailored client of Microsoft Dynamics NAV 2009 SP1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.82/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31510/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2388848"2388848/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2388796"2388796/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb$en-us$2388853amp;wa=wsignin1.0"2388853/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The RoleTailored client crashes when you enter double-byte characters that exceed the length of the field in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 Service Pack 1 server stops or the database is corrupted after you enter double-byte characters into a text field or a code field in the RoleTailored client /span/ppspan style="font-size:8pt;"The company list shows all companies unexpectedly in the RoleTailored client if a role that has the permissions specific to companies is assigned to Windows groups in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.83/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31546/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2291030"2291030/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2286746"2286746/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"quot;This operation cannot be performed while an auto-filled column is being resizedquot; error message when you perform lookup operations in the RoleTailored client (RTC) and the RTC crashes in Microsoft Dynamics NAV 2009 /span/ppspan style="font-size:8pt;"The Unit Cost amount cannot be saved when you leave the quot;Unit Costquot; field to come to the next field in the Job Journal in the RoleTailored client (RTC) of Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.84/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31548/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2345399"2345399/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2318337"span style="background-color:yellow;"em2318337/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The specified filter is not applied as expected for a field drop-down list that uses the quot;Advancedquot; option in the RoleTailored client in Microsoft Dynamics NAV 2009br /span style="background-color:yellow;"emAll printers for all users are displayed when you use the Printer Selection feature in Microsoft Dynamics NAV 2009 through terminal services on a Windows Server 2008-based or Windows Server 2003-based computer/em/span/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.85/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31587/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2390030"2390030/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The RoleTailored client crashes when you open a page that has fields based on a global variable in Microsoft Dynamics NAV 2009 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.86/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31671/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2402586"2402586/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2389900"2389900/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2390143"2390143/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2257093"2257093/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2415621"2415621/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2413929"2413929/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2391273"2391273/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb$en-us$2387387amp;wa=wsignin1.0"span style="background-color:yellow;"em2387387/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2361147"span style="background-color:yellow;"em2361147/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Not all filters are deleted when you try to delete all filters on a report in the Classic client in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"The records in the tree-view subpage are editable even though the page is in View mode in the RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"The value in a field cannot be edited if the field is available multiple times on a page in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"The NOTBlank property does not work on the fields of the quot;Datequot; type when you use the property in the RoleTailored client (RTC) in Microsoft Dynamics NAV 2009 SP1 /span/ppspan style="font-size:8pt;"Microsoft Dynamics NAV 2009 SP1 does not continue to restore a database backup after an error has occurred /span/ppspan style="font-size:8pt;"Microsoft Dynamics NAV 2009 SP1 executes the OnValidate trigger unexpectedly on a page that has a Boolean field /span/ppspan style="font-size:8pt;"You have to run a page two times to see the design changes of the page in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"span style="background-color:yellow;"emThe Microsoft Dynamics NAV server stops unexpectedly when you close the RoleTailored client/em/span /span/ppspan style="font-size:8pt;background-color:yellow;"emThe conversion to UTC occurs two times when the web services in Microsoft Dynamics NAV 2009 Service Pack 1 use the FORMAT(Time,0,9) format/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.87/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31695/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2393853"2393853/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2389934"2389934/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2406493"span style="background-color:yellow;"em2406493/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2411497"span style="background-color:yellow;"em2411497/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The RoleTailored client crashes when you close the last opened page when you have multiple pages open in Microsoft Dynamics NAV 2009 Service Pack 1 (SP1) /span/ppspan style="font-size:8pt;"The Roletailored client crashes when several pages are opened in Microsoft Dynamics NAV 2009 Service Pack 1 /span/ppspan style="font-size:8pt;"span style="background-color:yellow;"emSome flowfields display incorrect data in tables that have more than 20 flowfields in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;background-color:yellow;"emquot;208,quot;42S02quot;,[Microsoft][ODBC SQL Server Driver][SQL Server]Invalid object name #39;$ndo$usrproperty#39;quot; error message when you try to delete a table from the object designer in Microsoft Dynamics NAV 2009 Service Pack 1/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.88/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31774/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2252086"2252086/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2445675"2445675/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The RoleTailored client crashes when you operate on a treeview control in a customized treeview page in the RoleTailored client of Microsoft Dynamics NAV 2009 SP1 /span/ppspan style="font-size:8pt;"The system resets the subpage links unexpectedly when the additional filters are set in a source table of a subpage in Microsoft Dynamics NAV 2009 SP1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 0.89/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em31793/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb$en-us$2447261amp;wa=wsignin1.0"span style="background-color:yellow;"em2447261/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2444775"span style="background-color:yellow;"em2444775/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"span style="background-color:yellow;"emThe document number of the selected company is invisible in the business activity statement when you create a new Business Activity Statement unit in the Australian version of Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;background-color:yellow;"emThe RoleTailored client becomes unresponsive when you add criteria to a contact search operation in the Query Details page in Microsoft Dynamics NAV 2009 Service Pack 1/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 0.90/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em31839/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb$en-us$2457346amp;wa=wsignin1.0"span style="background-color:yellow;"em2457346/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2453373"span style="background-color:yellow;"em2453373/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2444074"span style="background-color:yellow;"em2444074/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"span style="background-color:yellow;"emquot;The length of the source exceeds the size of the destination bufferquot; error message when you export objects from the database in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;"span style="background-color:yellow;"emquot;Exception of type #39;Microsoft.Dynamics.Nav.Types.Exceptions.NavNCLDialogException#39; was thrownquot; error message when you close the Job Journal Template List page in the RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;background-color:yellow;"emThe client becomes unresponsive when you run the COPYLINKS C/AL function in which the source record variable and the destination record variable point to the same record in Microsoft Dynamics NAV 2009 Service Pack 1/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 0.91/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em31861/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2449163"span style="background-color:yellow;"em2449163/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2456269"span style="background-color:yellow;"em2456269/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2456542"span style="background-color:yellow;"em2456542/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"span style="background-color:yellow;"emThe code in the OnInsert trigger and in the OnDelete trigger of a page does not work as expected in the RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;"span style="background-color:yellow;"emThe filters in a page view are ignored when you open the view in a new window in RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;background-color:yellow;"emThe RoleTailored Client (RTC) crashes when the quot;PAGE.RUNMODALquot; code runs from the Onvalidate trigger of a field on a Page in Microsoft Dynamics NAV 2009 SP1/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 0.92/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em31912/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2462011"span style="background-color:yellow;"em2462011/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2458210"span style="background-color:yellow;"em2458210/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2462936"span style="background-color:yellow;"em2462936/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"span style="background-color:yellow;"emThe focus does not jump to the last window as expected after you close a confirmation dialog box in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;"span style="background-color:yellow;"emThe RoleTailored client crashes if a runtime error occurs when you enter a new record in a subpage in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;background-color:yellow;"emRefreshing the Order Planning page takes a long time if Calculate Plan results in an error message in Microsoft Dynamics NAV 2009 SP1/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 0.93/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em31926/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb$en-us$2462141amp;wa=wsignin1.0"span style="background-color:yellow;"em2462141/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2443436"span style="background-color:yellow;"em2443436/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2464830"span style="background-color:yellow;"em2464830/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"span style="background-color:yellow;"emquot;The property exceeds the buffer sizequot; error message when you try to import a language module into Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;"span style="background-color:yellow;"emMicrosoft Dynamics NAV 2009 SP1 web services incorrectly uses Coordinated Universal Time (UTC) when the TIME function is used/em/span /span/ppspan style="font-size:8pt;background-color:yellow;"emThe RoleTailored client cannot start after you receive an error message about incorrect generation of system tables in Microsoft Dynamics NAV 2009 Service Pack 1/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 0.94/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em31959/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2467974"span style="background-color:yellow;"em2467974/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2470706"span style="background-color:yellow;"em2470706/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2467346"span style="background-color:yellow;"em2467346/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"span style="background-color:yellow;"emThe code section on the request page of a report cannot be opened in Microsoft Dynamics NAV 2009 SP1/em/span /span/ppspan style="font-size:8pt;"span style="background-color:yellow;"emTwo special characters are incorrectly added at the end of the copied value when you copy cell content from Microsoft Excel to Microsoft Dynamics NAV 2009 SP1/em/span /span/ppspan style="font-size:8pt;background-color:yellow;"em2467346/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 0.95/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em31974/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2469304"span style="background-color:yellow;"em2469304/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;background-color:yellow;"emquot;GRANT VIEW SERVER STATEquot; error message when you try to convert a Microsoft Dynamics NAV database from Microsoft Dynamics NAV 5.0 to Microsoft Dynamics NAV 2009 Service Pack 1/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 0.96/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em31989/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="http://v"span style="background-color:yellow;"em2477467/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2479004"span style="background-color:yellow;"em2479004/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2474579"span style="background-color:yellow;"em2474579/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"span style="background-color:yellow;"emThe page layout is changed unexpectedly when you run a page by using the RunModal method in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;"span style="background-color:yellow;"emA Ratio control in a list page has no coloring based on the percentage in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;background-color:yellow;"emThe Microsoft Dynamics NAV server stops when you apply a heavy load to the Microsoft Dynamics NAV database in Microsoft Dynamics NAV 2009 Service Pack 1/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 0.97/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em32011/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2479645"span style="background-color:yellow;"em2479645/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2479116"span style="background-color:yellow;"em2479116/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2477374"span style="background-color:yellow;"em2477374/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2482775"span style="background-color:yellow;"em2482775/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"span style="background-color:yellow;"emThe current record pointer locates on the incorrect row in the lookup dialog box in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;"span style="background-color:yellow;"emYou receive a blank error message when an error occurs in an XMLPort import in Microsoft Dynamics NAV 2009 Service Pack 1 with the Microsoft SQL Server option/em/span /span/ppspan style="font-size:8pt;"span style="background-color:yellow;"emThe page closes after you receive an error message in a page in the RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;background-color:yellow;"emThe quot;Enable automatic filterquot; option in lookup fields is enabled even though you disable the option when you customize the list page in the RoleTailored client in Microsoft Dynamics NAV 2009 Service Pack 1/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 1/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em32012/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2496107"span style="background-color:yellow;"em2496107/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;background-color:yellow;"emPlatform hotfix resource files for Microsoft Dynamics NAV 2009 Service Pack 1/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 1.1/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em32029/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2483349"span style="background-color:yellow;"em2483349/em/span/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2483340"span style="background-color:yellow;"em2483340/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"span style="background-color:yellow;"emYou receive a confusing error message in the RoleTailored client when you run an object in Microsoft Dynamics NAV 2009 Service Pack 1/em/span /span/ppspan style="font-size:8pt;background-color:yellow;"emThe RoleTailored client crashes when you use an Arabic keyboard layout in Microsoft Dynamics NAV 2009 Service Pack 1/em/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="background-color:yellow;"emUpdate 1.2/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="background-color:yellow;"em32074/em/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb$en-us$2481169amp;wa=wsignin1.0"span style="background-color:yellow;"em2481169/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;background-color:yellow;"emquot;ComplexType is neither recognized as a GUID nor as the name of an Automation serverquot; error message when you try to import an object that has an Automation type variable into Microsoft Dynamics NAV 2009 Service Pack 1/em/span/p/td/tr/tbody/table/divpstrongSome interesting version-specific links:/strong /pdivtable border="0" style="border-collapse:collapse;"colgroupcol style="width:302px;"/colcol style="width:306px;"/col/colgrouptbody valign="top"trtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongExecutives amp; Sales/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongDevelopers amp; Consultants/strong/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"ullia href="https://mbs.microsoft.com/partnersource/marketing/campaigns/prospect/launchmdnav.htm?printpage=false"strongLaunch Portal for Dynamics NAV 2009/strong/a /lilia href="https://mbs.microsoft.com/partnersource/marketing/marketingcollateral/messagingframeworks/msdnav2009launchportal.htm?printpage=false"strongUS Launch Portal for Dynamics NAV 2009/strong/a /lilidivstrongDemo scripts:/strong /divullia href="https://mbs.microsoft.com/partnersource/deployment/documentation/demoscripts/Introduction_NAV2009.htm"Introduction to Microsoft Dynamics NAV 2009/a /lilia href="https://mbs.microsoft.com/partnersource/deployment/documentation/demoscripts/RoleCenter_NAV2009.htm"The Role Center/a /lilia href="https://mbs.microsoft.com/partnersource/deployment/documentation/demoscripts/MDNAV2009PayableDemoScript.htm"Payables/a /lilia href="https://mbs.microsoft.com/partnersource/deployment/documentation/demoscripts/Prepayments_NAV2009.htm"Prepayments/a /lilia href="https://mbs.microsoft.com/partnersource/deployment/documentation/demoscripts/FixedAssets_NAV2009.htm"Fixed Assets/a /lilia href="https://mbs.microsoft.com/partnersource/deployment/documentation/demoscripts/MDNAVDocumentsApprovalDemoScript.htm"Documents Approval/a /lilia href="https://mbs.microsoft.com/partnersource/deployment/documentation/demoscripts/MDNAVMobileSalesDemoScript.htm"Mobile Sales/a /lilia href="https://mbs.microsoft.com/partnersource/deployment/documentation/demoscripts/WebServicesIntegration_InfoPath_NAV2009.htm"Web Services Integration with InfoPath/a /lilia href="https://mbs.microsoft.com/partnersource/deployment/documentation/demoscripts/PageDesigner_StepbyStepGuide_NAV2009.htm"Page Designer Step-by-Step guide and script/a /lilia href="https://mbs.microsoft.com/partnersource/deployment/documentation/demoscripts/ConfiguringUserExperience_NAV2009.htm"User Experience Configuration/a /li/ul/lilia href="https://mbs.microsoft.com/partnersource/marketing/marketingcollateral/messagingframeworks/navpartnerresourcekit2009.htm"strongNAV2009 Partner Resource Toolkit/strong/astrong : New Additions!/strong /lilia href="https://mbs.microsoft.com/public/insights/ReadArticle.aspx?rcpt_id=15989386amp;ja_id=47719"strongSystem Requirements /strongfor NAV 2009/a /lilidiva href="https://mbs.microsoft.com/Cms/Templates/document/General.aspx?NRMODE=Publishedamp;NRNODEGUID=%7bA6A331A9-6B58-4006-8841-F96F5E7A8A93%7damp;NRORIGINALURL=/partnersource/deployment/methodology/vpc/nav2009SP1.htm"strongNAV 2009 SP1 RTM VPC/strong/a /divpnbsp;nbsp;/p/li/ul/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"ullia href="http://www.microsoft.com/downloads/details.aspx?FamilyID=EEC997BE-50C8-4D27-8BF2-FA93C9AC282Aamp;displaylang=en"strongMicrosoft Dynamics NAV 2009 Developer and IT Pro Help/strong/a /lilia href="http://www.microsoft.com/downloads/details.aspx?FamilyID=8B5AB93F-480B-4C14-868A-98F6B9BC3E86"strongUser Experience (UX) Guidelines/strong/a: a tool to guide ISV#39;s and partners in building more user-friendly applications. /lilia href="https://mbs.microsoft.com/partnersource/support/selfsupport/hotfixes/captionidsusingtransformationtoolformicrosoftdynamicsnav2009"strongCaption ID#39;s/strong using the strongForm Transformation Tool/strong for strongNAV 2009/strong/a /lilia href="https://mbs.microsoft.com/partnersource/downloads/releases/MicrosoftDynamicsNAV2009.htm"strongNAV2009 Download Page/strong/a /lilia href="https://mbs.microsoft.com/public/insights/ReadArticle.aspx?rcpt_id=15989386amp;ja_id=47716"strongInstallation and Application Setup Guides /strongfor NAV 2009/a /lilia href="https://mbs.microsoft.com/public/insights/ReadArticle.aspx?rcpt_id=15989386amp;ja_id=47719"strongSystem Requirements /strongfor NAV 2009/a /lilia href="https://mbs.microsoft.com/partnersource/deployment/documentation/whitepapers/MDNAVPerformanceGuide"strongPerformance Guide /strongfor NAV 2009/a /lilidivMicrosoft Dynamics strongNAV 2009 Developer and IT Pro Help/strong /divullia href="http://www.microsoft.com/downloads/details.aspx?FamilyID=eec997be-50c8-4d27-8bf2-fa93c9ac282aamp;DisplayLang=en"The strongDownload/strong of the help files/a /lilia href="http://msdn.microsoft.com/en-us/library/dd448639.aspx"The link to strongMSDN/strong/a /li/ul/lilia href="https://mbs.microsoft.com/Cms/Templates/document/General.aspx?NRMODE=Publishedamp;NRNODEGUID=%7b4A822EFE-4D59-45CE-8564-493F9A70F3C0%7damp;NRORIGINALURL=/customersource/documentation/whitepapers/NAV2009FeatureEnhancementsamp;NRCACHEHINT=Guestamp;wa=wsignin1.0"strongFeature Enhancements Documents/strong for Microsoft Dynamics NAV 2009/a /lilidivOverview of strongReleased Platform Hotfixes/strong on strongPartnersource/strong: /divullia href="https://mbs.microsoft.com/partnersource/support/selfsupport/hottopics/NAV2009PlatformHotfixOverview"for strongMicrosoft Dynamics NAV 2009/strong/a /lilia href="https://mbs.microsoft.com/partnersource/support/selfsupport/hottopics/NAV2009SP1PlatformHotfixOverview"for strongMicrosoft Dynamics NAV 2009 SP1/strong/a /li/ul/lilidivOverview of strongReleased Platform Hotfixes/strong on strongCustomersource/strong: /divullia href="https://mbs.microsoft.com/customersource/support/selfsupport/hottopics/NAV2009PlatformHotfixOverview"for strongMicrosoft Dynamics NAV 2009/strong/a /lilia href="https://mbs.microsoft.com/customersource/support/selfsupport/hottopics/NAV2009SP1PlatformHotfixOverview"for strongMicrosoft Dynamics NAV 2009 SP1/strong/a /li/ul/lilia href="https://mbs.microsoft.com/Cms/Templates/document/General.aspx?NRMODE=Publishedamp;NRNODEGUID=%7bD0F9FF46-DB6C-43C0-9F1F-44EE4D82EC4B%7damp;NRORIGINALURL=/partnersource/deployment/documentation/whitepapers/treemapbusinessdatavisualization_nav2009_sp1.htmamp;NRCACHEHINT=amp;wa=wsignin1.0"Dynamics NAV strongTreemap AddIn/strong/a/li/ul/td/tr/tbody/table/divpnbsp; nbsp;/ppnbsp; nbsp;/pdivtable border="0" style="border-collapse:collapse;"colgroupcol style="width:75px;"/colcol style="width:95px;"/colcol style="width:75px;"/colcol style="width:86px;"/colcol style="width:307px;"/col/colgrouptbody valign="top"trtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongVersion/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongUpdate/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongBuild No./strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongKB number/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongInfo/strong/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/partnersource/downloads/releases/microsoftdynamicsnav2009.htm?printpage=false"NAV2009/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27808/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"RTM/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.1/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27980/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLRROMWLKYMRKLPOKTUMUUMNRRVLPUROXY"960268/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The numeric decimal separator does not work as expected when you use non-US regional settings in the Microsoft Dynamics NAV 2009 Roletailored client/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.2/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28177/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLNVPMXNKMPMYKXMMXLXSMYYVPUQTXWQOW"961772/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The blank option disappear in the option list of option typed fields when you try to filter values on a report in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.3/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28463/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLMUROZYPMNOTUOYPSYKVPTSXQMSSQKOWK"962012/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you design reports in Microsoft Dynamics NAV 2009: quot;The RDLC file is not a well-formed XML documentquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.4/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28622/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLTRLKPPTYWTYUNZOUTRWWRTKOLTWNKYSZ"961430/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The filter values are not populated automatically into the page fields as expected in the Microsoft Dynamics NAV 2009 RTC client/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.5/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28713/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLTUZLWTUWZVQTMKWSNVLQPNLXPZVYSMPK"968196/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you active the option MaintainSQLIndex or MaintainSIFTIndex in Microsoft Dynamics NAV 2009: quot;Cannot drop the index #39;CRONUS International Ltd_$Cust_ Ledger Entry.$6#39;quot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.6/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28766/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLXNYLMQOTQZXROLQOROSMYVYSWLPQOTMX"968650/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The CurrPage.CLOSE method does not work as expected in the Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.7/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28772/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLKYTPNOSQSKZPUZWRVVTLXZVYVWKLXXPL"968466/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The shortcut that you create in the non-English classic client is lost in the Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.8/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28795/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLXOTPOSSZPYMQPRKWQROLWMNQNXWXKPPV"968189/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you try to start the Role Taylored Client (RTC) with a three tiers configuration in Microsoft Dynamics NAV 2009: quot;Login failed for user #39;NT AUTHORITYANONYMOUS LOGON#39;quot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.9/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28795/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLKSXZOYVMVTZLYOKOZZPMLKWMNXPPTYSQ"968649/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The XML port throws two errors when there is a data validation error during XMLPort import in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.10/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28815/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLNYZXYMKMPZONTROMWSTTXSVNXTUNTUSM"968277/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The quot;OnLookUpquot; trigger does not work as expected on a page in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.11/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28829/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLKSLYLMKZLOKXPWNVRQRZTTQLTYZNOWKU"968411/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The value of xRec is different between a form and a page when an OnLookup trigger is coded on the form and the page in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.12/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28889/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLWYQPSXZTRVXOKQQXYORZOMLSYVVSYMRN"969447/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The OnNewRecord trigger of a page is performed two times when you create a new record in the Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.13/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28981/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLYPTZOLRVWLYOTYXSYTXPPXZYLKZYOWMS"969448/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you open a report in the Microsoft Dynamics NAV Role Tailored Client that does not have a report definition layout in Microsoft Dynamics NAV 2009: quot;Microsoft Dynamics NAV Classic client is opened from an untrustworthy componentquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.14/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28981/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYSZRRNOTTUKOOSTLLYZPQXZUVMXTYZUMYTYRTLLLXTLQSOWQY"969649/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Microsoft Dynamics NAV crashes if you run the code to receive a stream in the Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.15/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29070/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLSNVSMQQUYZYVTQKWMTMQWSNQLZNTVNQX"970473/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"A report is not sent to a specified printer when you print the report from the Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.16/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29082/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLSMZPYRQZSPNZOMZLOWVLWMYSOKOUKLXW"970762/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 Classic client crashes when you export the Approval Request Entries form (662) to Excel 2007 on a computer that is running Windows Vista/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.17/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29096/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLVSLWMKVMLVZNORYXPZZZLKMQMSXOLKYP"970712/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The xRec and Rec variables unexpectedly contain the same values in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.18/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29140/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLXUVMTMNWRQRRKQYZXYVYRXUUOMTWKXPW"970545/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Menu items or menu groups that are sent to shortcuts disappear from the original menu in Microsoft Dynamics NAV 2009 or Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.19/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29140/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLWUKQRVPLLLOXQZKYSYPSPLVKURQSXTQU"971124/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You can access pages even if you do not have permissions in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.20/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29140/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLNSPWYXOMWYTSVKPZZQLLXVKVRRUMNMRR"971173/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"A new instance of the Microsoft Dynamics NAV 2009 client is started when you use a fully qualified hyperlink that links to the Microsoft Dynamics NAV 2009 database/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.21/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29140/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLRXVYWZNTXWUSYXZPSLXXWKMLUNUZTLPM"971230/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you run a page on the Microsoft Dynamics NAV Role Tailored Client (RTC) based on a custom table in Microsoft Dynamics NAV 2009: quot;Destination buffer is too small, destination buffer size: 65536, source size: 65675quot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.22/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29202/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLSQXVKRWUSKRPYLOLSKPUKTVWNPPWUYKX"970079/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you post an application that has multiple documents which are applied in the Microsoft Dynamics NAV 2009 Role Tailored Client (RTC): quot;The application was successfully posted though no entries have been appliedquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.23/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29210/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLWVUOLNUXYKRULTPWPKXYYRZTYWYQNLXL"971174/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you use the Hyperlink statement to open a file in the Role Tailored Client in Microsoft Dynamics NAV 2009: quot;File not foundquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.24/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29210/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLSYOMPTZSSXYZMKZTLNKLYLTWXKWUOMSM"971701/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You receive an error message in the RoleTailored client (RTC) in Microsoft Dynamics NAV 2009: quot;Overflow under conversion of System.Int32 value 256 to System.Bytequot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.25/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29210/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLUMOPXXZZUKQMYXLVNYKYTMTVZWQZKRKU"971738/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you run a report for a company whose name has an ampersand character in the RoleTailored client in Microsoft Dynamics NAV 2009: quot;Company Name #39;[Company_name]#39; does not existquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.26/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29267/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLVZTKNLRNUTQSTYTNUTVYLLZMUSXNONXY"972059/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you run a customized report in the Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009: quot;The input line is too longquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.27/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29285/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLRUPLVWXRRKQPOPMXWSRQSRNZUTZNNYYS"971989/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You cannot connect to a Web service when you connect a Web site by using the Microsoft Dynamics NAV 2009 Web service interface in a non-Microsoft development software environment/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.28/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29285/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLUMKXWNRUSSZWKOUWTVWQRLKWOXXTVPYR"972372/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you click quot;Post and Printquot; in the Bank Account Reconciliation dialog box to print a reconciliation in Microsoft Dynamics NAV 2009: quot;The Bank Acc. Reconciliation does not existquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.29/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29285/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLUUOVZZVMMNSUPXXYKXTXRURQKYQOYKKM"972465/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you run a page that is based on a table by using the RoleTailored Client (RTC) in Microsoft Dynamics NAV 2009: quot;The in the [table name] table must be enabledquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.30/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29285/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLQNSOURQNNMVKNLXNVMTTSPVWPWVVXZZS"972660/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you change the value in the quot;Bank Account No.quot; field in the quot;Bank Acc. Reconciliationquot; dialog box in the Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009: quot;The Bank Acc. Reconciliation does not existquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.31/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29372/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLTPSNLRMOPNNLPSUMZWZUXMUMSWXXTZMW"971784/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you create an item journal line in a project that uses the C# language by using the Item Journal page (40) as Web reference in Microsoft Dynamics NAV 2009: quot;You cannot use entry type Transfer in this journalquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.32/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29372/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLNYUORTPOQZQVRRKLPOPZTWUNKYVKTPNV"972430/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You cannot compile a statement that compares two strings in the Role Tailored Client in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.33/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29372/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLLXLZVORQUONKRQQPRYVWNOKVTRZQROSM"972791/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"A null termination string is added at the end of a text string when you load the string to a BSTR variable in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.34/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29372/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;972832"972832/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The line breaks that you added manually in the C/AL code do not work in the Role Tailored Client in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.35/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29392/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLXTUZOURRQOWXZMLWUWKUWLXSVXMOMRTX"972970/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The blank spaces after an ampersand (amp character are removed when you pass a string to a Microsoft Dynamics NAV 2009 Web service/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.36/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29392/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLWZQMXQPSVZKMWRSSVQOKQLOULNXSYTRW"973041/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you try to access all licensed sessions at the same time in Microsoft Dynamics NAV 2009: quot;Your program license does not permit more users to work simultaneouslyquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.37/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29415/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYVLXUZLWUKKQPOVRVLMWORVSNSXVNSOVZUPXUSKKNYNYMMRUS"942540/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You cannot determine which fields are available and which fields are unavailable when you open a dialog box in Microsoft Dynamics NAV/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.38/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29415/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLWTQWPUWSPUVXRNSSUZMXSUYPQMNPXXYX"971519/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you run an object that uses the RecordRef.GET(RecordID) function in Microsoft Dynamics NAV 2009: quot;Object of type Table with id 2000100007 could not be foundquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.39/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29415/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLSRWZZWUPZQSVUMSYLMSWSSQRNXZXOTRY"973237/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The date filter that you set in the quot;VAT Statement Previewquot; dialog box does not work in the Role Tailored Client in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.40/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29443/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLWXQPNYKVVYVZLLMZPRXLZNUMWLNPRZMP"973227/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Local characters are imported as question marks after you import a file from the RoleTailored client (RTC) in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.41/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29443/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLWQOVNNOWZUMLSYZMNOURUYYKVTSMNQKL"973416/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Transactions are not saved in the Microsoft Dynamics NAV 2009 database when you execute the transactions by using Web services/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.42/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29443/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLVXOUPTTYSYWPSWNUWLMQNNSULKLMSKXN"973491/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you use the quot;Send To Microsoft Office Excelquot; feature or the quot;Send To Microsoft Office Wordquot; feature in Microsoft Dynamics NAV 2009: quot;You do not have permission to read the User Default Style Sheet tablequot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.43/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29500/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLOZPVVUOZZKTSQXVRKVTOVKVMZRYYLMVQ"973899nbsp;/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You do not receive an error message as expected when an error occurs in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.44/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29500/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;973959"973959/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You do not receive a warning message when you try to add a record that already exists if you use the quot;No. Seriesquot; field with the quot;Default Nosquot; setting enabled in the Role Tailored Client in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.45/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29515/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;973997"973997/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You receive a Microsoft SQL Server error when you try to synchronize permissions if the quot;NT AUTHORITYNETWORK SERVICEquot; account is set up as a Windows logon account in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.46/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29515/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLMXWUSUZSYZRRVLRWWZXOSYSLOUULQZMQ"974066/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You experience slow performance when you restore a single company into a Microsoft SQL Server database in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.47/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29518/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLOSTOMZTPTWOSMZZYQOWKWTNULNZNSROQ"974024/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you change to another company in the Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009: quot;Page is not openquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.48/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29548/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLPKQWQKMKUUKUPQZUQYKLRMPYQSMTMWSL"974196/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you run the Calculate Inventory report in a quot;Whse. Physical Inventoryquot; journal in the RoleTailored Client (RTC) in Microsoft Dynamics NAV 2009: quot;The maximum length for a string value is 20quot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.49/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29548/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLZWYLQWNOZOXRWUQYMUKLVLWTWWTROZLS"974245/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The lines in a batch are not updated after you add a line to a batch of a general journal in the Role Tailored Client (RTC) in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.50/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29607/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYMYQKSYMXOSOOUMLVMKOONVNUKKPTSVZKQMWYQPNKLQYLZOM"974526/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Microsoft Dynamics NAV 2009 RoleTailored Client crashes when you try to open a home page/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.51/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29683/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;974244"974244/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 client crashes when you compile certain objects from the client/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.52/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29735/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;974717"974717/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Role Tailored Client in Microsoft Dynamics NAV 2009 crashes if you have Outlook 2007 Service Pack 2 installed/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.53/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29735/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;975655"975655/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The quot;ISTEMPORARYquot; property of a RecordRef variable becomes incorrect in certain cases in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.54/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29762/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;975799"975799/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"A newly created purchase invoice has the same number as the previously created invoice if you create the purchase invoice after you view the statistics in the Statistics dialog box in the Role Tailored Client in Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.55/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30233/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;948302"948302/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The NAS stops responding to events when a lock time-out occurs in Microsoft Dynamics NAV/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.56/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30078/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;977497"977497/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV server crashes when you type amounts in amount fields in the quot;Excise Cenvat Claim Detailquot; form in the RoleTailored client of Microsoft Dynamics NAV 2009/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.57/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30610/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978604"978604/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 2009 client crashes when you open many formsnbsp;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.58/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30610/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;978482"978482/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you type t in the Expiration Date/Time field in the Job Queue Entry Card form in Microsoft Dynamics NAV 2009: quot;You cannot enter #39;[Date]#39; in DateTimequot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.59/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30615/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;979760"979760/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The records are loaded only if the records were already selected in the component when a Client Extensibility component uses C/AL code to synchronize the current page in Microsoft Dynamics NAV 2009/span/p/td/tr/tbody/table/divpnbsp; nbsp;/ppstrongSome interesting version-specific links:/strong /ppspan style="background-color:yellow;"emSee NAV 2009 SP1 (up)/em/span /ppnbsp; nbsp;/pdivtable border="0" style="border-collapse:collapse;"colgroupcol style="width:64px;"/colcol style="width:82px;"/colcol style="width:64px;"/colcol style="width:71px;"/colcol style="width:357px;"/col/colgrouptbody valign="top"trtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongVersion/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongUpdate/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongBuild No./strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongKB number/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongInfo/strong/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/Cms/Templates/document/General.aspx?NRMODE=Publishedamp;NRNODEGUID=%7b7CC528BC-16F9-4325-BD32-076CF4E84ADB%7damp;NRORIGINALURL=/partnersource/downloads/releases/microsoftdynamicsnav50sp1.htmamp;NRCACHEHINT=Guestamp;wa=wsignin1.0"5.0 SP1/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"strong26084/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.1/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"26654/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;953245"953245/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"C/Front hangs while generating a lot of temp files/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.2/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"26751/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;953545"953545/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Selecting printer tray doesn#39;t work/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;951631"951631/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Locking error when printing a report with code in a form/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Local variable in debugger/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.3/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"26810/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;954342"954342/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"NAV Shows unexpected results when filtering, and may crash/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.4/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"26948/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;954672"954672/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Certain jobs can run slower after upgrading the client/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.5/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27002/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"954722/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"NAV can crash in certain situations: E.g. error 1247 in module 19. No official KB URL available yet. though./span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;956161"Update 1/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27191/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;956161"956161/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Cumulative Platform Update Rollup/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.1/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27253/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;954722"954722/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"NAV crashes when you try to open some forms/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.2/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27368/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;957219"957219/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error sending a document from Commerce Gateway to a server with BizTalk/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.3/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27368/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;957471"957471/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Restore backup: Company Name #39;xx#39; does not exist/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;957733"957733/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"All SIFT views of a table are rebuilt when changing the table/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.4/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27398/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;957824"957824/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Changes in Production Schedule are not saved - Native only/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.5/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27831/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;959911"959911/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"XMLPort.EXPORT cannot handle DBCS Characters./span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.6/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27831/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;959912"959912/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Permissions too restrictive when calculating flowfields with security filters (recordlevel security)/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.7/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27831/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;960141"960141/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"RunModal error screen when deleting record links in certain/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.8/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28007/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;960607"960607/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Save report to html can save the wrong space characters./span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.9/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28028/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;960661"960661/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Lookup list in report request forms do not open./span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.10/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28342/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;962005"962005/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"XML Ports do not import data that comes after a white space/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"./span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.11/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28412/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$963700amp;wa=wsignin1.0"963700/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Client crashes when using a global FieldRef variable/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.12/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28512/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;967158"967158/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you restore a customer database on Microsoft Dynamics NAV 4.0 Service Pack 3 (SP3) Native backup to the Native option for Microsoft Dynamics NAV 5.0 SP1 Client: quot;Internal Error 1355 in Module 19quot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.13/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28798/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;968465"968465/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The XML port returns an additional error message when you execute an XMLPort import in Microsoft Dynamics NAV 5.0 Service Pack 1: quot;The XML Parser setup failsquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.14/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28884/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;969452"969452/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The xRec and Rec are the same and the change log does not detect any changes when a record is changed from a sub form in Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.15/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28913/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;969590"969590/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You require a new platform feature to provide the functionality to limit the general visibility for users in Microsoft Dynamics NAV 5.0 Sp1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.16/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28956/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;969881"969881/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV client crashes when you lose the connection to Microsoft SQL Server in Microsoft Dynamics NAV 5.0 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.17/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29040/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;969777"969777/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Some temporary files are not deleted as expected when the Microsoft Dynamics NAV 5.0 application service stops/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.18/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29048/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$970545amp;wa=wsignin1.0"970545/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Menu items or menu groups that are sent to shortcuts disappear from the original menu in Microsoft Dynamics NAV 2009 or Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.19/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29083/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$970913amp;wa=wsignin1.0"970913/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The card form does not show the detailed information for the record in a list form in Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.20/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29118/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;971172"971172/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Slow performance when you apply a filter to a form that is based on a large table in Microsoft Dynamics NAV 4.0 Service Pack 3 and Microsoft Dynamics NAV 5.0 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.21/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29125/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;971170"971170/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV client crashes when you reopen a company that contains certain customizations in Microsoft Dynamic NAV 5.0 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.22/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29469/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;973584"973584/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The value in a field is changed by a value that you select for a field filter on the field in Microsoft Dynamics NAV 5.0 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.23/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30018/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;976908"976908/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The data in the Warning column is not exported as expected when you export a planning worksheet to a Microsoft Office Excel worksheet in Microsoft Dynamics NAV 5.0 with Service Pack 1 installed/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.24/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30482/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$979135amp;wa=wsignin1.0"979135/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you add a field to the table in Microsoft Dynamics NAV 5.0 SP1: quot;You can only specify the READPAST lock in the READ COMMITTED or REPEATABLE READ isolation levelsquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/Cms/Templates/document/General.aspx?NRMODE=Publishedamp;NRNODEGUID=%7b7CC528BC-16F9-4325-BD32-076CF4E84ADB%7damp;NRORIGINALURL=/partnersource/downloads/releases/MicrosoftDynamicsNAV50SP1.htmamp;NRCACHEHINT=Guestamp;wa=wsignin1.0"Update 2/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"strong30488/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"nbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"strongNew product DVD/strong that contains (obviously) all previous Platform Updates. Functional and technical changes in the product (database) as well. /span/ppa href="https://mbs.microsoft.com/partnersource/support/selfsupport/hotfixes/NAV500SP1Update2"span style="font-size:8pt;"Here are the release notes./span/a/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2.1/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30524/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;979610"979610/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The column that is defined by the Indicator control shows incorrect values when you export the contents in a list form to an Excel worksheet in Microsoft Dynamics NAV 5.0 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2.2/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30571/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;979758"979758/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you create records in a form in Microsoft Dynamics NAV 5.0: quot;Field no. [Field Number] is not defined in the [Table Number] tablequot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2.3/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30571/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;979852"979852/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Online Help feature does not work when you use Turkish language layer in Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2.4/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30584/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;980070"980070/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"A header table cannot show all calculations if there are more than 20 flowfields in the Microsoft SQL Server Option for Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2.5/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30668/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;979889"979889/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The NtAuthentication parameter is ignored when you use a shortcut to start Microsoft Dynamics NAV 5.0 /span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2.6/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30848/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;981756"981756/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"A consolidated hotfix for Microsoft Dynamic NAV 5.0 SP1 Platform Update 2 is available/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2.7/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30848/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;981923"981923/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV native database server may stop when a batch process is deadlocked in Microsoft Dynamics NAV/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2.8/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30906/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;982496"982496/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"quot;MMC could not create the snap-in. The snap-in might not have been installed correctlyquot; error message when you try to start the NAS snap-in after you install Update 2 for Microsoft Dynamics NAV 5.0 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2.9/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31006/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;982003"982003/a /pp style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2028757"span style="background-color:yellow;"em2028757/em/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You can access the quot;Record Linkquot; table (2000000068) even though you do not have permissions for the table when you use the Standard security model in Microsoft Dynamics NAV 5.0 SP1 /span/ppspan style="font-size:8pt;background-color:yellow;"The value in the Permissions property is incorrect when you import a codeunit object by using the text format in Microsoft Dynamics NAV 5.0 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2.10/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31241/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb;en-us;2264893"2264893/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you use the Security Filters function in C/FRONT in Microsoft Dynamics NAV 5.0 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2.11/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"31510/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;2291512"2291512/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Microsoft Dynamics NAV does not release locks as expected when a RunModal error occurs in the client/span/p/td/tr/tbody/table/divpnbsp; nbsp;/ppstrongSome interesting version-specific links:/strong /pullia href="http://blogs.msdn.com/german_nav_developer/archive/2008/07/21/buildnummern-bersicht-microsoft-dynamics-5-0-service-pack-1.aspx"Summary of Dynamics NAV strong5.0 Sp1 Build Numbers/strong/aspan style="font-family:Times New Roman;font-size:12pt;" /span/lilia href="http://blogs.technet.com/gediminb/archive/2008/05/30/microsoft-dynamics-nav-5-0-sp1-latest-available-version-build.aspx"Summery of strongplatform updates for 5.0Sp1/strong/a /lilia href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;951518"Released strongcode fixes/strong for NAV 5.0 that are strongincluded in SP1/strong/a /lilia href="https://mbs.microsoft.com/partnersource/downloads/migrationtools/upgradeinformationmicrosoftdynamicsnav50sp1.htm?printpage=false"strongUpgrade Information/strong for Microsoft Dynamics strongNAV 5.0 SP1/strong/anbsp; /lilia href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$954191amp;wa=wsignin1.0"strongJobs update/strong for 5.0SP1./a It#39;s not a platform update, but rather important, so I just add it here... . /liliThere are strongnew installers (msi)/strong available for about all country versions. You can find more info a href="http://blogs.technet.com/gediminb/archive/2009/02/26/nav-5-0-new-installer-by-country-language-released-kb-957397.aspx"here/a or on a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$957397amp;wa=wsignin1.0"KB957397/a. It corrects the error message quot;strongThe Windows Installer service cannot update the system file c:WINDOWSsystem32msxml6r.dll/strongquot;. /lilia href="https://mbs.microsoft.com/partnersource/support/selfsupport/hottopics/NAV500SP1PlatformHotfixOverview"Overview of strongReleased Platform Hotfixes/strong for strongMicrosoft Dynamics NAV 5.0 SP1/strong/a (strongPartnersource/strong) /lilidiva href="https://mbs.microsoft.com/customersource/support/selfsupport/hottopics/NAV500SP1PlatformHotfixOverview"Overview of strongReleased Platform Hotfixes/strong for strongMicrosoft Dynamics NAV 5.0 SP1/strong/a (strongCustomersource/strong) /divpnbsp; nbsp;/p/li/uldivtable border="0" style="border-collapse:collapse;"colgroupcol style="width:67px;"/colcol style="width:91px;"/colcol style="width:76px;"/colcol style="width:88px;"/colcol style="width:316px;"/col/colgrouptbody valign="top"trtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongVersion/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongUpdate/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongBuild No./strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:center;"strongKB number/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongInfo/strong/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/partnersource/downloads/releases/microsoftdynamicsnav50.htm?printpage=false"5.0/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"strong24199/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"nbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.1/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"24632/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$936885amp;wa=wsignin1.0"936885/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;Error when opening 4.x db in 5.x: quot;You do not have permission to modify the [Tablename] Tablequot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 0.2/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"25344/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$943581amp;wa=wsignin1.0"943581/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"All object info is unexpectedly updated after upgrade db to 5.0 (SQL Server)/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"25359/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYVLXUZLWUKKQPOVRVNMKXNYMVRUUTZVTMWWVWRUSPLQQTZXPQ"943858/aspan style="text-decoration:underline;" /span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;Platform update./span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.1/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"25560/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$945339amp;wa=wsignin1.0"945339/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error when renaming record: quot;you cannot rename a record because the new value is #39;#39;quot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.1b/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"25560/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;953245"953245/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"C/FRONT API stops responding when creating connection/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.2/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"25581/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$944919amp;wa=wsignin1.0"944919/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"quot;Two fields below must be the same type quot; or quot;No. xxxx is not defined in the contact profile answer tablequot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.3/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"25653/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$945349amp;wa=wsignin1.0"945349/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Locks are not released as expected/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.4/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"25684/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$945992amp;wa=wsignin1.0"945992/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Crash when processing messages from MSMQ/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.5/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"26026/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$948512amp;wa=wsignin1.0"948512/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Slow performance when running reports after client upgrade 4 to 5/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.6/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"26810/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$954342"954342/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"several issues when you set a filter in a list form/span /p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.7/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27241/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;957267"957267/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"NAV displays an incorrect character when using a DBCS character in a field/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.8/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27831/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;959911"959911/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The XML port adds unwanted characters when you export data in a double-byte character set (DBCS) environment in Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.9/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28007/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;960607"960607/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The characters that indicate an empty HTML cells are incorrect displayed as quot;amp;nbspquot; in Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.10/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28874/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;969125"969125/a /pp style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;969037"969037/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You experience slow performance when you restore some companies into a Microsoft SQL Server database in Microsoft Dynamics NAV 5.0 /span/ppspan style="font-size:8pt;"Microsoft Dynamics NAV 5.0 becomes unresponsive when you perform a search process in a list-type form/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.11/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28884/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;959158"959158/a /pp style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;969452"969452/a /pp style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;968679"968679/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you perform the Copylinks function by using a recordref-type variable in Microsoft Dynamics NAV 5.0: quot;Type conversion is not possible because one of the operators contains an invalid type. Record := Recordrefquot; /span/ppspan style="font-size:8pt;"The xRec and Rec are the same and the change log does not detect any changes when a record is changed from a sub form in Microsoft Dynamics NAV 5.0br /Error message when you change the properties of a key in the Cust. Ledger Entry table (21) in Microsoft Dynamics NAV 5.0: quot;3701,quot;42S02quot;,[Microsoft][ODBC SQL Server Driver][SQL Server]Cannot drop the index #39;CRONUS International Ltd_$Cust_ Ledger Entry.$6#39;quot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.12/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29083/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;970913"970913/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The card form does not show the detailed information for the record in a list form in Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.13/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29178/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$970256amp;wa=wsignin1.0"970256/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 5.0 client crashes if you receive an error message when you try to close a form/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.14/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29379/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;973133"973133/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Some printers are not displayed in Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.15/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29410/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;973045"973045/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 5.0 client crashes when you use the Error function in the OnCloseForm trigger/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.16/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29729/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;974798"974798/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The fast forward-only pointer replaces the dynamic pointer when you run the Microsoft SQL Server Option for Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.17/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29736/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;975673"975673/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Microsoft Dynamics NAV 5.0 crashes when you open too many dialog boxes/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.18/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30407/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;978080"978080/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You cannot know whether the RecRef object is already opened or not in Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.19/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30550/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$978893amp;wa=wsignin1.0"978893/abr /a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$979210amp;wa=wsignin1.0"979210/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Some transactions are rolled back without an error message if SHOWPLAN permissions are revoked from the $ndo$shadow application role in Microsoft Dynamics NAV 5.0br /Error message when you use the Global Filter group feature in Microsoft SQL Server Option for Microsoft Dynamics NAV 5.0 Service Pack 1: quot;The FlowField value cannot be calculatedquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.20/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30584/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;980070"980070/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"A header table cannot show all calculations if there are more than 20 flowfields in the Microsoft SQL Server Option for Microsoft Dynamics NAV 5.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1.21/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30668/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;979889"979889/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The NtAuthentication parameter is ignored when you use a shortcut to start Microsoft Dynamics NAV 5.0/span/p/td/tr/tbody/table/divpstrongSome interesting version-specific links:/strong /pullia href="https://mbs.microsoft.com/Cms/Templates/document/General.aspx?NRMODE=Publishedamp;NRNODEGUID=%7bCBAF42F8-2EAE-41CF-8037-88215E81C296%7damp;NRORIGINALURL=/customersource/documentation/setupguides/InstallationManualsMicrosoftDynamicsNav50amp;NRCACHEHINT=Guestamp;wa=wsignin1.0"strongInstallations manuals/strong for Microsoft Dynamics NAV 5.0/a span style="font-family:Times New Roman;font-size:12pt;"/span/lilia href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$942793amp;wa=wsignin1.0"How to set up stronge-mail logging/strong in NAV5.0/a /lilia href="https://mbs.microsoft.com/partnersource/products/navision/50vpc.htm?printpage=false"strongDemo Center/strong for Microsoft Dynamics NAV 5.0 W1/a. Here you can find some demo VPC#39;s. /lilidiva href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$941551amp;wa=wsignin1.0"Released strongplatform hotfixes/strong and strongrollup updates/strong for NAV 5.0/a /divpnbsp; nbsp;/p/li/uldivtable border="0" style="border-collapse:collapse;"colgroupcol style="width:68px;"/colcol style="width:109px;"/colcol style="width:76px;"/colcol style="width:88px;"/colcol style="width:297px;"/col/colgrouptbody valign="top"trtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongVersion/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongUpdate/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongBuild No./strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongKB number/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongInfo/strong/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/partnersource/downloads/servicepack/microsoftdynamicsnav40sp3.htm?printpage=false"4.0 SP3/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"strong25143/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:9pt;"Update 1nbsp;/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="font-size:9pt;"24080/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYLSVQUSPTNTNSMQPYLPMTZVVOMOMMVUNNMKSRNMLPQZMRXRPX"span style="font-size:9pt;"931841/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;included in 4.0SP3!*/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:9pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:9pt;"Update 2 ndash; NODBC/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:9pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:9pt;"Not released/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;included in 4.0SP3!*/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:9pt;"Update 3nbsp;/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="font-size:9pt;"24219/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYLSVQUSPTNTNSMQPYYZPOPPTWYTOMVZVKMZOSXQKURZWPUNXK"span style="font-size:9pt;"933727/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;included in 4.0SP3!*/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:9pt;"Update 4nbsp;/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="font-size:9pt;"24449/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYLSVQUSPTNTNSMQPYMWLROTUWRPQURMYTXUTLXMNXXPQYWXNV"span style="font-size:9pt;"936602/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;included in 4.0SP3!*/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:9pt;"Update 5nbsp;/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="font-size:9pt;"24734/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYLSVQUSPTNTNSMQPYZSKYSLKSOYRQQOLULTSSPRYLPNPVNURN"span style="font-size:9pt;"938138/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;included in 4.0SP3!*/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:9pt;"Update 6nbsp;/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"span style="font-size:9pt;"25143/span/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYVLXUZLWUKKQPOVRVWNOPOZYYWXTLWRLLNOKLZRYYWSZOSTVP"span style="font-size:9pt;"940718/span/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;included in 4.0SP3!*/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.1/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"25307/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$943227amp;wa=wsignin1.0"943227/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"F4 Delete function behaves inconsistently when pressing CTRL+A to select all records/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.2/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"25638/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$945349amp;wa=wsignin1.0"945349/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Locks are not released as expected/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.3/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"25709/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$946247amp;wa=wsignin1.0"946247/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"NAV crashes when saving an object with large amount of text constants/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.4/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"25726/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$945992amp;wa=wsignin1.0"945992/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Crash when processing messages from MSMQ/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.5/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"25732/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$945339amp;wa=wsignin1.0"945339/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error when renaming record: quot;you cannot rename a record because the new value is #39;#39;quot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.6/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"26033/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$948302amp;wa=wsignin1.0"948302/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"NAS stops responding to events when a lock timeout occurs/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.7/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"26170/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$949866amp;wa=wsignin1.0"949866/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"NAV ignores specified printer tray selection when printing a file from second page or later/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.8/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"26410/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$950920amp;wa=wsignin1.0"950920/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Slow performance when browsing a list in a form/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.9/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"26565/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$952355amp;wa=wsignin1.0"952355/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Dynamics NAV client stops respoding when NAV calcs a SIFT/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.10/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"26708/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$952873"952873/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you open a company in NAV 4.0: quot;Property exceeds the buffer sizequot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.11/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"26752/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;953313"953313/a /p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"?????????????????/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.12/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27010/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;954342"954342/a /pp style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;954722"954722/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Several issues when filtering an list form/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.13/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27256/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;957275"957275/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"NAV crashes on citrix if captions contain an ampersand/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.14/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27742/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;959165"959165/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Inconsistent behavior when you search for the quot;RecordRefquot; data type records in different Windows operating systems and Microsoft Dynamics NAV versions/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.15/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27765/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;EN-US;959822"959822/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error when printing a report: #39;FORM NAME#39; cannot close because the system is currently working/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.16/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"27857/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;959656"959656/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error when lock time-out occurs: quot;Function sequence errorquot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.17/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28477/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;965225"965225/a /pp style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;965224"965224/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The characters that indicates an empty HTML cells are incorrect displayed as quot;amp;nbspquot; in Microsoft Dynamics NAV 4.0 Service Pack 3 (SP3) /span/ppspan style="font-size:8pt;"Memory is not released when you open a new company in Microsoft Dynamics NAV 4.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.18/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"28541/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;967469"967469/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you open a table in the Design mode in Microsoft Dynamics NAV 4.0: quot;Error 2 in module 5quot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.19/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29021/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$970383amp;wa=wsignin1.0"970383/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The BLOB data type cannot be performed on the RecordRefs object in Microsoft Dynamics NAV 4.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.20/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29113/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;971172"971172/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Slow performance when you apply a filter to a form that is based on a large table in Microsoft Dynamics NAV 4.0 Service Pack 3 and Microsoft Dynamics NAV 5.0 Service Pack 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.21/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29723/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;975345"975345/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The last Outstream.Writetext statement is not considered by the string.LEN function or the string.TRUNC function in Microsoft Dynamics NAV 4.0/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.22/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29821/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;975988"975988/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You experience slow performance when you browse some forms in Microsoft Dynamics NAV 4.0 with Service Pack 3/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.23/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"29961/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;976327"976327/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"The Microsoft Dynamics NAV 4.0 client crashes when you delete a record in a List form by right-clicking Delete/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.24/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30033/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;976911"976911/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you try to change a table that has a primary key field defined by using Variant as the SQL data type in Microsoft Dynamics NAV 4.0: quot;Invalid cursor statequot;/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.25/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30377/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb$en-us$978895amp;wa=wsignin1.0"978895/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"You experience slow performance when you restore some companies into a Microsoft SQL Server database in Microsoft Dynamics NAV 4.0 SP3/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 6.26/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"30698/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;978786"978786/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"All printers in network are displayed when you run Microsoft Dynamics NAV 4.0 Service Pack 3 on a terminal server/span/p/td/tr/tbody/table/divpstrongSome interesting version-specific links:/strong /pullidiva href="http://blogs.msdn.com/german_nav_developer/archive/2008/06/23/buildnummern-bersicht-microsoft-dynamics-4-0-service-pack-3.aspx"Summary of Dynamics NAV strong4.0 Service Pack 3 Build Numbers/strong/aspan style="font-family:Times New Roman;font-size:12pt;" /span/divpnbsp; nbsp;/p/li/uldivtable border="0" style="border-collapse:collapse;"colgroupcol style="width:68px;"/colcol style="width:132px;"/colcol style="width:77px;"/colcol style="width:88px;"/colcol style="width:273px;"/col/colgrouptbody valign="top"trtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongVersion/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongUpdate/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongBuild No./strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongKB number/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongInfo/strong/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/partnersource/downloads/releases/microsoftbusinesssolutionsnavision40sp2.htm?printpage=false"4.0 SP2/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"strong22100/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"22611/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYUSKWOTVUNVLMRYSKWZKVXWYKLTLSNTMRNZRMNKOZVVTORMR"919407/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2 ndash; NODBC/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"22851/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYKORSXPPNNWUNVVRWZRRQZSLKSKSWSRRXZXMKXROMTNLQYVQN"921893/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 3nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"23099/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYKORSXPPNNWUNVVRWSZNVNNVWTPNWOOYTYTOYZPVKNMZPQXKO"922695/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 4 ndash; NODBCnbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"23460/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYKORSXPPNNWUNVVRWMTVWVYVWWLXSMXLMTTPVWVSZVVTSLNNL"927113/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Update 3/span/p/td/tr/tbody/table/divpnbsp; nbsp;/pdivtable border="0" style="border-collapse:collapse;"colgroupcol style="width:68px;"/colcol style="width:132px;"/colcol style="width:77px;"/colcol style="width:88px;"/colcol style="width:273px;"/col/colgrouptbody valign="top"trtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongVersion/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongUpdate/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongBuild No./strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongKB number/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongInfo/strong/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/partnersource/downloads/releases/nav40sp1w1.htm?printpage=false"4.0 SP1/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"strong21666/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"21990/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYUSKWOTVUNVLMRYSNKPSLYXTRVKMYNNOZPNKPOWXQZQWTUNX"913523/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2 ndash; NODBCnbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"22373/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYUSKWOTVUNVLMRYSNVKVMLZNZTTWYVLTPXMWOULQRTMZKPOV"912791/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 3nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"22363/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYYUSKWOTVUNVLMRYSZUQPZNTOXPKXPXSVOLNQVNTWTRMPMTMQ"915455/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/tr/tbody/table/divpnbsp; nbsp;/pdivtable border="0" style="border-collapse:collapse;"colgroupcol style="width:67px;"/colcol style="width:74px;"/colcol style="width:76px;"/colcol style="width:88px;"/colcol style="width:332px;"/col/colgrouptbody valign="top"trtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongVersion/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongUpdate/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongBuild No./strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongKB number/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongInfo/strong/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/partnersource/products/navision/downloads/releases/6c38ecf3-6452-4c11-b6d8-62fdff4cbbc7.htm?printpage=false"4.0/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"strong19365/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"20942/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYKKQRRUZVRPSSXNSNKLSPVXYOVWLQKOYYYUZKSXRKNZOSNYNL"890551/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 2/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"21871/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?WTNTZSMNWUKNTMMYKOYVTOLQWXPSLWRZSQYRQNLMTLRMVVSNMPZWTTOQWQSKLMRZ"908918/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Update 1/span/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 3/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"21990/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;911653"911653/a /pp style="text-align:right;"a href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;911654"911654/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"Error message when you paste selected records from a form to a table that has the property quot;PasteIsValid=Noquot; in Microsoft Navision: quot;You are not allowed to paste in this tablequot; /span/ppspan style="font-size:8pt;"You are prompted to convert the database every time that you open a database in a client installation of Microsoft Navision 4.0 Service Pack 1/span/p/td/tr/tbody/table/divpnbsp; nbsp;/pdivtable border="0" style="border-collapse:collapse;"colgroupcol style="width:67px;"/colcol style="width:74px;"/colcol style="width:77px;"/colcol style="width:88px;"/colcol style="width:331px;"/col/colgrouptbody valign="top"trtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongVersion/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongUpdate/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongBuild No./strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongKB number/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:solid #a3a3a3 1.0pt;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pstrongInfo/strong/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pa href="https://mbs.microsoft.com/partnersource/products/navision/downloads/releases/navision370brelease.htm?printpage=false"3.70.B/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"strong19516/strong/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/trtrtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:solid #a3a3a3 1.0pt;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pnbsp;nbsp;/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pUpdate 1/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"19868/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"p style="text-align:right;"a href="https://mbs2.microsoft.com/Knowledgebase/KBDisplay.aspx?scid=kb$en-us$890640amp;wa=wsignin1.0"890640/a/p/tdtd style="padding-top:5px;padding-left:5px;padding-bottom:5px;padding-right:5px;border-top:none;border-left:none;border-bottom:solid #a3a3a3 1.0pt;border-right:solid #a3a3a3 1.0pt;"pspan style="font-size:8pt;"nbsp;/spannbsp;/p/td/tr/tbody/table/divp style="margin-left:54pt;"nbsp; nbsp;/ppstrongManuals/strong /pullia href="https://mbs.microsoft.com/partnersource/documentation/userguides/MSDNAVlocalfunct"Microsoft Dynamics NAV strongLocal Functionality/strong/aspan style="font-family:Times New Roman;font-size:12pt;" /span/li/ulpstrongProduct Information/Updates/strong /pullia href="https://mbs.microsoft.com/knowledgebase/KBDisplay.aspx?scid=kb;en-us;940494"Update of the ADCS feature.../aspan style="font-family:Times New Roman;font-size:12pt;" /span/lilia href="https://mbs.microsoft.com/Cms/Templates/document/General.aspx?NRMODE=Publishedamp;NRNODEGUID=%7b2D497826-49DE-4952-9820-9519BA04237A%7damp;NRORIGINALURL=/partnersource/support/selfsupport/taxupdates/MSD_NAV2010VATSupportEUamp;NRCACHEHINT=Guestamp;wa=wsignin1.0"Microsoft Dynamics NAV strongVAT 2010 Support/strong/a /li/ulpstrongInteresting downloads:/strong /pullidivMicrosoft strongDynamics Mobile/strong: span style="font-family:Times New Roman;font-size:12pt;"/span/divullia href="https://mbs.microsoft.com/partnersource/downloads/releases/dynamicsmobileversion11.htm?printpage=false"Product Release/a /lilia href="https://mbs.microsoft.com/partnersource/downloads/releases/dynamicsmobilev1.1_eval.htm?printpage=false"Evaluation edition/a /li/ul/lilia href="https://mbs.microsoft.com/partnersource/downloads/migrationtools/databasearchiveformicrosoftnavisionna.htm?printpage=false"strongDatabase Archive/strong for Microsoft Dynamics NAV/a: You need a db from Navision Financials 1.00? You can find it here.. . /lilia href="https://mbs.microsoft.com/partnersource/downloads/migrationtools/northamericanmicrosoftnavisionupgrade_toolkitarchive.htm?printpage=false"strongUpgrade Toolkit Archive/strong for Microsoft Dynamic NAV/a: really cool site to give you access to all info you need to update form very early versions (Navision Financials 1.00) to 5.00 SP1. /lilia href="https://mbs.microsoft.com/Cms/Templates/document/General.aspx?NRMODE=Publishedamp;NRNODEGUID=%7b9D5BBD5F-BD25-4FE7-A5F6-F209AC9253B5%7damp;NRORIGINALURL=/partnersource/newsevents/news/newsgeneral/dynnavtoolsoverview.htm?printpage=falseamp;NRCACHEHINT=Guestamp;printpage=falseamp;wa=wsignin1.0"Microsoft Dynamics NAV strongTools Overview/strong/a: an overview of all Microsoft Dynamics Nav related tools, like: Tools CD, Upgrade Toolkit, Database Resource Kit, Developer#39;s Toolkit, hellip; /lilia href="https://mbs.microsoft.com/partnersource/marketing/campaigns/advertising/MSDYNAV2009_MaterialsMegaMap"strongMegamap/strong for Dynamics NAV 2009 Materials/a /li/ulpstrongBlogs:/strong /pullia href="https://mbs.microsoft.com/public/insights/ReadArticle.aspx?rcpt_id=15989386amp;ja_id=47722"strongMicrosoft Dynamics NAV Team Blog/strong/aspan style="font-family:Times New Roman;font-size:12pt;" /span/lilia href="https://mbs.microsoft.com/public/insights/ReadArticle.aspx?rcpt_id=15989386amp;ja_id=47723"strongNAV Reporting Blog/strong/a /lilia href="https://mbs.microsoft.com/public/insights/ReadArticle.aspx?rcpt_id=15989386amp;ja_id=47724"strongSustained Engineering Team Blog/strong/a /lilia href="https://mbs.microsoft.com/public/insights/ReadArticle.aspx?rcpt_id=15989386amp;ja_id=47725"strongNAV Developer Blog/strong/a /lilia href="https://mbs.microsoft.com/public/insights/ReadArticle.aspx?rcpt_id=15989386amp;ja_id=47726"strongClausl#39;s Dynamics NAV Blog/strong/a /lilia href="http://navigateintosuccess.com/"strongNavigate Into Success/strong/a /lilia href="http://blogs.msdn.com/freddyk/default.aspx"strongFreddys Blog/strong/a /lilia href="http://plataan.typepad.com/microsoftdynamics/"strongPlataan#39;s Blog/strong/a /lilia href="http://dynamicsuser.net/blogs/Kine/"strongKine#39;s Info/strong/a /lilia href="http://dynamicsuser.net/blogs/mark_brummel/default.aspx"strongMark Brummel#39;s Blog/strong/a /li/ulpstrongOther interesting links:/strong /pullia href="https://mbs.microsoft.com/customersource/support/selfsupport/hottopics/kb__nav"strongKB articles/strong that were added in January 2008, February 2008 and March 2008/a span style="font-family:Times New Roman;font-size:12pt;"/span/lilia href="https://premier.microsoft.com/default.aspx?scid=kb%3ben-us%3b941551"Updates for general distribution for NA version of Microsoft Dynamics NAV/a /lilidiva href="https://mbs.microsoft.com/Cms/Templates/document/General.aspx?NRMODE=Publishedamp;NRNODEGUID=%7bA156A710-4A47-4693-A568-8A3FA1AA3807%7damp;NRORIGINALURL=/partnersource/newsevents/news/rssfeeds.htmamp;NRCACHEHINT=Guest"Microsoft Dynamics PartnerSource strongRSS Feeds/strong/a: Most interesting (imho) are: /divullia href="https://mbs.microsoft.com/downloads/public/rss/KB_Newest_NAV.xml"RSS feed for the strongmost recent Knowledge Base Articles/strong/a /lilia href="https://mbs.microsoft.com/downloads/public/rss/PS_NAV_News.xml"RSS feed for strongMicrosoft Dynamics NAV News/strong/a /li/ul/lilia href="https://mbs.microsoft.com/partnersource/resources/support/supportinformation/microsoftdynamicsnavsupportnorthamerica.htm"North American Support Site for Microsoft Dynamics/a (A LOT of links to find about NAV 5.0, NAV 5.0 SP1, NAV2009, SQL Server, Security, ...) /lilidivMore information about strongCertified for Microsoft Dynamics:/strong /divullia href="https://mbs.microsoft.com/partnersource/sales/salestools/productfactsheets/CertifiedforMicrosoftDynamics.htm"Fact Sheet/a /lilia href="https://mbs.microsoft.com/partnersource/newsevents/news/newsgeneral/CertifiedforMicrosoftDynamics.htm"List of current certified products/a /lilia href="http://www.microsoft.com/dynamics/partners/dynamicssolutionDirectory.mspx?Product=085b757b-88c9-443c-8f5a-ccbeee325909"Microsoft Dynamics Solution Finder/a for detailed solution descriptions /lilia href="http://www.microsoft.com/dynamics/partners/cfmd.mspx"Customer information/a /li/ul/lilia href="https://mbs.microsoft.com/knowledgebase/search.aspx"strongKnowledgebase Search Engine/strong/a /lilidiva href="http://msdn.microsoft.com/en-us/dynamics/bb467598.aspx"strongNAV 2009 Developer and IT Pro Help is on MSDN/strong/a /divpnbsp; nbsp;/p/li/ulpstrongRemarks/strong /pulliThe text in italic and yellow means that that peace was added or changed since last update.span style="font-family:Times New Roman;font-size:12pt;" /span/li/uldiv style="clear:both;"/divimg src="http://dynamicsuser.net/aggbug.aspx?PostID=203416" width="1" height="1"
Читать дальше
Часовой пояс GMT +3, время: 11:02.
Powered by vBulletin® v3.8.5. Перевод: zCarot
Контактная информация, Реклама.
