Старый 19.07.2016, 00:11   #1
emeadaxsupport: Data Management Framework: Export fails with no apparent details on the cause
Источник: https://blogs.msdn.microsoft.com/axs...-on-the-cause/
In a recent issue, a customer was reporting a problem exporting data using the data management framework. The issue was that during the export they were leaving the “Skip staging” option to “Yes”, which is the default option. When the export of the entity was run, it reported that it had failed and there seemed... Read more
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2009 SP1 Blog bot Dynamics CRM: Blogs 0 11.06.2010 16:33
Часовой пояс GMT +3, время: 14:27.
