Старый 30.09.2016, 22:13   #1
organicax: Vendor invoice with workflow and matching test
Источник: https://organicax.com/2016/09/30/ven...matching-test/
I’ve done a post in the past about pending vendor invoices and the basic flow. You can add some more control to that flow with invoice matching and workflow. For example if the invoices matches the purchase order it might not be worth getting the organization to spend time to approve this. If there is matching issues then it probably should go to someone for approval.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Accounts payable
DynamicsAxSCM: Creating Custom Solutions with the Warehouse Mobile Device Portal Blog bot DAX Blogs 0 13.03.2015 16:11
emeadaxsupport: AX Content: Procure-to-pay (P2P) workflow Blog bot DAX Blogs 0 23.09.2013 23:11
emeadaxsupport: Error message “The value ‘xxx’ is not found in the map” when opening Workflow configuration Blog bot DAX Blogs 0 10.02.2010 00:07
Microsoft Dynamics CRM Team Blog: Workflow E-mail Utilities Blog bot Dynamics CRM: Blogs 0 16.12.2008 23:05
Microsoft Dynamics CRM Team Blog: CRM 4: Waiting Workflow VS Windows Service Blog bot Dynamics CRM: Blogs 0 30.10.2008 00:06
Часовой пояс GMT +3, время: 22:32.
