Старый 04.02.2018, 17:15   #1
sunilrakesh: Import file from SharePoint to D365FO using Logic App
Источник: https://community.dynamics.com/membe...7-4713d1346791
Below example on logic apps integration for Share point – D365 Ops.
  • When you upload a .txt file on Share Point folder with customer details, using that file we can create new customer in D365 using Microsoft flow with less efforts. We can use same process for "Housing sol" custom data entities. Instead file system we can use this approach. And need to do more analysis with different scenarios.
.Txt file content:
{"CustAccount": "AZ000435",
         "Name": "From Azure Sun Test",
                 "Currency": "GBP",
                "CustomerGroup": "10"}
d365o, logic apps, интеграция
sunilrakesh: Export file from D365FO to OneDrive using LogicApp Blog bot DAX Blogs 0 04.02.2018 17:15
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 Blog bot NAV: Blogs 0 15.05.2016 18:12
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
DynamicsAxSCM: Import vendor catalogs: from setup to importing a sample catalog – Part 2 (Importing a sample catalog) Blog bot DAX Blogs 0 09.09.2012 20:15
Часовой пояс GMT +3, время: 08:25.
