Старый 03.08.2018, 11:12   #1
25,554 / 848 (80) +++++++
erconsult: Copy-paste with keyboard script 2: from Excel to D365FO
Источник: http://erconsult.eu/blog/copy-paste-...cel-to-d365fo/
Again an entity was missing in D365FO to import the data, this time a custom one. Building upon my work Copy-paste automation in D365 FO with a keyboard script, I created a Wunderwaffe script to copy a simple table with a Code and a Description directly from Excel into the D365FO browser window.
Close all other windows and put the browser with D365FO and Excel side by side. Place the cursor in Excel in the Code column at the first row to copy, then hit Ctrl-J. The script will start copying data from Excel and pasting records in D365FO by switching windows forth and back:
^j::
; --------- Place the focus on the code column in Excel, start with Ctrl-J
Loop 200 {
; --------- Copy the content of the Code from Excel
Send, ^c
Sleep, 500
; --------- Switch the window: Alt-Tab
Send, !{TAB}
Sleep, 1000
; --------- Create a new record in the D365FO window
Send, {Alt Down}
Sleep, 500
Send, n
Sleep, 500
Send, {Alt Up}
Sleep, 1000
; --------- Go to the next field and back in the D365FO to get into the edit mode
Send, {TAB}
Sleep, 1000
Send, +{TAB}
; --------- Paste the code
Send, ^v
; --------- Switch the window and go back to Excel
Send, !{TAB}
Sleep, 1000
; --------- Copy the content of the Description column from Excel
Send, {Right}
Send, ^c
Sleep, 1000
; --------- Switch the window for D365FO
Send, !{TAB}
Sleep, 1000
Send, {TAB}
Sleep, 500
; --------- Paste the description
Send, ^v
; --------- Switch the window for Excel
Send, !{TAB}
Sleep, 1000
; ---------Scroll down to the next record, and repeat the cycle
Send, {Down}{Left}
Return
; Press F1 in panic
F1::ExitApp
The post Copy-paste with keyboard script 2: from Excel to D365FO appeared first on ER-Consult.
stoneridgesoftware: Are You Using Copy & Paste in Dynamics NAV? You Should! Blog bot NAV: Blogs 0 08.03.2018 19:16
emeadaxsupport: Calling AX 2012 Business Logic from SSIS Using a Script Task and Custom Web Service Blog bot DAX Blogs 0 12.11.2015 03:48
Malaysia: AX SSRS - copy report design from one VS to another VS Blog bot DAX Blogs 0 16.02.2015 08:11
Kine: Copy Microsoft Dynamics NAV company by SQL script into another database Blog bot Dynamics CRM: Blogs 0 18.10.2013 10:07
Dynamics AX: Calling an Excel Macro from X++ Blog bot DAX Blogs 1 26.05.2008 16:39
Часовой пояс GMT +3, время: 15:31.
Powered by vBulletin® v3.8.5. Перевод: zCarot
Контактная информация, Реклама.
