Старый 29.08.2018, 20:16   #1
d365technext: Generate class from SQL database table
Источник: http://d365technext.blogspot.com/201...ase-table.html
declare @TableName sysname = 'BANKACCOUNT'
declare @Result varchar(max) = 'public class ' + UPPER(LEFT(@TableName,1))+LOWER(SUBSTRING(@TableName,2,LEN(@TableName))) + 'Entity
select @Result =@Result + '
public ' + ColumnType + NullableSign + ' ' + ColumnName + ' { get; set; }
from
select
replace(col.name, ' ', '_') ColumnName,
column_id ColumnId,
casetyp.name
when'bigint' then 'long'
when'binary' then 'byte[]'
when'bit' then 'bool'
when'char' then 'string'
when'date' then 'DateTime'
when'datetime' then 'DateTime'
when'datetime2' then'DateTime'
when'datetimeoffset' then'DateTimeOffset'
when'decimal' then 'decimal'
when'float' then 'float'
when'image' then 'byte[]'
when'int' then 'int'
when'money' then 'decimal'
when'nchar' then 'char'
when'ntext' then 'string'
when'numeric' then 'decimal'
when'nvarchar' then 'string'
when'real' then 'double'
when'smalldatetime' then'DateTime'
when'smallint' then 'short'
when'smallmoney' then'decimal'
when'text' then 'string'
when'time' then 'TimeSpan'
when'timestamp' then'DateTime'
when'tinyint' then 'byte'
when'uniqueidentifier' then'Guid'
when'varbinary' then'byte[]'
when'varchar' then 'string'
else'UNKNOWN_' + typ.name
endColumnType,
case
whencol.is_nullable =1 and typ.name in('bigint', 'bit', 'date', 'datetime', 'datetime2', 'datetimeoffset', 'decimal', 'float', 'int', 'money', 'numeric', 'real', 'smalldatetime', 'smallint', 'smallmoney', 'time', 'tinyint', 'uniqueidentifier')
then'?'
else''
endNullableSign
from sys.columns col
join sys.types typ on
col.system_type_id = typ.system_type_id AND col.user_type_id = typ.user_type_id
where object_id= object_id(@TableName)
) t
order byColumnId
set @Result =@Result +'
print @Result
public class BankaccountEntity
public int ID { get; set; }
public string BANK { get; set; }
public string ROUNTINGNUM { get; set; }
public string CURRENCY { get; set; }
public string ACCOUNTNUM { get; set; }
public int? MAINACCOUNTID { get; set; }
public string IBAN { get; set; }
public string SWIFT { get; set; }
public string BRANCH { get; set; }
public string CONTACTPERSON { get; set; }
public string CONTACTPHONE { get; set; }
public string CONTACTEMAIL { get; set; }
public bool? STATUS { get; set; }
Kine’s info: Copy Microsoft Dynamics NAV company by SQL script into another database v2 Blog bot NAV: Blogs 0 15.05.2016 17:11
dax-lessons: SysFieldGroupLookup class in AX 2012–lookup from Table FieldGroups[X++] Blog bot DAX Blogs 0 05.04.2012 00:14
NAV Team: Multiple Record Corruption on a Native Database: The “Table Isolation” Trick Blog bot Dynamics CRM: Blogs 0 05.08.2010 22:06
wiki.dynamicsbook: Changes Made in Navision Financials 2.00 Blog bot Dynamics CRM: Blogs 0 02.09.2008 14:47
Часовой пояс GMT +3, время: 17:56.
