Старый 26.07.2019, 18:12   #1
25,643 / 848 (80) +++++++
a33ik: SSRS display static row as header at each page
Источник: http://daxonline.org/1652-ssrs-displ...each-page.html
Static row as header
  1. Select tablix.
  2. On the right side of the Grouping pane, click the down arrow, and then click Advanced Mode.
  3. Click the static member that corresponds to the static member (row or column) that you want to remain visible while scrolling. The Properties pane displays the Tablix Member properties.
  4. In the Properties pane, set RepeatOnNewPage to True.
  5. Set KeepWithGroup to After.
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
kamalblogs: SSRS Tips: Combating Blank Page in SSRS Reports – Dynamics AX 2012 Blog bot DAX Blogs 0 08.11.2013 08:11
kamalblogs: Error: SSRS/EP error when the return type in display method is incorrect – Dynamics AX 2012 Blog bot DAX Blogs 0 11.10.2013 12:11
kamalblogs: SSRS Tip: Printing Row headers in every page – Dynamics Ax 2012 Blog bot DAX Blogs 0 23.09.2013 16:12
Часовой пояс GMT +3, время: 13:59.
