11.07.2023, 19:13 | #1 |
Alexdmeyer: Apply Environment Update to D365FO via Command Line
Источник: https://alexdmeyer.com/2023/07/11/ap...-command-line/
============== Following up on my previous post about deploying a local VHD of D365FO, I wanted to show how you can then update your environment when Microsoft releases newer versions. The first step is to download the update deployable package from LCS by navigating to the Shared Asset Library: Then navigating to the ‘Software Deployable Package’: […] The post Apply Environment Update to D365FO via Command Line appeared first on Alex Meyer. Источник: https://alexdmeyer.com/2023/07/11/ap...-command-line/
