13.03.2008, 19:05 | #1 |
axStart: When is my Label file updated in AX?
Источник: http://axstart.spaces.live.com/Blog/...C0A0!269.entry
============== If we look at our label files in the AOT we see 3 different extensions for our labels · ALI Axapta Label Index · ALC Axapta Label Cache · ALD Axapta Label Dictionary The ALD file is readable/edible whit a text editor. General speaking you only need the ALD file. When the AOS is restarted the ALI and ALC will be generated on the fly. Next a developer will create new labels. These labels will be stored in the ALI file. Not yet in the ALD file. When the final AOS will stop. AX will update the ALD file this way. It will copy the ALD file to an ALB file. Next the changes in the ALI file will be stored in the ALB file. Finally this ALB file is placed back in the ALD file and the ALB file will be deleted. (HINT: make the ALD file read only and you will see it your selfJ) When your AOS has creased the changes are not stored in the ALD file. Even when you start and stop the AOS again the file is not updated. To solve this issue start an AX client search for the label in the Label editor. Next stop your client and the AOS. Now the label file is updated. Источник: http://axstart.spaces.live.com/Blog/...C0A0!269.entry
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
Теги |
alb, alc, ald, ali, alt, label, метки |
Опции просмотра | |
