Старый 17.07.2008, 20:05   #1
gatesasbait: Dynamics AX 2009 Report Deployment error
Источник: http://gatesasbait.spaces.live.com/B...B9F5!239.entry
Good morning
If you get either of the following two errors when deploying SQL Reports from Dynamics AX 2009 over to SQL Reporting services, you may have a bad parameter in file \Program Files\Microsoft SQL Server\MSSQL.3\Reporting Services\ReportServer\rsreportserver.config. (might be in ...\MSSQL.2\... sometimes)
The parameter needs to have the value corresponding to the web site containing the Reports and ReportServer virtual folders. Error #1 is caused when your Sharepoint EP is installed on the same server at port 80, and when you have the default url value in rsreportserver.config. Error #2 is clearer.
Error #1
____________________________
Error: Deployment failed unexpectedly with the message:
Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml'.
The request failed with the error message:
[snip…]
                   File Not Found.
<span class="ms-descriptiontext">
                                Troubleshoot issues with Windows SharePoint Services.
[snip…]
See the log file for further details.
Deployment failed with the following exception:
System.InvalidOperationException: Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml'.
[snip…]
Error #2
Deploying 0 data source(s) and 1 design(s) in 40 culture(s) (40 item(s) total)...
Unable to connect to http://xxxx:xxxx/reportserver/ReportService2005.asmx as specified in the config file for the report server at c:\Program Files\Microsoft SQL Server\MSSQL.2\Reporting Services\ReportServer\RSReportServer.config. If this url is not correct please update the config file, otherwise make sure the report server is configured correctly.
The deployment log file can be found at "C:\Documents and Settings\Administrator\Local Settings\Temp\tmp4.txt"
Good luck!
gatesasbait: Dynamics Ax 2009 SSRS report deployment under Server 2008 (deux) Blog bot DAX Blogs 0 11.02.2009 23:05
gatesasbait: Dynamics Ax 2009 SSRS report deployment under Server 2008 Blog bot DAX Blogs 0 11.02.2009 11:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Часовой пояс GMT +3, время: 12:27.
