Старый 22.01.2007, 17:24   #1
oleg_e is offline
oleg_e
Angry Установка Ax 4.0
Установка axapta 4.0 завершилпась неудачно. Не были установлены Aos и Client.
Пробовал и интернационалбную версию и sp1. Привожу сообщения (только при возникновенни ошибок) в логе по установке.
У кого какие мысли?
AOS.1: Regasm C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\regasm.exe "D:\Program Files\Microsoft Dynamics AX\40\Server\Ax4_Demo\Bin\Microsoft.Dynamics.IntegrationFramework.dll"
RegAsm error: Failed to load 'D:\Program Files\Microsoft Dynamics AX\40\Server\Ax4_Demo\Bin\Microsoft.Dynamics.IntegrationFramework.dll' because it is not a valid .NET assembly
Error during setup of Object server.. Reason: Error unregistering Microsoft.Dynamics.IntegrationFramework.dll. Program run: C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\regasm.exe. Parms: "D:\Program Files\Microsoft Dynamics AX\40\Server\Ax4_Demo\Bin\Microsoft.Dynamics.IntegrationFramework.dll" /unregister
=== Setting up Client ===
Launching MSI: /i "E:\MS Dynamics AX 4.0 International\AXAPTA40_International\Msi\Client\Client.msi" /qb-! /l*v "C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2007-01-22 16-21-17\Client Log.txt" DIRECTEXECUTE=1 INSTALLDIR="D:\Program Files\Microsoft Dynamics AX\40\Client" CLIENTAOSSERVER="OLEG" INSTALLLANGUAGE="EN-US" LICENSE=EN-US AOS2="Ax4_Demo@OLEG" ADDLOCAL="hENUS,Debugger,License,Config"
Client.1: regasm "D:\Program Files\Microsoft Dynamics AX\40\Client\Bin\Microsoft.Dynamics.AnalysisServices.dll"
RegAsm error: Failed to load 'D:\Program Files\Microsoft Dynamics AX\40\Client\Bin\Microsoft.Dynamics.AnalysisServices.dll' because it is not a valid .NET assembly
Error during setup of Client.. Reason: Error unregistering "D:\Program Files\Microsoft Dynamics AX\40\Client\Bin\Microsoft.Dynamics.AnalysisServices.dll". Program run: C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\regasm.exe. Parms: "D:\Program Files\Microsoft Dynamics AX\40\Client\Bin\Microsoft.Dynamics.AnalysisServices.dll" /unregister
С уваженеим, Олег
Старый 22.01.2007, 17:35   #2
George Nordic is offline
George Nordic
Аватар для George Nordic
4,479 / 1250 (50) ++++++++
Записей в блоге: 9
Какая система?
Для начала поставьте только:
Database
File Server
Application Server
Client
Старый 22.01.2007, 17:50   #3
oleg_e is offline
oleg_e
так и делал все по инструкцие, которая была ранее на форуме.
Сейчас попробовал на другом компе - там все OK.
На что ставил и там и там- XP SP2, MSSQL2005 (Instance Oleg\MSSQL2005) с SP1.
И там и там Framework 1 и 2... Где зарыта собака, не понимаю...
Старый 22.01.2007, 20:11   #4
AlexSD is offline
AlexSD
Microsoft Dynamics
257 / 302 (11) ++++++
Попробуйте переставить фреймворки. У меня примерно подобное было. Вылечилось полным сносом и переустановкой. Какие-то очередные апдейты криво поставились.
Старый 29.01.2007, 20:02   #5
RS is offline
RS
Аватар для RS
53 / 13 (1) ++
Поисчите на Майкрософтовском сайте инструкцию по установке 4.0. Она с хитростью о которой ни кто не упоминает - последовательно настраивать Винду и частями устанавливать АХАРТА. Некоторые настройки необходимо выполнить еще до инсталяции АОСа и Клиента. В том числе и версия Фреймворка на ИИС (АСП).
ax4.0
Arijit Basu: Reporting & BI in AX: An Overview [Level 100] Blog bot DAX Blogs 0 07.01.2008 16:01
Часовой пояс GMT +3, время: 18:17.
