Старый 05.03.2009, 06:16   #1
Solutions Monkey: Multiple AxDataSource Controls in one .ascx control
Источник: http://blogs.msdn.com/solutions/arch...x-control.aspx
If you have more than one AxDataSource control in one user control , make sure you mark the Role property of all but one AxDataSource controls to anything other than “Provider” or “ProviderConsumer”. Otherwise you will get an error.
In one usercontrol , only one AxDataSource control could provide the context to other controls and web parts. So only one can have the provider role.
By default the Role Property of the AxDataSource control is set to "ProviderConsumer" . So if you have more than one control with the default set of properties. you will get Specified method is not supported error. To fix this change the role to None or Consumer.
Solutions Monkey: How to use Chart Control in EP 2009? Blog bot DAX Blogs 0 02.04.2009 09:05
Solutions Monkey: EP Page Life Cycle Blog bot DAX Blogs 0 18.02.2009 08:05
Solutions Monkey: Using Microsoft Dynamics Ax 2009 Workflow controls in EP Blog bot DAX Blogs 0 30.07.2008 10:05
Solutions Monkey: Enterprise Portal Screencasts at Channel9.msdn.com Blog bot DAX Blogs 6 01.07.2008 19:38
Solutions Monkey: EP Configuration - Single Web Server & Multiple AOS installations Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 17:52.
