Старый 04.05.2009, 14:05   #1
Dynamics AX Geek: Finding files with WinAPI
Источник: http://axgeek.spaces.live.com/Blog/c...DB13!150.entry
 Axapta’s WinAPI class has a bunch of static methods to handle files. The code example below shows how to utilize some of these methods to find files.
The two methods used to fetch all files matching the search criteria are findFirstFile() and findNextFile(). Don’t forget to clean up after yourself with findClose().
The code also uses three different find methods:
  • fileExists(_name) returns true, if _name is an existing file
  • folderExists(_name) returns true, if _name is an existing file or folder
  • pathExists(_name) returns true, if _name is an existing folder
The example uses the infolog for output. As with any infolog beware of performance and limitation to 10.000 lines.
 static void FindFile(Args _args)
  #File
  FileName fullFileName(FileName _path, FileName _fileName)
   pathName;
   fileName;
   fileExtension;
  [pathName,fileName,fileExtension] = fileNameSplit(_fileName);
  return _path + '\\' + fileName + fileExtension;
  void findFiles(FileName _path,
  FileName _fileName,
  boolean _inclSubDir = true,
  FileName _prefix = fullFileName(_path,_fileName))
   fileName;
  int hdl;
  setprefix(_prefix);
  if (WinAPI::folderExists(_path))
  [hdl,fileName] = WinApi::findFirstFile(fullFileName(_path,_fileName));
  while (fileName)
  if (WinAPI::fileExists(fullFileName(_path,fileName)))
  info(fileName);
  fileName = WinApi::findNextFile(hdl);
  WinApi::findClose(hdl);
  if (_inclSubDir)
  [hdl, fileName] = WinAPI::findFirstFile(_path+'\\'+#AllFiles);
  while (fileName)
  if (strlwr(fileName) != strlwr(_fileName) &&
  strlwr(fileName) != strlwr('.') &&
  strlwr(fileName) != strlwr('..') &&
  WinAPI::pathExists(fullFileName(_path,fileName)))
  findFiles(fullFileName(_path,fileName), _fileName, _inclSubDir, fileName);
  findFiles('c:\\Program Files','*.doc');
За это сообщение автора поблагодарили: Gustav (0), alex55 (1).
Старый 08.10.2009, 17:36   #2
alex55 is offline
alex55
224 / 145 (5) +++++
А кто-нибудь знает почему возвращаются значения '.' и '..' при обработке пустой директории и зачем в коде берется нижний регистр от точек?
winapi
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Dynamics AX Geek: Finding files with WinAPI Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 06:45.
