Старый 29.03.2012, 17:11   #1
emeadaxsupport: Overview of AX build numbers
Источник: http://blogs.msdn.com/b/axsupport/ar...d-numbers.aspx
Dynamics AX 2012
Feature PackKernel buildApplication buildSolution buildComment/LinkDynamics AX 2012 FP1 (6.1) Hotfix6.0.1108.xxx6.0.1108.xxx6.1.1108.xxx Dynamics AX 2012 FP1 (6.1) RTM6.0.947.8626.0.947.2806.0.1108.0Feature Pack 1VersionKernel buildApplication buildCommentLinkDynamics AX 2012 CU26.0.947.2806.0.947.280 Cumulative Update 2Dynamics AX 2012 CU16.0.947.616.0.947.61 Cumulative Update 1Dynamics AX 2012 RTM Hotfix [new]6.0.1108.xxx6.0.1108.xxxAs of Feb 15thPublished HotfixesDynamics AX 2012 RTM Hotfix [old]6.0.947.xxx6.0.947.xxxUntil Feb 15thPublished HotfixesDynamics AX 2012 RTM6.0.947.06.0.947.0 RTM
Dynamics AX 2009
VersionKernel buildApplication buildLinkCommentDynamics AX 2009 SP1 RU-85.0.1500.64915.0.1500.6491Rollup 8 Dynamics AX 2009 SP1 RU-75.0.1500.45705.0.1500.4570Rollup 7 Dynamics AX 2009 SP1 RU-65.0.1500.37615.0.1500.3761Rollup 6 Dynamics AX 2009 SP1 RU-55.0.1500.29855.0.1500.2985Rollup 5 Dynamics AX 2009 SP1 RU-45.0.1500.21165.0.1500.2116Rollup 4 Dynamics AX 2009 SP1 RU-35.0.1500.13135.0.1500.1313Rollup 3 Dynamics AX 2009 SP1 RU-25.0.1500.8095.0.1500.809Rollup 2 Dynamics AX 2009 SP1 RU-15.0.1500.3585.0.1500.358Rollup 1 Dynamics AX 2009 SP1 Hotfix5.0.1500.xxx5.0.1500.xxxPublished Hotfixes Dynamics AX 2009 SP15.0.1000.525.0.1000.52Service Pack 1 Dynamics AX 2009 RTM RU-65.0.593.14295.0.593.1429Rollup 6 Dynamics AX 2009 RTM RU-55.0.593.12875.0.593.1287Rollup 5 Dynamics AX 2009 RTM RU-45.0.593.10845.0.593.1084Rollup 4 Dynamics AX 2009 RTM RU-35.0.593.8275.0.593.827Rollup 3 Dynamics AX 2009 RTM RU-25.0.593.6625.0.593.662Rollup 2 Dynamics AX 2009 RTM RU-15.0.593.4395.0.593.439Rollup 1 Dynamics AX 2009 RTM Hotfix5.0.593.xxx5.0.593.xxxPublished Hotfixes Dynamics AX 2009 RTM5.0.593.05.0.593.0RTM
Dynamics AX 4.0
VersionKernel buildApplication buildLinkCommentLatest SP2 Kernel Build4.0.2503.1610 KB2567634 Published AX 4.0 Hotfixes Published Hotfix List Please follow this link for a complete list of build numbers from AX 4.0 and previous versions:
--author: Daniel Durrer--editor: Daniel Durrer--updated: 29/03/2012
Старый 30.03.2012, 07:43   #2
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,342 / 3563 (125) ++++++++++
2 mazzy: Эту ссылку (прямо на источник) нужно вывесить на главную страницу. Это то, чего я 100 лет назад хотел сделать, да не сделал, а тут можно сказать информация практически от вендора.
Заодно узнал о выходе AX2012 FP1, для которой мало того, что собрали отдельный билд, так еще и написали, что демо-данные от AX 2012 к ней не подходят (а раньше предполагалось что надо апгрейдить данные самостоятельно).
Последний раз редактировалось sukhanchik; 30.03.2012 в 07:56.
Старый 24.05.2012, 19:13   #3
wojzeh is offline
wojzeh
Аватар для wojzeh
674 / 512 (19) +++++++
я вот что-то никак не врублюсь, а как этот feature pack установить на уже существующую инсталляцию с моими разработками -- ты ставил уже?
Felix nihil admirari
Старый 24.05.2012, 19:44   #4
sukhanchik
Сообщение от wojzeh Посмотреть сообщение
Не.... не ставил. Я то с 2012-й столкнулся по необходимости читать курсы. А т.к. в Россию спрос на АХ 2012 пока невелик, да и курсы не читаются по FP1 то я не ставил и не пробовал. Припрет - поковыряюсь. Но пока точно не в ближайшем обозримом будущем
Rahul Sharma: Dynamics AX Build Numbers Blog bot DAX Blogs 0 12.10.2010 15:05
Часовой пояс GMT +3, время: 17:54.
