25.11.2013, 18:52 | #10 |
Пытаясь изменить код под свои нужды, столкнулся вот с какой проблемой, вроде все делаю так как надо:
X++: using Microsoft.Xrm.Sdk; using Microsoft.Xrm.Sdk.Client; using Microsoft.Xrm.Sdk.Query; using Microsoft.Xrm.Sdk.Messages; using Microsoft.Xrm.Sdk.Discovery; using Microsoft.Crm.Sdk.Messages; using System.ServiceModel; namespace SetAccountName { public class SetAccountName : IPlugin { public void Execute(IServiceProvider serviceProvider) { // Получаемо сервис CRM из контекста IPluginExecutionContext context = (IPluginExecutionContext)serviceProvider.GetService(typeof(IPluginExecutionContext)); IOrganizationServiceFactory serviceFactory = (IOrganizationServiceFactory)serviceProvider.GetService(typeof(IOrganizationServiceFactory)); IOrganizationService service = serviceFactory.CreateOrganizationService(context.UserId); // Получаемо объект Target Entity entity = (Entity)context.InputParameters["Target"]; ColumnSet cs = new ColumnSet(); //try //{ if (entity.LogicalName == "phonecall") { if (entity.Contains("regardingobjectid")) { Guid phoneid = entity.Id; //Entity PhoneCall = service.Retrieve("phonecall", phoneid, new Microsoft.Xrm.Sdk.Query.ColumnSet(true)); Entity PhoneCall = service.Retrieve("phonecall", phoneid, cs); EntityReference regarding = ((EntityReference)PhoneCall.Attributes["regardingobjectid"]); switch (regarding.LogicalName.ToString()) { case "account": Entity account = service.Retrieve("account", regarding.Id, cs); entity.Attributes.Add("new_nameofaccount", account.FormattedValues.ToString()); //entity.Attributes["new_nameofaccount"] = account.FormattedValues["name"].ToString(); //entity.Attributes["new_nameofaccount"] = account.; //entity.Attributes["new_companyname"] = ((EntityReference)account.Attributes["name"]); break; case "lead": Entity lead = service.Retrieve("lead", regarding.Id, cs); entity.Attributes["new_nameofaccount"] = lead.FormattedValues["new_companyname"].ToString(); break; case "opportunity": Entity opport = service.Retrieve("opportunity", regarding.Id, cs); entity.Attributes["new_nameofaccount"] = opport.FormattedValues["customerid"].ToString(); break; } service.Update(PhoneCall); } } //catch (Exception ex) // { // throw new InvalidPluginExecutionException("An error occured in the Plugin.", ex); // } } } } Прошу сильно не пинать меня ногами. Это первый так сказать опыт по написанию своего собственного плагина, и как говорится сроки очень сильно поджимают. Подскажите - где мог ошибится и как все таки правильно реализовать получение значения имени организации в первом Кейсе. За ранее спасибо. |
Опции просмотра | |
