Старый 12.05.2014, 19:11   #1
crminthefield: Sitemap Issues after CRM 2011 Import into CRM 2013
Источник: http://blogs.msdn.com/b/crminthefiel...-crm-2013.aspx
I was recently assisting a customer with an import of their CRM 2011 organization into a new CRM 2013 deployment. The import completed successfully and after logging in we noticed that the some of the sitemap links were either broken (no response when clicking on them) or completely missing when compared with a brand new CRM 2013 organization.
Examples of Missing Links:
  • Email Configuration
  • Dashboards
  • Post Configuration
  • What’s New
  • Post Rule Configuration
  • Activities
Examples of what might be missing:
We were able to restore the missing links and fix the broken links by using the SiteMap Editor from the XRM ToolBox. The sitemap links in question were all out of the box and the customer had only added a few customized links within the SubArea element of the sitemap. The steps for resetting your sitemap to the 2013 defaults are outlined below. Please read the disclaimer below before following these steps.
Disclaimer: The steps below will reset the top 3 elements of your CRM sitemap. If you have added custom sitemap links in the Area>Group>SubArea elements of your sitemap, these changes will be overwritten with the default sitemap values. There is a step below outlining how to backup your pre-existing sitemap in case you do need to perform a restore, but it is not advised to move forward with these steps unless you plan to add back those custom sitemap links manually. As an alternative solution, review the information at the following link to add the new sitemap areas manually after upgrading your organization: http://msdn.microsoft.com/en-us/library/dn486920.aspx
Steps for Resetting your 2013 SiteMap to the Default Values
1. Download the XRM Toolbox for Dynamics CRM 2011/2013 found at: http://xrmtoolbox.codeplex.com/
2. Once downloaded, extract the package contents
3. Open File Explorer and browse to the location where you extracted the package
4. Locate the XrmToolBox.exe file, right-click on the file and click Run as administrator
Note: If your receive an error stating you must first install .NET 4.0, please download and install before continuing to the next step.
5. Once the application is open, click on the Connect to CRM icon in the upper left-hand corner
6. On the Select connection page, click New Connection
7. Enter the connection information for your CRM deployment and click Get Orgs to populate the Organization dropdown box
8. Select the Organization that contains the broken sitemap from the Organization dropdown box and click OK
9. Click Yes to confirm you’d like to connect now
10. You should now see your connection listed in the lower-left corner of the ToolBox window
11. On the ToolBox main menu, scroll down the list of tools and click on SiteMap Editor
12. On the SiteMap Editor tab, click Load SiteMap
You should now see the sitemap listed in the SiteMap dialogue box on the left
13. From the actions menu, click Save SiteMap to export a copy of the pre-existing sitemap for backup purposes
14. Click OK to the SiteMap Saved informational message
15. Now that you have a backup of your sitemap, click the More actions dropdown and click Reset CRM 2013 SiteMap to default
16. Click Yes when asked if you are sure you want to reset the sitemap
17. You should now be able to login to CRM and verify that your sitemap is fully functional
If you have any additional SiteMap tips or tricks you'd like to share with the community, please comment below!
Thanks!
Reed Wolfe
Premier Field Engineer
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2013 Update Rollup 2 Blog bot Dynamics CRM: Blogs 0 15.04.2014 01:15
Часовой пояс GMT +3, время: 17:31.
