Старый 04.11.2020, 13:06   #1
Ion is offline
Ion
Сообщение от Ion Посмотреть сообщение
Спасибо, нашел в Main_system_library методы generateWordTemplateFlyout, runWordTemplate - все то что нужно!
Вот эти функции, по сути если кому-то надо будет, по можно просто подпилить функцию generateExcelTemplateFlyout и добавить нужные фильтры.
var CustomXrmCore;
(function(CustomXrmCore) {
    var Commands;
    (function(Commands) {
        var ExportLibrary = function() {
            function ExportLibrary() {
                var _this = this;
                this.generateWordTemplateFlyout = function(commandProperties, entityTypeName, isForm, gridControl) {
                    var documentType = 2
                      , ribbonRelationshipType = -1
                      , contextType = 0
                      , currentEntityTypeName = entityTypeName;
                    if (isForm)
                        contextType = 1;
                    else {
                        if (entityTypeName == "activitypointer" && gridControl != null && gridControl.getGrid() != null) {
                            var selectedRows = gridControl.getGrid().getSelectedRows();
                            if (selectedRows != null && selectedRows.getLength() == 1) {
                                var selectedEntity = selectedRows.get(0).data.entity;
                                if (selectedEntity != null)
                                    currentEntityTypeName = selectedEntity.getEntityName()
                        if (typeof gridControl.getRelationship === "function") {
                            contextType = 2;
                            var relationship = gridControl.getRelationship();
                            if (relationship !== null && relationship.relationshipType === 0)
                                ribbonRelationshipType = 0;
                            else if (relationship !== null && relationship.relationshipType === 1)
                                ribbonRelationshipType = 1
                    var deferred1 = XrmCore.InternalUtilities.ExportUtilities.retrieveSystemDocumentTemplates(currentEntityTypeName, documentType)
                      , deferred2 = XrmCore.InternalUtilities.ExportUtilities.retrievePersonalDocumentTemplates(currentEntityTypeName, documentType)
                      , menu = Promise.all([deferred1, deferred2]).then(function(_a) {
                        var systemTemplates = _a[0]
                          , personalTemplates = _a[1];
                        ExportLibrary._systemTemplates = systemTemplates;
                        ExportLibrary._personalTemplates = personalTemplates;
                        return _this.buildMenu(systemTemplates, personalTemplates, entityTypeName, isForm, contextType, ribbonRelationshipType, documentType)
                    commandProperties["PopulationXML"] = menu;
                    return
                this.generateExcelTemplateFlyout = function(commandProperties, entityTypeName, gridControl) {
                    var isForm = false
                      , documentType = 1
                      , contextType = 0
                    if (entityTypeName == "activitypointer" && gridControl != null && gridControl.getEntityName() != null)
                        currentEntityTypeName = gridControl.getEntityName();
                        contextType = 2;
                    return
                this.openDocTemplateDialog = function(dialogName, documentType, gridControl, isForm) {
                    var width = 512
                      , height = 300
                      , docDialog = "DocumentTemplateUpload";
                    if (documentType == 2 && dialogName === "DownloadTemplate") {
                        width = 850;
                        height = 650
                    if (dialogName === "DownloadTemplate")
                        docDialog = "DocumentTemplateDownload";
                    var params = {};
                    if (isForm)
                        params["Entity_Name"] = gridControl.entityReference.entityType;
                    else {
                        var viewId = gridControl.getViewSelector().getCurrentView().id.replace("{", "").replace("}", "")
                          , currentView = gridControl.getViewSelector().getCurrentView().name
                          , fetchXmlData = gridControl.getFetchXml();
                        params["Entity_Name"] = gridControl.getEntityName();
                        params["View_Id"] = viewId;
                        params["current_view"] = currentView;
                        params["fetch_xmldata"] = fetchXmlData
                    params["DocTemplateFile_Type"] = documentType;
                    params["DocTemplate_ExpectedFileType"] = documentType == 1 ? 3 : documentType;
                    params["DocTemplate_Type"] = 9941;
                    Xrm.Navigation.openDialog(docDialog, {
                        width: width,
                        height: height,
                        position: 1
                    }, params).then(function(result) {
                        if (result.parameters && result.parameters["Is_DocumentTemplate_Uploaded"] != undefined && result.parameters["DocumentTemplate_index"] != undefined)
                            if (result.parameters["Is_DocumentTemplate_Uploaded"] == 1) {
                                var entityFormOptions = {};
                                entityFormOptions["entityName"] = "personaldocumenttemplate";
                                entityFormOptions["entityId"] = result.parameters["DocumentTemplate_index"];
                                var actionDescriptor = {
                                    actionLabel: Xrm.Utility.getResourceString("Main_system_library", "View_Personal_Document_Template"),
                                    eventHandler: function() {
                                        Xrm.Navigation.openForm(entityFormOptions)
                                Xrm.UI.addGlobalNotification(1, 1, Xrm.Utility.getResourceString("Main_system_library", "DocTemplate_Successfully_Uploaded"), null, actionDescriptor)
                        Xrm.Utility.closeProgressIndicator()
                    return
                this.runWordTemplate = function(commandProperties, entityTypeCode, gridControl, selectedRecords) {
                    var isForm = false
                      , records = [];
                    if (typeof selectedRecords === "string") {
                        records = [selectedRecords];
                        isForm = true
                    } else
                        records = [selectedRecords[0].Id];
                      , openMode = {
                        openMode: 2
                      , personalTemplateKeyword = "WordTemplates.Menu.PersonalWordTemplates."
                      , sourceControlId = commandProperties["SourceControlId"];
                    if (sourceControlId == "ViewAllMyTemplatesId") {
                        _this.navigateToPersonalDocumentTemplates("recordlist", "personaldocumenttemplate");
                        return
                    var templateEntityName = "documenttemplate";
                    if (sourceControlId.indexOf(personalTemplateKeyword) !== -1)
                        templateEntityName = "personaldocumenttemplate";
                    var templateId = sourceControlId.split(/[. ]+/).pop();
                    if (templateId === "UploadTemplate" || templateId === "DownloadTemplate") {
                        _this.openDocTemplateDialog(templateId, documentType, gridControl, isForm);
                        return
                    var templateRef = {
                        id: "{" + templateId + "}",
                        entityType: templateEntityName
                      , actualEntityTypeCode = isForm ? entityTypeCode : Xrm.Internal.getEntityCode(selectedRecords[0].TypeName)
                      , recordsString = JSON.stringify(records)
                      , exportWordDocumentRequest = new XrmCore.SdkContracts.ExportWordDocumentRequest(actualEntityTypeCode,templateRef,recordsString);
                    Xrm.Utility.showProgressIndicator(Xrm.Utility.getResourceString("Main_system_library", "ExportToDocx_ProgressDialog_Header"));
                    var deferred = Xrm.WebApi.online.execute(exportWordDocumentRequest).then(function(res) {
                        return res.json()
                    }).then(function(odataResponse) {
                        var template = undefined;
                        if (templateEntityName === "documenttemplate")
                            template = ExportLibrary._systemTemplates.filter(function(obj) {
                                return obj.Id === templateId
                            })[0];
                        else
                            template = ExportLibrary._personalTemplates.filter(function(obj) {
                            })[0];
                        var file = {
                            fileContent: odataResponse.WordFile,
                            fileName: XrmCore.InternalUtilities.ExportUtilities.generateExportFileName(template.Name, documentType),
                            mimeType: "application/vnd.openxmlformats-officedocument.wordprocessingml.document"
                        Xrm.UI.addGlobalNotification(1, 1, Xrm.Utility.getResourceString("Main_system_library", "Menu_Label_Group_Word_SucessfullyDownloaded"), null, null);
                        return Xrm.Navigation.openFile(file, openMode)
                    }, function(errorResponse) {
                        Xrm.Utility.closeProgressIndicator();
                        console.log(errorResponse);
                        var errorMessage = "";
                        if (errorResponse.innerror && errorResponse.innerror.message) {
                            if (errorResponse.innerror.message != "")
                                errorMessage = errorResponse.innerror.message
                        } else
                            errorMessage = errorResponse.message;
                        var errorDialogOptions = {
                            message: errorMessage,
                            errorCode: errorResponse.errorCode
                        Xrm.Navigation.openErrorDialog(errorDialogOptions)
                    }).then(function(res) {
                        console.log(res);
                    return
                this.navigateToPersonalDocumentTemplates = function(pageType, entityName) {
                    var personalDocTemplatePageInput = {
                        pageType: pageType,
                        entityName: entityName
                    Xrm.Navigation.navigateTo(personalDocTemplatePageInput)
                this.buildMenu = function(systemTemplates, personalTemplates, entityTypeName, isForm, contextType, ribbonRelationshipType, documentType) {
                    var menuId = XrmCore.InternalUtilities.ExportUtilities.determineRibbonMenuId(entityTypeName, isForm, contextType, ribbonRelationshipType, documentType, false)
                      , onlineMenuId = XrmCore.InternalUtilities.ExportUtilities.determineRibbonMenuId(entityTypeName, isForm, contextType, ribbonRelationshipType, documentType, true)
                      , commandId = XrmCore.InternalUtilities.ExportUtilities.determinRibbonCommandId(entityTypeName, isForm, contextType, ribbonRelationshipType, documentType, false)
                      , systemButtonsControl = systemTemplates != null ? XrmCore.InternalUtilities.ExportUtilities.buildControlsFromTemplates(menuId, onlineMenuId, commandId, systemTemplates, true, documentType) : null
                      , personalButtonsControl = personalTemplates != null ? XrmCore.InternalUtilities.ExportUtilities.buildControlsFromTemplates(menuId, onlineMenuId, commandId, personalTemplates, false, documentType) : null
                      , createcommandId = XrmCore.InternalUtilities.ExportUtilities.determinCreateRibbonCommandId(entityTypeName, isForm, contextType, documentType, true)
                      , createTemplates = XrmCore.InternalUtilities.ExportUtilities.retrieveCreateTemplates()
                      , createuploadDownloadButtonsControl = XrmCore.InternalUtilities.ExportUtilities.buildControlsForCreate(menuId, createcommandId, createTemplates, false, documentType)
                      , menuSection1 = XrmCore.InternalUtilities.ExportUtilities.buildMenuSection(menuId, false, documentType, true, 10, createuploadDownloadButtonsControl)
                      , menuSection2 = systemButtonsControl != null ? XrmCore.InternalUtilities.ExportUtilities.buildMenuSection(menuId, true, documentType, false, 20, systemButtonsControl) : null
                      , menuSection3 = personalButtonsControl != null ? XrmCore.InternalUtilities.ExportUtilities.buildMenuSection(menuId, false, documentType, false, 30, personalButtonsControl) : null
                      , menuSections = [];
                    menuSections.push(menuSection1);
                    menuSection2 != null && menuSections.push(menuSection2);
                    menuSection3 != null && menuSections.push(menuSection3);
                    var menu = XrmCore.InternalUtilities.ExportUtilities.buildMenu(menuId, menuSections);
                    return menu
				return {
					RunWordTemplate: runWordTemplate,
					GenerateWordTemplateFlyout: generateWordTemplateFlyout
			ExportLibrary = ExportLibrary();
            ExportLibrary._systemTemplates = [];
            ExportLibrary._personalTemplates = [];
            return ExportLibrary;
        Commands.ExportLibrary = ExportLibrary
    )(Commands = CustomXrmCore.Commands || (CustomXrmCore.Commands = {}))
)(CustomXrmCore || (CustomXrmCore = {}));
За это сообщение автора поблагодарили: a33ik (1).
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2013 Update Rollup 2 Blog bot Dynamics CRM: Blogs 0 15.04.2014 01:15
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 12 Blog bot Dynamics CRM: Blogs 0 30.01.2013 01:11
crminthefield: CRM Upgrade Best Practices Blog bot Dynamics CRM: Blogs 0 11.10.2012 00:11
CRM Programmer: How to hide an items of drop-down list? Blog bot Dynamics CRM: Blogs 0 10.11.2009 14:05
Часовой пояс GMT +3, время: 20:12.
