Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 29.03.2006, 14:19   #1
Maxim Gorbunov is offline
Maxim Gorbunov
2,483 / 646 (26) +++++++
Application Developer Documentation (by DubbleEagle)
Posted on 28-Mar-2006 at microsoft.public.axapta.programming by DubbleEagle
I would like to add my own Application Developer Documentation to Axapta. I
know how to do so for tables and classes (because the nodes already exist),
but is this also possible for forms/jobs/edt's ?? I tried opening the editor
with path like "AODDOC://Forms/Address", and the editor really opens this
path, but saving the item doesn't seem to work.
Any idea's ??
And why did Axapta restrict this documentation to only tables and classes ???
Application developer documentation is opened when you press F1 while in the X++ Source Code Editor window. The main purpose of this documentation is to give information about the methods of a class of currently highlighted variable. Since jobs and types do not have methods, they are not listed under this node. Forms have methods but they are all represented with the FormRun class when referred from X++ code. So you cannot tell, which form is represented by a variable unless you run your code (i.e. instantiate the object).
You can put user documentation for forms and data type under the Application documentation node. Also you can create Help topics, Hints or Global help items using the Help Book projects. But then you will have to take care about providing access to them from somewhere in Axapta.
mfp: Anyone interested in developer documentation of X++ code? Blog bot DAX Blogs 0 19.02.2008 18:50
Экспорт Application Documentation miklenew DAX: Программирование 5 19.06.2007 16:25
Application Documentation и AX 4.0 Damn DAX: Программирование 6 06.04.2007 17:15
tomb: Microsoft Dynamics AX 4.0 SP1 Application Documentation Hotfix Blog bot DAX Blogs 0 12.03.2007 15:30
mfp: I want developer documentation! Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 22:04.
