Старый 18.01.2010, 18:38   #1
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1849 (69) ++++++++
Kernel rollup 975520 is available for Microsoft Dynamics AX 4.0 Service Pack 2
Problems that are resolved in hotfix rollup 975520
This hotfix rollup resolves the following problems in Microsoft Dynamics AX 4.0 SP2.
Microsoft Dynamics AX client crashes when you open the Item counting journal form
Consider the following scenario. You set a value in the Automatic shutdown setting in the User options form. Then, you open the Item counting form. When the automatic shutdown time expires in this scenario, Microsoft Dynamics AX client crashes.
Group totals labels are missing on a report that is created by using the Autodesign design template
Consider the following scenario. You have a report that is created by using the Autodesign design template. In the query of the report, you enable the Group totals setting for some fields on the Sorting tab. Then, you print the report to the screen or to a printer. In this scenario, the sorting fields that have the Group totals setting enabled are displayed incorrectly. Additionally, There is only one label for the first record.
Внимание: ссылка на закрытый ресурс (Partnersource)
-ТСЯ или -ТЬСЯ ?
ax4.0, hotfix, скачать (download)
daxcoder: Hotfix rollup 3 is available for Microsoft Dynamics AX 2009 Service Pack 1 Blog bot DAX Blogs 0 02.10.2009 05:14
Kernel rollup 971558 is available for Microsoft Dynamics AX 4.0 Service Pack 2 Vadik DAX: База знаний и проекты 2 23.07.2009 00:01
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Service Pack 1 Released Blog bot DAX Blogs 5 21.11.2008 17:00
Часовой пояс GMT +3, время: 12:08.
