Старый 26.03.2024, 16:11   #1
25,487 / 846 (79) +++++++
a33ik: Read/Write CSV file
Источник: http://daxonline.org/1945-read-write-csv-file.html
If unquoted text values are required then CommaTextStreamIo should be replaced with TextStreamIo, which has the same methods.
Read CSV file
#File #OCCRetryCount #define.delimiterField(',') System.IO.MemoryStream memoryStream = connector.getCurrentMemoryStream(); CommaTextStreamIo commaTextStreamIo = CommaTextStreamIo::constructForRead(memoryStream); if (commaTextStreamIo) { if (commaTextStreamIo.status()) { throw error("@CLIDocuments:FileUpload_Failed"); } commaTextStreamIo.inFieldDelimiter(#delimiterField); commaTextStreamIo.inRecordDelimiter(#delimiterCRLF); container record; while (!commaTextStreamIo.status()) { record = commaTextStreamIo.read(); } }
Write CSV file
CommaTextStreamIo commaTextStreamIo = CommaTextStreamIo::constructForWrite(); commaTextStreamIo.writeExp(['row 1 col 1', 'row 1 col 2']); commaTextStreamIo.writeExp(['row 2 col 1', 'row 2 col 2']); File::SendFileToUser(commaTextStreamIo.getStream(), 'file name.csv');
Result:
dynamicsaxinsight: D365FO: Read CSV file from Azure File Share Blog bot DAX Blogs 0 28.07.2022 13:12
dynamicsaxinsight: Read CSV file in X++ Blog bot DAX Blogs 0 20.10.2020 14:12
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 Blog bot NAV: Blogs 0 15.05.2016 18:12
DynamicsAxSCM: Change license plate, split quantity, skip and override location during inbound put away Blog bot DAX Blogs 0 27.11.2015 16:11
bojensen: IT Happens Here!: How to write in a CSV file from X++ Blog bot DAX Blogs 0 02.01.2013 21:11
Часовой пояс GMT +3, время: 00:44.
