Старый 19.07.2024, 03:31   #1
25,554 / 848 (80) +++++++
To Increase: Overcoming EDI Implementation Pitfalls
Источник: https://staedean.com/data/blog/edi-i...namics-365-erp
EDI implementation can pose several unforeseen hurdles and slow down the process of EDI adoption. For every new EDI project that comes to us, we perform an analysis and review and based on the results, we share an estimated time for the project to go live. Unfortunately, despite doing an analysis, we often see companies struggle to meet their deadlines. We have prepared a list of the factors that are responsible for this delay. They range from the lack of planning to changes in business priorities.
We have seen so many EDI implementation obstacles come up over the years. We hope that putting together this list will help our prospects plan better and benefit from these past experiences. You can consider this as an EDI solution implementation guide for Microsoft Dynamics 365 Finance & Supply Chain ERP. We also share best practices in this blog to keep in mind to better plan and set timelines for your project.
Before jumping into the pitfalls, there is one big recommendation for organizations implementing Microsoft Dynamics 365 Finance & Supply Change Management or are early in the process.
It is likely that your business processes are not clearly defined and could change. This could impact your EDI implementation. In our experience, businesses that start implementing EDI earlier in the D365 implementation when business processes are more fluid and less defined, will most likely have more changes and take longer to go live. However, organizations that are already live with D365 F&SCM have a less complex EDI implementation in comparison to organizations still going live. Having said that you can implement an EDI solution while implementing D365 F&SCM but will need to be more flexible with the timelines.
stoneridgesoftware: Checklist for Ensuring a Successful CRM Implementation Blog bot Dynamics CRM: Blogs 0 16.08.2018 14:11
stoneridgesoftware: 3 Proven Principles for Implementation Success Blog bot DAX Blogs 0 14.10.2016 01:11
Часовой пояс GMT +3, время: 02:52.
