Старый 21.11.2005, 09:26   #1
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Несколько полезностей для Axapta
http://www.systomatics.biz/Projects.htm
InventMovement/InventUpdate
(Last update 15th August 05)
Project related to InventMovement and InventUpdate framework.
By-product for manufacturing
Project for introducing by-product in Axapta manufacturing.
Infolog
Make your users happy, allow them to see the closed infolog again.
Object generator
A small utility that will come in very handy during the implementation
Master planning positive days
Fingering around the positive days in master planning...
Vendor remittance advice
(Last update September 05)
Vendor remittance advice that will display the invoices details.
Validation hierarchy for financial dimension
Want to define hierarchy or limit the combinations of financial dimensions? This is the project for you.
Sales duel unit of measure
A project for using dual units of measure for sales.
Negative on-hand inventory
(Last update 4th October 05)
date controlled 'allow negative on-hand'
Uploading journals into Axapta
(Last update 2nd November 05)
Upgrade proof code to upload journals into Axapta
I hate this project - change code at runtime
(Last update 10th November 05)
Try this for testing - how to change code at runtime.
axaptabuilder: How to build Axapta application from XPO files stored in Visual Source Safe. Blog bot DAX Blogs 0 12.04.2007 16:10
axaptabuilder: How to build Axapta application from XPO files stored in Visual Source Safe. Blog bot DAX Blogs 0 22.11.2006 15:20
Несколько || процессов в Axapta Patriot DAX: Программирование 2 29.10.2002 17:02
Часовой пояс GMT +3, время: 16:28.
