Старый 16.11.2006, 17:40   #1
axaptafreak: AOT search within search results
Источник: http://axaptafreak.blogspot.com/2006...h-results.html
One of the things that happen to you when you take an active part in a community is that you actually build up a community. This way, I get emails with questions about Axapta but also people send me their projects to test them.
So, a guy called Jonathan Watkins asked me if I can test a tool called "AOT Search extended" for him. Well I did now so I will share it with you all.
What does the tool do? When you search something in AOT, you get a load of results. And what if you then subsequently want to search inside these results?
That's where the tool can help you. Just before you do your initial search, click on "Save results". After the search has finished (or you stopped it), click on "New search" and it will ask you if you want to search within your previous results.
Cute, isn't it? The tool has been made in Axapta 3.0 SP4, but will also work in other 3.0 versions.
I have created a page in Axaptapedia for it, you can find it here: http://www.axaptapedia.com/AOT_Searc...search_results
You can also download the tool directly from here: http://www.geocities.com/axaptafreak...chextended.zip
And, as always: my apologies if you cannot download the file. I have no webspace so I have to put it on my Yahoo Geocities account which has limited traffic allowance.
Dianne Siebold: Limit MSDN Search to AX Content Only (4.0) Blog bot DAX Blogs 0 16.02.2008 04:41
Dynamics AX: Search, and the SharePoint OS Blog bot DAX Blogs 0 09.01.2008 04:34
Inside Dynamics AX 4.0: Common Search Blog bot DAX Blogs 0 29.10.2007 10:50
daxmy: AOT Find function Blog bot DAX Blogs 0 17.08.2007 01:23
Arijit Basu: Search Windows Live from AX Blog bot DAX Blogs 0 02.06.2007 17:13
Часовой пояс GMT +3, время: 01:13.
