Старый 02.11.2010, 18:05   #1
dynamics-ax-dev: Retrieving Record Values in an Enterprise Portal Wizard/Tunnel
Источник: http://dynamics-ax-dev.blogspot.com/...nterprise.html
Let’s say you have a scenario in which you need to pull a field from a newly created record that was inserted into AX via an Enterprise Portal Wizard/Tunnel. This need could be useful in the event that after a record is created, you need to obtain the record’s Id, so that you can do something else which relates to the new record. In this example we will extend the code example found in the book “Microsoft Dynamics AX 2009 Programming: Getting Started” (page 304)
protected void WizardTunnel_FinishButtonClick(object sender,
WizardNavigationEventArgs e)
AxDataSourceView rentalTableView =
this.RentalDataSet.GetDataSourceView("RentalTable");
if (rentalTableView != null)
rentalTableView.EndEdit();
AxUrlMenuItem carRentalsMenuItem =
new AxUrlMenuItem("CarRentalList");
Response.Redirect(carRentalsMenuItem.Url.ToString());
To pull the value from the CarRentalId in the following modified event handler…
DataSetViewRow dvr = rentalTableView.DataSetView.GetCurrent();
string CarRentalId = dvr.GetFieldValue("CarRentalId").ToString();
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
JOPX: Dynamics AX 2009 - Enterprise Portal link bonanza Blog bot DAX Blogs 0 27.11.2008 01:05
jinx: Microsoft Dynamics AX 2009 Enterprise Portal Entwicklung Samples Blog bot DAX auf Deutsch 0 27.06.2008 04:06
JOPX: Integrating MOSS 2007 and Dynamics AX Part II - installing and configuring Dynamics AX Enterprise Portal Blog bot DAX Blogs 0 02.03.2008 06:42
Часовой пояс GMT +3, время: 13:43.
