Старый 02.02.2012, 15:11   #1
palleagermark: "Find as you type" in the AX 2012 X++ editor
Источник: http://palleagermark.blogspot.com/20...-x-editor.html
As you may know the new X++ editor in AX 2012, is actually the Visual Studio editor.
One of the sweet things that gives us, is the ability to do "Find as you type" searches in the code.
Press CTRL + I once, and set of binoculars pops up. Now start typing, and you can see how the editor starts to find matching values in your code. If you want to stop the typing, and just find the next instance of the same text, just press CTRL + I again.
To search upwards in the code, press CTRL + Shift + I.
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
palleagermark: AX 2012 editor extensions Blog bot DAX Blogs 0 24.10.2011 16:11
Часовой пояс GMT +3, время: 02:48.
